W210 Engine Running Temperature?
My 2000 E320 W210 with 170K miles is always running 3/4 way on the temperature gauge. Is that normal? It hasn't over heated....yet. I sit in traffic and it stays that way.
Is there a thermostat I can change to run cooler or I need to do something else to make it run cooler?
Thanks~
Thanks~
H danielle (06-09-2019)
'99 E430, '05 ML500, '15 GLK350
The "normal" temperature should be a little above 80, right around 90. Hot weather, running your AC and sitting in traffic can dirve it higher, but if it gets up to the 3/4 mark, my guess is that your fan clutch needs replacing (fairly common item by your mileage). Of course, make sure you have enough coolant first.
Thanks for the info guys. I am going to pick up a thermostat. The coolent if to the full line. Last would be the fan clutch since it cost more.
WHAT TEMP IS IT POINTING AT?
IF IT STAYS STEADY AT 90C IT IS NORMAL.It can even go higher or lower depending on ambient temp,traffic,load etc.
You can double check by using the digital readout in the climate control diagnostics.
If your tstat was stuck closed you would be way above 3/4 way.
Check the digital readout,post a picture via your camera,My suspicion is you are normal and no need to change anything.
If it has been 3 years or more change it and flush the system and install 50/50 mix of GO5 zerex .
Okay, thanks. I'll go take a picture of it and post it up tonight.
That's not really normal, esp at 73F. It's not dangerous, but it is higher than usual. If that is the temp you get while driving, then it can indicate something blocking the cooling in the radiator (low coolant, clogged pipes, debris in the fins). If it is the temp reached while idling, it is most likely a bad fan clutch.
My car, while driving in 99F weather, is steady at 87-90C ( maybe 1/10th inch above 80) which is right at the thermostat opening point. While idling, the temp may rise as high as yours before the fan clutch fully engages to bring it lower.
Was my car surpose to have a fan clutch? I opened the hood to check the coolent(good), checked for leeks(good), fan clutch(there is non). I am going to get the car flushed and change out the thermostat this weekend first. I hope that helps.
Yes, you have a fan clutch. It is the hub part of your fan, and you need to remove the fan (using a holding tool like the one attached) to replace it.
Here's a bad video that still gives you an idea of how to replace it:
fan clutch video
If you don't hear whooshing with from the front end when the car is hot and you increase engine rpm, the clutch is not working.
Also attached are two pics showing my temp at highway speeds and at idle today, AC on, 86-87F outside temp. The 8 never got uncovered completely.
fan clutch video
fan clutch video
fan clutch video
I don't see a fan/fan clutch beside the electric fans on the radiator. I just have a serpentine belt. I'll have to take a picture of it when I get home.
Yes~! You are right. I do not have a fan clutch. I am going to take it to a Mercedes place tomorrow and have them look at it. They said it might be a fan relay...something, something.
Nein! You need to look at the front of your engine, not in front of the radiator. If there is no fan there, that is your problem.
The electric fans in the front of the radiator are only aux fans that kick in at high temp.
Here is the part for your car: http://www.autohausaz.com/search/pro...2@Fan%20Clutch
also look at step 2 in the first pdf here: http://www.benzworld.org/forums/w210...-pump-wis.html
Went to get my car checked out. The cooling fans is working. Thermostat not opening all the way. Here is a picture of my engine bay. No fan clutch. Just a fan.
Someone replaced your mechanical cooling fan with an electrical one. It will have different setpoints than the stock clutch. Since your temp is still within an acceptable band, you can live with it. If the fan is working, it should drop the temperature when it kicks on. Thermostat replacement is an easy DIY job.
Nobody
replaced anything with an electric fan.
That is factory electric fan and shroud mounted behind the radiator and pulls air through.
Stop confusing the poor guy
Stop confusing me with your too short posts.
My 2000 E430 has a fan clutch behind the rad with 2 electric fans in front. My temp gauge runs in the identical place as sarakung's.
Okay, I just changed out the thermostat($34, not bad)and the temp is still at 3/4. So I am guessing it was not the thermostat.
When I got home and pulled into the garage, I kept it running and looked at the radiator fan to see if it was spinning. It was spinning really slow. You coulld actually put your finger in there to stop it. But it was spinning. I am thinking on chaning out the fan to a fan that puts out more cfm.
My idea was to relay the new fan so it will run on full power but triggered with the stock relay. I am thinking of purchasing a Spal fan.
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
If it doesn't get above 100 I would not be too concerned. How old is the coolant? Every 3 years you need to change it and be sure to use distilled water and MB or Zerex G05.
There were a few times on some really hot days where it hit 100, but didnt go over. Recently, I got the indicator for the low coolant level. I went to my local lordco (local car store, was not near any MB dealers), and they gave me "Pentofrost NF" which was made in Germany for european cars.. So I mixed that with distilled water. Shortly after my coolant reservoir was empty again(a leak somewhere I'm guessing).. So I filled it with the same thing, but seems the leak has stopped, but the heat still goes slightly high when the car is driving in the city. Will the dealers have Zerex?
