E-Class (W211) 2003-2009
How many miles on your W211?
Old 07-15-2021, 05:44 AM
  #751
TexE350's Avatar
2008 Mercedes E350 4MATIC
2008 E350 4MATIC
130,000 Miles
only issue is the owner before me decided to straight pipe it by removing the mufflers but now I hear the rattle of two pipes every time I idle. Thought it was something way worse but looking into ways to fix it so the pipe is in the secure. Other than that no issues mechanically…cosmetically however…she’s see seen better days but I hope to restore it a bit
Old 09-13-2021, 10:12 PM
  #752
Doctor Who's Avatar
W211 E320 Wagon
2004 e320 third owner at 174.8k already at 175.6k. Bought on 8/27/2021
Did mostly maintenance.
Old 09-15-2021, 08:25 AM
  #753
juanmor40's Avatar
Received 1,566 Likes on 983 Posts
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
Originally Posted by SkidVicious
'08 E350 4Matic
138K
Owned less than a week, with a little digging I can find extensive previous work, in the last few years nothing major, two front wheel bearings and maintenance.
Cosmetically it's very nice in and out, the engine seems to run well and is running better after some "Italian Tuneup" type driving, it was driven almost exclusively on parkways
and freeways to work and back by an older Australian gent who retired and moved back. I never saw him drive but can sense from his dress and manner that the care was driven
very carefully, to the point that a few hard accelerations and letting it wind up through the gears and it seems to have smoothed out a little and gotten more responsive.
Mechanically, the front brakes have life in them, there is a pretty good lip on the rotor and they just don't feel that great, so redoing all corners and a flush is high up the list, right after
changing all the drivetrain fluids. It's a nice car, I was shopping in a much higher price range than the $5700 I paid, that leaves me a lot of room for parts and maintenance.
If in the "extensive previous work," you do not see "oil separator, or crankcase ventilation breather/valve/PCV" nor "intake manifold", you should check your PCV valve/hose to be certain is working correctly. Otherwise, oil will end up in the intake manifold, and it will finally give up breaking either an external plastic actuator or an internal part in the manifold. Preventative maintenance will save you some $$ down the road.
CaliBenzDriver (09-19-2021)
Old 09-23-2021, 09:36 PM
  #754
777AEN's Avatar
E550
2007 e550 sport package ( with a stage 1 tune) Xpipe, muffler delete , amg wheels
125k miles
currently is getting valve body-replaced , should get it by tomorrow for a whopping 3k. recently changed oil cooler, water pump , thermostat housing pulleys and belt .
despite the bill it’s amazing to drive and the power is almost on par with amg as it is .
Old 09-28-2021, 11:56 AM
  #755
no-luv-frome350's Avatar
2009 e350
2009 w211 e350
1) 2009 E350
2) 160,211 miles
3) long list-
engine/transmission mounts
transmission speed sensor
upper/lower control arms
ball joints
steering control arms
replacement key fobs
brakes front/back
replaced headlamps
belt, tensioner, idler pulley, belt kit
thermostat
front steering cross member
variable intake manifold cam control arm
power steering pump
replacement fuel tank/pump assembly
A/C fan blower and fan module
Old 10-04-2021, 10:54 PM
  #756
AIKID's Avatar
E350 4matic
1) 08 E350 4matic sport
2) 71960mi
3) small problems
Old 10-06-2021, 12:25 PM
  #757
Smaug6's Avatar
05 E320 CDI
2005 E320 CDI
2005 E320 CDI
219000 miles 2nd owner had since 203,000 miles.
New ECU, EGR, Radiator, Brakes, SBC (under warranty $0 yay), tires, mounts, replaced injector seals #2 had started black death, oil, filters etc...
I love this car!!
Small problem now it is slow to crank overnight unless I prime it to start first. Fuel pump in tank is a little weak. Anyone just replaced the motor in the sending unit?
Old 10-07-2021, 08:34 PM
  #758
That_E35's Avatar
W211 E350
2006 E350 4MATIC
186,648 Miles, I am the third owner
P2006 Intake runner code, previously, the front left axle boot tore, the sunroof binding recall, and now the SOS system speaker is buzzing and I have an SOS malfunction notice
Old 10-19-2021, 04:51 AM
  #759
Diablo_CLS55's Avatar
2006 CLS55 AMG
153k miles and and counting on my 2007 E550…
Alternator, Conductor plate, serpentine belt, Front right airmatic strut, Battery, have all been replaced in my ownership. $4000 in repairs alone spent on this car since I bought it 30k miles ago. Daily driven every day 20 miles to and from work. Its broken down but It’s never left me stranded. Except when my alternator and voltage regulator both decided to die and I was stuck at work until 1am waiting for a tow truck… luckily this didn’t happen on the road. I love this car
Old 10-19-2021, 04:56 AM
  #760
2006 CLS55 AMG
125k miles
Badass looking E550 you got there. I have a black 2007 E550 as well with mufflers and resonator delete.
Old 04-09-2022, 06:42 PM
  #761
MilosCovaci's Avatar
2007 Mercedes E320 Bluetec, 2011 Mercedes E350 Wagon
2007 E320 Bluetec
105k miles
No issues, just maintenance
Old 04-10-2022, 11:59 AM
  #762
dvenneman's Avatar
E350 4matic Wagon
Originally Posted by alexsynn
Let's see who has the most miles, and how many averages miles are on our W211s.
Create a list like this:
1) Year and Model
2) Mileage
3) Any mechanical problems
I'll start:
1) 2006 E350
2) 39,452 miles
3) None
1) 2007 E350 4matic wagon
2) 247,700
3) currently redoing valve cover seals - I don’t consider this a mechanical problem; expected maintenance for age
Quick Reply: How many miles on your W211?
