Instrument cluster lights?
1987 300E, 1995 C280
Well i have an 87 w124, and you know the cluster lights suck! i was thinking about just dropping in leds, of the same size.. would they work fine? i mean in terms of melting the plastic or something like that
and i don't want to upgrade whole cluster out again as i have already swapped it due to a dead speedo :/ so it shows incorrect mileage haha
LEDs = Less heat. They don't produce light by heating a filament, they produce it by having the electrons drop an energy level, releasing a photon of light.
/physics
Anyway, they should be fine so long as you keep them in spec (Voltage of original filament bulbs, wattage, use discretion).
Also, you should look into the prisms from the later model clusters (92+?) which are larger, therefore collecting more light.
/physics
wow fast reply..
well i was looking into prisms, but doesn't that require the whole assembly to be swapped? like i said i already swapped the cluster because the speedometer and odometer didn't work.. the only other thing i did was retrofit a later model outside temp display
have any idea how i can find out what the voltage is and where i can find the proper leds? (i was looking through google and ebay)
http://www.peachparts.com/Wikka/W124InstCluster
According to this, the prisms are a direct swap.
This is an acceptable bulb replacement:
http://www.bulbtronics.com/Search-Th...ookieSupport=1
Looks like 12v (no surprises there) and 3w. Again, with LEDs you should be able to get away with more wattage as they produce much less heat. Use discretion.
The ***** of it will be finding LEDs with the proper base or retroing LEDs onto the proper basing.
As for the fast reply, I'm up late dodging sleep and bored out of my mind. Forum time
hmm if it is a direct swap, i shall retro the prisms in when i have time hehe.. i thought 3w was alot for older cars, i thought most use 1w or so, but sounds great.. also the bulb you posted, is it a yellow bulb or a white bulb? not that it matters.. just want all the visibility i can get
and literally "dodging/procrastinating" sleep huh? can't have any good effects on you.. trust me.. i've experimented too much with it :P
Well, if you want MAX visibility look for a bulb with anywhere under 5100k color temp :P Yellow can be easier for your eyes to focus on, increasing viewability. The closer you get to blue/white, the less visible it actually becomes.
Not sure on the bulb, I'm just using stock bulbs/prisms. I agree, it seems a bit dim but it is also not intrusive at night which is key. I believe that is why Benz stuck with the lighting color it did.
well i agree with that i guess, the orange does keep my eyes nice and dilated but i do have an 87 model so its probably a bit darker.. its kind of sad that i can't really see most of the gauges because its so dark (yes i have replaced the dimmer assembly as well) and the retrofitted temp gauge is the brightest thing in my cluster haha but ill get those prisms for sure, and upgrade to sylvanias.. way better to be safe than sorry (learned the hard way for many things)
According to the PeachParts Wiki, I have the upgraded prisms. With those and the stock bulbs, my ambient temp gauge is no brighter than the gauge faces. It works out rather nicely actually.
Funkgab, my 88 300TE's instrument cluster is amazing, while my 87 260E's is absolutely terrible. You don't need LED's. You need the updated prisms or just clean the ones you have. I haven't got around to fixing it yet, but it is so bad you can't see the bottom of the display at night.
Saijin, I didn't know the prisms were able to be dropped in? That is great to hear! I will order the updated prism to fix my issue
1989 300E 105,000 miles
Cluster
I used a method found somewhere in the forums. I wanted the original look but just brighter. I took out my prisms and cut them back off the light bulb about a 1/4 of an inch. Why? No melting issues using 5 watt bulbs! I then painted the bulb cavities white which increased the illumination throughout the entire light channels. Works great!
Alright thanks ps2cho, give me the price too if you do
And big dog the cluster looks great.. Not too great at cutting things tho if I do, usually they stop working ;p
Cluster
Chrome paint? Now that was a thought..............
I used some bright white primer paint laying around in the garage. I painted the bulb area and along the light channels too! Checked for melting issues several times and there were none. I saw a post somewhere where someone gave a tutorial on it. Maybe it was just me but the original even light look matching the rest of the instrument panel was my choice. I tried LED's but the color was off, the light was uneven and they occasionally flickered from time to time. I have LED's in other areas of the car like the footwells, glove box and trunk but not for the cluster!
Cluster
I tried the LED's there but decided to leave them alone. The light wasn't much brighter than the orginals and the color was off to me. However, the LED's in the trunk looked good! Some LED's tucked behind the trunk light out of the way and two more on either side in the corners. Doesn't look that bright with the dark carpet but reflects well off objects in the trunk...............
1 Post
*89 300 E -*91 300 TD -85 300SD *74 VW dune buggy
hello guys I am new here. Superbrightleds.com/car_bulb is the place where you can find deshboard led lights with a sucket in diferent colors.They go for less than 2$ a piece.Have fun.
mmm im actually set on just keeping the oem look, leds seem to throw it off :/ so im going to just upgrade the prisms and change the bulbs later on
