In case you missed all of the recalls and SB's
http://www.alldata.com/TSB/0335_mo.html
I was looking through the E500 list and was very concerned with some of the SB's. Oil sludge, cyclinder wall assessment, etc.
TSB Number Issue Date TSB Title
1. 2003120006 JAN 04 Recall - Seat Belt Buckle Replacement
2. 2003080003 AUG 03 Recall - Steering Coupler Pinch Bolt Torque
General Recalls
1. 2003010009 MAR 04 Campaign - Wheelhouse Water Drain Modification
2. 2003020003 JUN 03 Campaign - Front Door Module Replacement
3. 2002090005 DEC 02 Campaign - Instrument Cluster Module Flashing
Service Bulletins
1. P-27_00-40A APR 04 A/T - Shift Concerns/No Codes Set
2. P-82_10-343A APR 04 Lighting - Fog Lamp Beam Screen Cap Loose
3. P-82_10-344 APR 04 Lighting - Left/Right Brake Lamp Brightness Difference
4. P-54_00-71C APR 04 SRS - MIL ON/Multiple DTC's Found
5. P-67_29-10 APR 04 A/C - Rear Window Won't Heat in the Upper Area
6. P-82_70-346 APR 04 Cellular Phone - V60s Phone Locks Up
7. P-82_60-259A APR 04 BCM - P9386 Control Module Diagnosis Stored in DAS
8. P-82_85-325B APR 04 Audio - Intermittently Not Functioning
9. P-46_20-16 APR 04 Steering - Leaks at Line/Rack Housing Connection
10. P-42_46-38 APR 04 Brakes - Software Patch Necessary Before Bleeding
System
11. P-82_95-322A APR 04 Communications - 'Tele Aid Not Active' Displayed
12. P-82_85-322 APR 04 Navigation System - Installation
13. P-82_20-336 MAR 04 Interior - Sliding Roof Switch Cover Cracks
14. P-82_70-338 MAR 04 Cellular Phone - Poor Hands Free Usage Quality
15. P-82_85-332 MAR 04 Navigation System - Slow to Start Upon DVD Insertion
16. P-42_10-33B MAR 04 Brakes - Front Brakes Shudder
17. P-42_20-35 MAR 04 Parktronic System(R) - Intermittently Inoperative
18. P-46_10-15 MAR 04 Interior - Steering Wheel Heater Inoperative
19. S-07_61-039A MAR 04 Engine Controls - DTC Trouble Shooting
20. P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
21. P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
22. P-54_18-108 FEB 04 Starting System - Engine Does Not Start
23. P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
24. P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
25. P-82_85-301 FEB 04 Navigation System - DTC D300 Explanation
26. S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assessment
27. S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
28. P-42_46-32A JAN 04 Brakes - Whistling Noise When Depressing Brake Pedal
29. P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
30. P-54_21-89B JAN 04 Charging System - 'Battery: Visit Workshop' Message
31. P-54_65-104A JAN 04 Parking Assist System - Triggers for No Reason
32. P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
33. P-54_10-106 DEC 03 Battery/Charging - Error Message Displayed/DTC's Set
34. P-42_46-27C DEC 03 Brakes - Buzzing Noise During SBC Pressure Build-up
35. P-82_30-316 DEC 03 Wipers/Washers - Erratic Intermittent Wipe Explanation
36. P-82_10-258A DEC 03 Lighting - Front Turn Signal Lamps Inoperative
37. S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
38. P-82_95-295 OCT 03 Communication Platform - Mobile Identification Number
39. P-82_62-226A OCT 03 Audio System - Intermittent Loss of Audio
40. S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
41. P-88_50-33 SEP 03 Body - Trunk Lid Springs Back When Opened
42. P-18_20-22 SEP 03 Engine - New Oil Filter Requirements
43. P-54_18-98 SEP 03 Battery - Disconnecting Requirements During Vehicle Svc.
44. P-82_10-255 AUG 03 Lighting - Premature Headlamp Bulb Failure
45. P-88_50-32 AUG 03 Body - Water Drips Into trunk With Trunk Lid Open
46. P-61_10-02 AUG 03 Body - Water leaks Into Trunk
47. P-18_00-22 AUG 03 Engine - Oil Fill Capacity Correction
48. P-54_10-90 AUG 03 Battery - Diagnostic Troubleshooting procedure
49. P-82_00-260 JUL 03 Audio System - Dual Sided CD's Won't Eject
50. P-82_95-273 JUL 03 Communications Platform - DTC D640 Set
51. P-82_95-274 JUL 03 Communications Platform - DTC D662 Set
52. P-07_07-34 JUL 03 Engine Controls - MIL ON/Multiple DTC's Set
53. P-82_10-269A JUL 03 High Mount Stop Lamp - Water Leaks Into Trunk
54. P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
55. P-82_95-251A JUL 03 TeleAid(R) System - 'TeleAid Defective' Displayed
56. P-07_00-21F JUL 03 Engine - Piston Slap Sound on Acceleration
57. P-82_95-267 JUL 03 Cell Phone - Erroneous Hands Free Fault Code
58. P-14_30-15 JUL 03 Emissions - MIL ON/DTC P2003 Stored in Memory
59. P-82_10-257 JUN 03 Lighting - Headlamp Bulbs Inoperative
60. P-82_95-235A JUN 03 Communications Platform - Replacement Instructions
61. P-82_30-254 JUN 03 Wipers/Washers - Wiper Blades Noisy
62. P-82_95-250 MAY 03 TeleAid(R) System - No Audio Mute When Button is Pressed
63. P-82_70-248 MAY 03 Cellular Phone - 'No Service' Displayed
64. P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
65. P-91_60-57A MAY 03 SRS System - Control Module Service Precautions
