E-Class (W211) 2003-2009
How many miles on your W211?
Old 10-01-2009, 01:11 PM
  #101
Can Drive 55's Avatar
2005 E55
Originally Posted by Can Drive 55
Not me. Other issues, but the pump seems to be just fine.
1. 2005 E55
2. 52,000
3. Strut leak, SRS failure 3 times, satellite radio replaced, oil leak at valve cover, parktronic sensors twice, and door sill light failure twice.
Old 10-01-2009, 04:25 PM
  #102
patrick_y's Avatar
2006 E55 and 2002 E320
1. 2005 E55
2. 52,000
I hope you have extended warranty!
Old 10-02-2009, 11:32 PM
  #103
2005 E55
I do. Seven years and 100k miles. There is plenty of life left in it. So far, other than the strut, the repairs would have been reasonable in cost. My only expenses have been services, gas, and tires. Still on the original brake pads and rotors.
Old 10-20-2009, 02:07 AM
  #104
neyugnj's Avatar
2003 E320
just passed 72k here.
Old 10-21-2009, 12:26 AM
  #105
lboudreau's Avatar
2019 C63S
1. 2008 E300 4M
2. 40,000
3. Rotors and regular maintenance. Solid car!
Old 10-22-2009, 06:18 PM
  #106
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
2006 E55 78K miles
so far so good (own it for 4 months now)
Might need to do E service in 900 miles.
Also might need to change engine mount because of small vibration
Old 11-21-2009, 12:36 AM
  #107
jefe95's Avatar
2003 W211
Smile
2003 E320
78000
Battery and ECM at 40k;Front bushings at 50k
Old 11-21-2009, 03:16 AM
  #108
rmeneses's Avatar
07 E350
Mileage...
2007 E350 (non Sport)
28940 + miles
No problems (knock on wood)
due for "C" service in about 1000 miles
pulsating brakes (I think warped rotors)
current factory warranty + 2 years CPO
Brakes Squeak every now and then
Smells like Roses when I turn on the A/C (annoying)
QUIET AND SMOOTH! A big improvement over the 02 E320
that was totalled.
Old 11-22-2009, 08:23 PM
  #109
Tricky's 55's Avatar
2006 CLS 55
05, e500 4matic
30,000 miles
good so far, knock on wood.
Old 11-22-2009, 10:32 PM
  #110
Rennlaufer's Avatar
2005 E500 Sport
1) 2005 E500
2) 40,580
3) Rear airmatic shocks replaced at 32K, Motor mounts at 38K - all under warrenty - CPO care with extended Starmark contranct!!!!! I love my MB !!!
Old 11-22-2009, 10:45 PM
  #111
Benz-O-Rama's Avatar
I'm sure I'm already in this thread, but I now sit at 92,000 and no warranty since the 48K mile one expired. Car was a MB buyback, which I purchased at 28K miles, and has performed brilliantly other than the common W211 niggles.
Although, my keyless-go has been flaky recently.
Old 12-04-2009, 03:38 PM
  #112
ohthelawd's Avatar
2006 E350
2006 E350
41500 miles
No problems until a couple of weeks ago... have to change the upper idler pulley this weekend.
Old 12-04-2009, 05:38 PM
  #113
weinschela's Avatar
'14 E350 wagon; BMW G12 (2020) G01 (2019)
2004 E320 4m wagon 53,000 mi (no major issues)
2008 E550 24,000 mi (no major issues)(my daily driver)
2009 E350 4m wagon 3000 mi (no issues)(wife's)
Old 12-05-2009, 07:44 PM
  #114
locomercedes's Avatar
2007 CLS550 Designo; 2009 Mini Cooper; 2011 BMW 335d
2004 E500
70,000 miles, no warranty since 48k.
One front air strut, two front parktronic sensors. Other than that solid.
Old 12-07-2009, 01:50 PM
  #115
wustywaste's Avatar
2003 E320 sedan
2003 E320 (2nd owner)
7300 miles
Ball Joints and arm,($700 local shop.) (dealearship quoted $1500.00)
Pulling into a parking lot makes whistles from the right side.. not fixed yet.
Replace left low beam (dealearship quote $280) bought bulb for $10 for a pair and my buddy and i figured out how to put it in.. took 30 mins..
Now the right side is out.. buddy is out of country.. i might just wait till i get pulled over..
Licence plate bulb blown.
Ac/heater squeaks from Vent.
Keys only rolls down/up windows occassionally.
Schedule C maintenance is around the corner. prob feb or march.
Wusty
Old 12-07-2009, 01:54 PM
  #116
wustywaste's Avatar
2003 E320 sedan
oh one more problem. Moon roof will not shut automatically.. i have to hold the close down all the way to close.
Old 12-07-2009, 05:09 PM
  #117
CharlyE500's Avatar
7300 miles
Wusty
I have hard time with the squeaks sound..... this drives me crazy !!!
Old 12-07-2009, 08:09 PM
  #118
LaicepsYdobon's Avatar
2011 E350 Sport 4Matic - P2 & Drivers Assist / 2010 C300 Sport 4Matic - P2 / 2013 Porsche Cayenne S
I had that once on a previous car. I thought the sunroof opening/closing mechanism was broken but it turned out that it was just out of sync. My SA showed me how to re-sync it by hand and I didn't have to bother him that one more time it happened. Do you know how to do that ?
Old 12-07-2009, 08:14 PM
  #119
Should be a quick fix; they just need to replace the fan because most probably the bearing is faulty inside it and its making that squeaking noise.
Old 12-12-2009, 07:23 AM
  #120
You need to resync the windows. Check the manual.
Old 12-12-2009, 11:55 AM
  #121
Bennett S's Avatar
95 E-320
21,400 miles on my 07 e350.
Old 12-23-2009, 10:56 AM
  #122
Davel's Avatar
03 Eclass, 03 BMW 06 Porsche Cayman S, 03 Harley Davidson "bored & stroked"
Purchased new, 03 with 57K miles, car has been very reliable and the best MB i've owned out of 3, no problems with the other 2, just that the E does everything better. So far replaced:
tranny mount
heater control valve
CD (6 disc) player
Just had first brake change at 55K miles, 1 year left on MB extended warranty
Old 12-23-2009, 08:15 PM
  #123
vettdvr's Avatar
03 E500 and Corvette
Originally Posted by ohthelawd
2006 E350
41500 miles
That is a $20 part and easy to change. Wife and I changed ours in about 20 minutes. Normal failure due to small pulley size causing the pulley to turn faster rpm than other larger pulleys. Just watch it and change it when needed. Minor thing.
Old 12-29-2009, 10:07 PM
  #124
Cocoa Tom's Avatar
2004 E320 Wagon
2004 E320 Wagon
58,600
AC compressor bearing
Old 01-04-2010, 04:57 PM
  #125
Vrrooom's Avatar
2005 E500
Originally Posted by Rennlaufer
1) 2005 E500
2) 40,580
Sounds just like me.
2005 E500
46k miles
rear airmatic shocks replaced, solid car though
Quick Reply: How many miles on your W211?
