Help I destroyed my door lock!!
Old 07-20-2015, 07:56 PM
azure's Avatar
1995 E320
I did something very stupid today, not trying to imply I never did anything stupid in my life before but this was stupider than most...
Background: The door lock cylinder on drivers side of my 95 E320 hasn't worked for past few weeks. The key fits in but won't turn at all. But the door can be locked or unlocked via the other locks on the car. So I was planning on removing the cylinder from the door, trying to play around with it and hopefully get it to work and worst case scenario switch it with the passenger one which works fine.
However I did something stupid, I don't know why I did it and now I don't know what to do. Basically I first removed the hex set screw that holds the cylinder in place. Then, I thought that I needed to remove that plastic screw or whatever it is that is in the other hole on the side of the door. However when trying to unscrew it (granted I didn't know what it was or why I was opening it) it got stripped. Here's where the really stupid thing happened. I don't know what I was thinking but I decided to drill it out. I guess I was thinking I would put in a screw extractor. But somehow I drilled the whole thing out, then a bunch of pieces fell down inside the door. I don't know exactly what that mechanism was or how it worked, but I see that the outer door handle is now no longer able to open the door at all! Apparently I destroyed the linking mechanism that does that!! Can someone please tell me what I have to do, or what I have to replace in order to make this right????
Not to mention that I still haven't figured out how to remove the door lock cylinder which is what I went to do in the first place!!! I've been told to turn the key in it to get it out, but key doesn't turn.....
Please help!!!!
Old 07-20-2015, 08:38 PM
azure's Avatar
1995 E320
its reached the point where i'm about to take my dremel and start cutting chunks out of the side of the door so i can see whats going on there.....
Old 07-22-2015, 12:18 PM
Plutoe's Avatar
Received 1,052 Likes on 973 Posts
1999 E300TD
OOOOOOOOOOOOOOOOOOOOop's
Old 07-23-2015, 06:21 PM
Je Suis Moi's Avatar
1992 400E, 1997 SL500, 2009 R350, 1998 SL500 (for sale)
My first step would be to go to mbpartsworld.com which is Mercedes of South Atlanta's parts website. You can search for a parts drawing for your door so that you can see what it was that you damaged.
Next, I would figure out exactly how to take a door mechanism apart before I cause more problems. Perhaps Youtube may have a video or Pelican Parts' website may have a DIY article.
Once you figure those things out, you can hit a junkyard or other source to look for a replacement part.
Good luck and don't sweat it too much. If you broke it, you can probably fix it and learn from the experience.
Old 07-24-2015, 04:44 PM
SPONSOR
PelicanParts.com's Avatar
Look under body & interior at this link here. There are a lot of tech articles that can help you out with fixing whatever may need to be replaced. If you need parts and unsure of what is needed, you can always give us a call and we can help over the phone.
Old 07-31-2015, 04:51 AM
optimusprime m1's Avatar
W124 260E
You must turn the key to remove the part that holds the barrel .It is a try and turn it job it will go .Spray it with WD40 or oil , the key as to turn to get it out of the door.But in saying that i think you will need to pull the door car off to get at the door lock .For this operation go to you tube and put in Mercedes W124 door card removal .
Old 07-31-2015, 04:56 AM
W124 260E
As for the barrel it can be made good by working on the tumblers in the barrel .See the picture So sorry picture not loading up.
Old 07-31-2015, 04:59 AM
W124 260E
Same again as i posted this up some time ago it wont let me put it on again.
Quick Reply: Help I destroyed my door lock!!
