Bulletins 207 coupe & 212 sedan
Rating: Thread Rating: 9 votes, 5.00 average.
Old 04-15-2012, 12:29 PM
  #76
Yosheego's Avatar
2011 E550
you see where it pops out? where the rear lamp and bump part meet? it doesn't look flushed in.
Old 04-15-2012, 08:27 PM
  #77
BM2BZ's Avatar
w212 E550
yes, i can see it pops out a bit but just not sure where is it exactly. is it your left tail light? the light from your pic looks more vertical than horizontal and it looks more like the tail light from a cadillac srx suv. that's why i'm kind of confused.
Old 04-15-2012, 10:47 PM
  #78
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
Yosheego, your wood console looks good to me. In fact, all the cars I saw at the dealer lot last had the same color and the sides were a little lighter on all the E sedans I saw; My dealer told me the expansion was normal too!
Old 04-16-2012, 06:15 PM
  #79
golfster's Avatar
Titleist
Originally Posted by K-A
What's your cars build date?
09/10 build as MY2011. The fading for me seems to be limited to the trim piece above the glove box, and not even across as it is more faded towards the AC vent on the right than on the left.
My car is garaged at home, but is parked outside in my spot at work, with a mixture of sun and shade. Of course, when I golf, it is outside in the sun for 5 hours or so at a time, as is the case when normally out and about.
Old 05-03-2012, 03:16 PM
  #80
konigstiger's Avatar
Received 4,417 Likes on 3,146 Posts
'71 Pinto
LI88.30-P-053562 APR12 – wheel well liners in engine compartment heavily soiled. Vehicle with air and steel suspension have the same size liner opening the diameter of the steel spring is smaller allowing more dirt to enter. Dirt repellent foam will be fitted.
LI72.10-P-053587 APR12 – 212 as of VIN A444532 up to A487761 rattling noise from front door lock (left & right), insulate door module.
LI91.40-P-053536 APR12 – 212 & 218 (CLS) production 9/11 up to 1/12, right or left front seat belt does not roll up completely - reposition tensioning retractor and torque mounting bolts.
LI46.35-P-053719 MAY12 – 218 only “Power Steering Malfunction, Service Required” fault message on engine start, perform software update.
Old 05-09-2012, 01:08 AM
  #81
SoCalCLK's Avatar
2017 W205 C43 AMG
Subscribed. Konigstiger, you are the man!
Old 06-04-2012, 12:41 PM
  #82
'71 Pinto
LI20.40-P-053718 MAY12– 203, 164, 251, 204, 207, 212, 219, 216, 221 and 218 radiator fan starts although ignition has been off for longer than 30 minutes and/or fan changes to limp mode (runs @ 100%) while driving with display “cooling system” in instrument cluster and/or battery discharged, replace radiator fan. Only Brose/Temic fan, following part #s are affected 2215000993, 2215001093, 2215001193; 1645000493, 16450005693; 2035001693, 2035001494; 2045000293, 2045000493.
Old 06-05-2012, 11:45 AM
  #83
El Cid's Avatar
2010 E350 Luxury Sedan, Engine 272 (V6)
Model Years?
Thanks for keeping up informed, but what model years are involved in this?
Old 06-05-2012, 12:37 PM
  #84
'71 Pinto
MY not specified, your vehicle (VIN) is equipped with 2045000293 - check your email.
Old 06-06-2012, 11:06 AM
  #85
El Cid's Avatar
Thank You!
Thanks once again for your service.
Old 07-02-2012, 02:44 PM
  #86
'71 Pinto
LI88.50-P-053768 JUN12 – 207, 212 and 204 without AMG package, edges of the rear spoiler accessory protrudes at sides - incorrect installation, spoiler will be replaced (re-gluing is not permissible).
LI82.85-P-053927 JUN12 – COMAND display “Metadata loss – Please reimport all media data”, update COMAND software (Telematics CD 05/2012).
Attached Thumbnails Bulletins 207 coupe & 212 sedan-053768.jpg   Bulletins 207 coupe & 212 sedan-053927.jpg
Old 07-04-2012, 03:39 PM
  #87
boater07's Avatar
2012 E 350
Subscribe
Your posts are very helpful. Just bought E350 VIN A643834.
You appear to be able to track bulletins applying to specific cars.
What is the best way to track your info?? I assume regular readings.
Ted
Old 07-11-2012, 02:57 AM
  #88
LFTW8S's Avatar
2010 E350
Subscribed
Old 08-02-2012, 02:19 PM
  #89
'71 Pinto
LI54.10-P-054089 JUL12 – 204, 207 and 212 battery discharged vehicle does not start, rotary light switch sending wrong signal after ignition off (i.e.: power consumption by low beams) switch will be replaced.
Old 09-05-2012, 04:57 PM
  #90
'71 Pinto
LI82.85-P-053600 AUG12– 212, 207, 218 COMAND unit starts up then switches itself off after a short time when CDs/DVDs are loaded. Update COMAND software.
LI42.10-P-054524 SEPT12 – 212.072/090/272 front brake vibration. Thickness fault on brake disk replace pads and disks.
LI82.85-P-051046 SEPT12 – 212 up to VIN 1A329706 & 207 to 1F085904 reversing camera intermittently has no picture; next/previous track function inoperative, perform COMAND software update.
LI82.70-P-054226 SEPT12 – 212, 207, 218 NTG4 mobile phone driver poorly understood & background noise audible during call, perform COMAND software update.
