Tires for 20"Staggered Wheels for E320
I HAVE A 1996 E320 AND I AM PLANNING ON PUTTING 20" WHEELS 8.5 ON FRONT AND 9.5 ON REAR, WHAT SIZE TIRES SHUD I USE, CAN SOME ONE HELP??!
2000 E430 Sport
1998 e320
How did the car ride with the 20s good,bad the same I want to put 20 on my e but don't want it to ride like **** or feel every bump or stop at every train Xing How r the amg wheel i was thinking of getting a set 20 or amg
2000 E430 Sport
The wheels ride smooth but you just have to watch out for pot holes and YES, go slow on train tracks. If anything I would get these wheels
http://cgi.ebay.com/ebaymotors/20-WH...item5ad7af1c8b
1998 e320
Nice wheel.what rides better 18in amgs or the 20inI heard that lowprofile tires don't last long maybe a year or so I got a set of 20in dub trump spinners I got them for $300.00 they came off a e320 it was in a bad accident. I havn't had the time to put them on one becouse i want tp paint the benz first to mach the back of the spinner but i also like the chrome mono blocks
2000 E430 Sport
The 18's ride much better than 20's. They both are low pro tires. The big reason why low profile tires don't last long are because of air pressure and car isn't lowered correctly. If you have a bend in the wheel caused by a pot hole, tire may loose pressure and cause the side wall to wear out from the inside of the tire and cause bubbles or blow out. They can also loose pressure from weather conditions. If not lowered correctly the tires will wear from the inside causing the tires to wear much faster. So in other words You Play You Pay.
People still putting spinners on cars
You need to do more homework
If this concerns you
"How did the car ride with the 20s good,bad the same I want to put 20 on my e but don't want it to ride like **** or feel every bump or stop at every train Xing"
enough to ask the question.
Yes it will ruin your ride
Yes you will find yourself asking yourself why you ruined such a nice ride.
the 20's looked good above, but in Cali where the roads are smooth, you can pull that off. here in NYC, ha, no way.
20's 8.5 width with 40offset will fit on 235/35/20's though on my w210? I have a 96 e320 as well looking to put 20's on with these dimensions.
I'll have pictures up this week! Also I was looking for forums related to this subject, so I had to resurrect this thread being a new Mercedes-Benz owner and all.
I have a nice set of 20's that came off of a 2008 s-class. As you can see I've tried to mount them, it's rubbing the upper control arm. So obviously I need spacers. My question is, after the adapter are equipped what tires do I need? They have 245 40 20's on them right now. Oh and I have a 97 e320.
Received 1,730 Likes
1922 Ford Model T / no OBD
Check rpm of original tires and match new tires close to it.
I think with 20" rims that will give you about 15 height ratio
WATCH OUT FOR THOSE TOOTHPICKS ON THE ROAD.
Definitely not my cup of tea, as I am classic fan.
Here is a picture of mine 18" on the car.
the rims I have are 20x8.5 225/35 XL
[QUOTE=BenzBoi223;6802539]
Tengo un buen juego de 20 que salió de una clase S de 2008. Como podéis ver he intentado montarlos, está rozando el brazo de control superior. Así que obviamente necesito espaciadores. Mi pregunta es, después de que el adaptador esté equipado, ¿qué neumáticos necesito? Tienen 245 40 20 en ellos en este momento. Ah, y tengo un 97 e320.[/QUOTE
the rims I have are r20x8.5 225/35 xl. help!!!! for what car they are
[QUOTE=Ececi1;8624954]