66. P-82_95-242 APR 03 Communications Platform - DTC D003 Explanation
67. P-91_40-59 APR 03 Interior - Seat Belt Buckle Pinging Noise Upon Buckling
68. P-91_60-58 APR 03 SRS System - Post Collision Impact Sensor Replacement
69. P-54_65-86 APR 03 Parking Assist System - Apparent Erroneous Activation
70. P-62_00-03B APR 03 Electrical System - Various Malfunctions
71. P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
72. P-32_22-15 MAR 03 Air Suspension - Low Ride Height in Cold Temperatures
73. P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
74. P-54_18-84 MAR 03 Battery - Disconnecting During Service
75. S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
76. P-82_60-227 FEB 03 Audio System - Static Noise With Rear Defroster ON
77. P-80_57-20 FEB 03 Audio System - RF Interference Explanation
78. P-46_20-10 FEB 03 Steering Rack - Connector Leaks
79. P-77_20-19 FEB 03 Moonroof - Intermittent Synchronization Loss
80. P-54_21-80 JAN 03 Electrical - Rear Fuse Panel Cover Difficult to Remove
81. P-54_15-79 JAN 03 Electrical - Wheel Well Fuse Box Loose
82. P-82_10-218 JAN 03 Lighting - Dust/Debris Inside Tail lamps
83. P-54_10-78 JAN 03 Electrical - Automatic Switching ON/OFF Explanation
84. P-82_60-214 DEC 02 Audio System - No/Poor FM Reception
85. P-83_55-65 DEC 02 A/C - Compressor Cycles Frequently
86. P-80_61-17 NOV 02 Keyless Go System(R) - System Initialization
87. P-54_21-74 NOV 02 Engine Controls - ECM Programming Procedure
88. P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
89. P-72_10-28 OCT 02 Power Locks - Lock Knob Jumps Up and Down
90. P-82_95-206 OCT 02 Communications Platform -Tele Aid DTC Codes
91. S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
92. P-00_20-74 AUG 02 Maintenance - Flexible Service System Plus(R)
93. P-18_00-17A JUL 02 Engine - Approved Engine Oils
94. S-07_08-001 JUL 02 Engine Controls - Software Calibration Number Coding
General Recalls
Service Bulletins
System
2004 E500 / 2001 C240
Thank you for posting this list. It is a great list. I have seen it before but not so up to date. What is great about your list is you list the TSB #.
Thanks.
Thanks.
Here is the list I got fixed so far:
2013 GL550
i8hotdogs - What was the fix for the fog lamp screen thing? I assume you are talking about the small bottle cap size thing that sits right in front of the fog lamp bulb? One of mine has falled off and is laying the bottom of the lamp. Did they replace the entire housing? Thanks!
This is good, not bad
BMcD-E500 - Yes, it is that bottle cap looking thing. I noticed one mine fell off while I was drying my car. I took back to the dealer and they did have to replace the whole thing. A few weeks later, the other side popped off too. Both sides have been replaced.
2013 GL550
Thanks for the update. My car goes in tomorrow for a oil change and to fix the fogs. That's the only thing to go wrong with the car in the past 16,000 miles. 26,000 miles and counting!
#1 on your list I had done- fixed the cap but came back(popped off again)
#2 will be going back for the third time(seems to cut out only blasting it in the summer)
#3 never noticed lack of power but of course my first engine seized driving in the rain(flood the engine, service advicer said it's common for the e class. Atleast one comes in each summer! Bad intake design.)
#4 never touch it being two years old(almost), time to replace anyways.
#5 new engine
#6 same as #4
out of all those the stereo really ticks me off
2003 W211
Does anyone know what the fix is to these:
I have had a number of the other issues which have been resolved by the dealer.
Me:04 E320 Pewter:Wife:04 E320 White
E320 Recall Details
I have an 2004 E320 that has poor acceleration and hesitiation during downshifts...this bulletin seems like it might apply to me...where can I find the details about what this bulletin is about? Can someone post it?
Thanks to everyone...
2000 528BMW 5sp
give me a break more than 50 TSb. perfect
Originally Posted by MadManAboutTown
Show me a car that is perfect, and I'll tell you who the perfect Presidential candidate is!
2003 E500
With regard to the steering wheel heater: mine doesn't work, either. Since this is not that big a deal, I waited until my first service appointment to ask the dealer about it. Unfortunately, at that point it was too warm for the dealer to get the heater to turn on; they told me they can only diagnose problems with the heater when it is cold out.
Received 4,446 Likes
'71 Pinto
Originally Posted by MB4Fun
I have an 2004 E320 that has poor acceleration and hesitiation during downshifts...this bulletin seems like it might apply to me...where can I find the details about what this bulletin is about? Can someone post it? Thanks to everyone... P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
'71 Pinto
Originally Posted by RichardM
Does anyone know what the fix is to these: P-67_29-10, P-42_46-27C, P-88_50-32, P-82_30-254