Old 09-06-2012, 01:00 PM
  #91
tutooo's Avatar
2010 E350 4Matic Sport
I recently purchased a 2010 and noticed the issue with the reverse camera. Having all of this information is extremely valuable before heading to the dealer for service.
THANK YOU!
Old 10-04-2012, 05:11 PM
  #92
'71 Pinto
Service Campaign 2012070002 SEPT12
Models 164, 171, 203, 204, 207, 209, 211, 212, 216, 219, 221, 230, 251, 463 Engines 272 and 273, MY 2005 – 2011 Camshaft Adjustment Solenoids - due to the settling properties of the seal, oil may leak from the camshaft adjustment solenoid dealers will retrofit four adapter harnesses onto the engine wiring harness. Covers any/all repairs due to damage from oil leak however, claims replacement of leaking camshaft solenoid is not permitted under consequential damage. Approximately 557,108 vehicles are affected - have dealer check VMI to determine if vehicle is included.
LI46.10-P-054502 – 204, 212, 218 scraping noises when steering the steering boot heat shield with aluminum ring may have loosened and is scraping on the steering shaft.
LI54.35-P-053444 – 204, 212, 218 Sindelfingen production up to December 2011, horns too quiet, inoperative or have poor sound flat plug on horn may have broken off, replace horn.
LI91.30-P-054637 – 212 up to VIN A362355 with seat heater, cable channel of seat heater visibly protruding and able to be felt replace heat mat with modified heating element routing.
LI47.20-P-054504 – 212, 207, 218, 204, 221, 246, 251, 164, 166 with diesel engine ( 642 & 651) complaints of running characteristics (cutting, hesitation) due to possible fuel delivery issues if the voltage or current test values deviate from specified values, the fuel pump must be replaced.
LI82.85-P-054716 – 204, 207, 212 with NTG4 Intermittently no audio from any source on startup satellite radio selection displays “Device Unavailable” backdate the SDAR’s software.
Old 10-05-2012, 11:16 AM
  #93
El Cid's Avatar
Thanbks for info.
"The Best or Nothing"? Yet more reasons why DAG fails to offer a warranty as good as that of Hyundai and Kia.
Old 11-05-2012, 03:01 PM
  #94
'71 Pinto
LI03.10-P-054702 Models with 276 engine-knock noises in crank assembly, repair requires the replacement of all connecting rods & pistons with wrist pins assembly.
LI15.12-P-054772 Models 212.074/274 (E63), 166.074/874, 172.475, 216.374, 218.374/974, 221.074/174, 231.474, 463.272/273 oil level query in IC not possible or oil temperature does not display in AMG menu – if ignition coils with part # 2769060160 are installed, replace all coils.
LI49.00-P-054888 Models 212/166/207/216/218/221 with 278 engine - warning + fault code P262600 or P262900 stored in ECU relating to oxygen sensor upstream of catalytic converter, replace left & right oxygen sensors and update ECU software if needed.
Old 11-08-2012, 09:37 AM
  #95
El Cid's Avatar
Which engine
How do I determine which engine I have?
Thanks for keeping us posted.
Old 11-08-2012, 10:29 AM
  #96
'71 Pinto
Check your datacard you have "272"980 .. ......
272 = 350 / 273 = 550 / 642 = BT
MY12 > 276 = 350 / 278 = 550
Old 11-08-2012, 10:47 AM
  #97
El Cid's Avatar
Thank You!!!
Thanks. I've made a note of this information.
Old 12-07-2012, 04:57 PM
  #98
'71 Pinto
Recall 2012110003 – MY12 218 bolts securing the striker for the engine hood latch tightened with reduced torque in subject vehicles. Approximately 23 vehicles affected.
Service Campaign 2012100005 – MY12 x164, 212, 221, 251 Selective Catalytic Reduction (SCR) control module software may not meet specifications. Update will optimize cold starting issues. Approximately 9,872 vehicles affected.
LI72.10-P-055044 – 207 up to VIN F174511 inside door handle inoperative, replace Bowden cable & clip.
LI91.30-P-054637 – 212 with seat heater (873) up to VIN A703331 lump under seat cushion cover, install modified heat mat.
LI68.30-P-053962 – 212 with burred walnut veneer wood finish (731) or burred walnut veneer designo brown (w60) UV can cause fading trim will be replaced, August 2011 clean point.
Old 12-08-2012, 11:51 AM
  #99
El Cid's Avatar
Burled wood trim?
LI68.30-P-053962 – 212 with burred walnut veneer wood finish (731) or burred walnut veneer designo brown (w60) UV can cause fading trim will be replaced, August 2011 clean point.[/QUOTE]
Is this different from TSB LI68.10-P-050415?
How can you tell if you have this situation?
Thanks once again for all you help.
Old 12-08-2012, 05:16 PM
  #100
'71 Pinto
LI68.30-P-053962Is this different from TSB LI68.10-P-050415?
Yes, not certain why they issued another bulletin rather than revision but looks like they added designo trim and clean point 8/11 validation (claim vehicles produced 8/11 > are equipped with modified trim).
LI91.30-P-054637 How can you tell if you have this situation?
This bulletin applies to your vehicle – within VIN range & datacard includes 873 (seat heater for left/ right front seats) have dealer check it.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
Quick Reply: Bulletins 207 coupe & 212 sedan
