DIY with Pictures for 2000 E430 (W210) Cabin Filter Change / Glove Box Removal
I changed my cabin filter on my 2000 E430 today and I took a few pictures and made a DIY. Hope this helps anyone interested in doing this.
2003 S210 3.8L Brabus wagon
That was really nice of you to do that. I am sure some people here will benefit. I just did. These cars are easy to maintain if you understand a little about how they go together. They are not that complicated and dealer dependence is not required in order to own one. Thanks for the informative piece and welcome to the group.
Nice write-up. As a FYI to anyone interested, I very gently trimmed about 1/3 of the material off of the two friction fins on the back of the glovebox, allowing for super easy and fast subsequent removals. (This is a tip I read about on either this site or the other Benz site.)
The full
DIY for both types of cabin filters is in the diy section on
www.benzworld.org w210 forum.
www.autohausaz.com has them cheap
LelandHendrix (07-26-2016)
98 Brilliant Silver E320 Wagon
raymond's link is a bit idealized for your car.
To remove the under dash panel on the right side you need to remove the air vent grill (small black plastic) on the side of the transmission tunnel. There's a round black fastener with a slot for a screwdriver or similar. Then removing the screws will free the panel.
Ok, charcoal filters are done. The Wix filters are very different. I can't tell how much the original filters were used. There's no visual way to indicate this, because they are black. The Wix filters are dark with a slivery weave over the filter elements. It is certainly a different philosophy of charcoal filtering. I wish I knew which is best, but either way, the air coming through this car's filtration system is probably the best air I'll ever breathe, in terms of dust and pollen.
Now I'm working on the regular filter elements.
Early W210's had a charcoal filter filled with a large amount of charcoal and felt very heavy. Sometime during the model run the design was changed to more of a carbon impregnated paper one. Probably because the old one was overkill. I think for most of us changing it every four years is wasting money. Since it traps gases no easy way to tell if dirty unless it's 'loaded' and smells.
However, the dust/pollen filters are worth changing on schedule since if they get plugged the blower could overheat (a known weak point).
Thanks for the write-up.
I went to change out my cabin air filters yesterday, and to my surprise the car didn't have any. I have only had the car for about 8 months, so some shop out there made a nice penny off of the previous owner.
Received 1,730 Likes
1922 Ford Model T / no OBD
Did you check oil filter?
nope. I am not sure MB has any warning other than no pressure.
On my 1980 Peugeot diesel, I had red light coming when oil filter clog and bypass valve open.
I am not even sure MB has bypass valve.
Per my observation -it is not that uncommon that unscrupulous mechanics change the oil without replacing the filter.
Why get messy for something owner has no way to check.?
I see the same trend in house repairs. The add-on insulation is put heavy close to attic door, while far, hard to access corners have no insulation at all.
We are only human.
We are only human.
