Bulletins 207 coupe & 212 sedan
Rating: Thread Rating: 9 votes, 5.00 average.
Old 12-09-2012, 12:39 AM
  #101
BM2BZ's Avatar
w212 E550
Originally Posted by El Cid
LI91.30-P-054637 – 212 with seat heater (873) up to VIN A703331 lump under seat cushion cover, install modified heat mat.
How can you tell if you have this situation?
i have the same question, too . i do see a "lump" on each of the front seats but not sure what that is .
Old 12-09-2012, 10:55 AM
  #102
konigstiger's Avatar
Received 4,435 Likes on 3,152 Posts
'71 Pinto
If there is a visual lump, vehicle is equipped (873), and within VIN range have dealer check it.
Old 12-09-2012, 11:48 AM
  #103
El Cid's Avatar
2010 E350 Luxury Sedan, Engine 272 (V6)
Thanks again - and Happy Holidays!
Old 12-09-2012, 04:05 PM
  #104
BM2BZ's Avatar
w212 E550
roger that, konigstiger ! thanks again for all your helps !
Old 01-04-2013, 04:09 PM
  #105
'71 Pinto
S-B-42.15/122 DEC12 Brake disks treated with Zinc Dust Spray Paint, re-spraying friction rings (outside & inside surfaces) with zinc paint is essential in protecting from corrosion, shuddering, and squeaking: all model years; 163,164,166, 170, 171, 172, 197, 202, 203, 204, 207, 208, 209, 210, 211, 212, 215, 216, 218, 219, 220, 221, 230,231, 245, 251, 463.
LI07.08-P-055310 Engine intermittently shuts off immediately after starting but does not shut off again on a restart. When started may exhibit rough idle for a few seconds. Symptom more common on restarts after short trips and relatively short engine off periods (10-60 minutes). ECU software update (version VC12.0.1) will be available mid February.
LI72.40-P-055045 Various function failures in front door; automatic window raising not possible / power window cannot be normalized (reset) / malfunction of central locking / illumination faulty – attempt door control unit reset by unplugging connector for about 20 seconds if unsuccessful replace DCU.
Old 01-19-2013, 12:09 PM
  #106
aeroconfigs's Avatar
w212
new member here, first post
I bought a 2010 350 last May. Thank you so much for this post. It has helped give me justification for requesting warranty claims with my dealership. They like to assume it is nothing wrong, or something that I was doing.
I took it in yesterday because of Bluetooth issues with calls, and also the streaming audio getting spotty after a few minutes. They updated the firmware but I don't think it's the latest version. It has the updated nav bird's eye view with the clouds, but it doesn't show the fan speed or temperature when changing the climate control. I'll check the version later in the engineering menu and post up.
Also, I asked them to check the wood trim because it looked like MatOhio's picture. (I am also from Ohio, go Browns and Bucks) They checked and said they didn't see a problem, so when I picked it up today I had to show them the LI and hold their hand while we went over to my car so that I could point it out. Then the guy saw it.
I'll be checking back with them on Monday, when the manager will be back. Is the firmware referenced in this comand 0009026706-001 the latest still?
Old 01-22-2013, 02:25 PM
  #107
mleskovar's Avatar
'17 Jaguar XF
Subscribed....although for some reason I'm not getting notified....which seems to be a recurring problem for me with this forum .
Old 02-01-2013, 04:26 PM
  #108
'71 Pinto
Service Campaign 2013010001 JAN13 – MY13 207,212, 218, 221, 231 with M278 engine left & right secondary chain tensioners installed at factory pressed too deep into cylinder head, dealer will remove check valve of tensioners. Approximately 167 vehicles affected.
Service Campaign 2012120003 JAN13 – MY12 218 Dealer will update ECM software, may not meet current specifications. Approximately 10 vehicles affected.
Service Campaign 201212004 JAN13 – MY12 212, 218 with M157 (AMG) engine dealer will update ECM SCN coding, injector coding may not meet current specifications. Approximately 24 vehicles affected.
LI46.35-P-055436 JAN13 – 204, 212, 207, 231 red display message “Power Steering Malfunction – See Owner’s Manual” immediately after engine start, steering assistance reduced; update software of electric power steering (ES) control unit.
LI77.00-P-055046 JAN13 – 204/216/218/GLK/221/205/213 with sunroof (without panoramic roof) moisture in the area of left or right A-pillar trim/headliner, replace water drain grommet.
LI82.60-P-055465 JAN13 – 164, 166, 169, 171, 176, 203.7, 204, 207, 209, 211, 212, 216, 219, 221, 230, 231, 231, 245, 246, 251 with Media Interface (code 518), 463 (EH3) iPod/iPhone music playback not possible; audible only on left/right side; iPod not charged – replace Media Interface connecting cable.
Old 02-17-2013, 06:26 PM
  #109
T100T's Avatar
2010 E550
What if car's out of warranty
Great thread, can someone educate me as to how the local MB dealer uses the information in these bulletins? Is it the case that they are obliged to check your car for the issues listed, or do they wait for the owner to see a problem and complain? Is there a record of what checks have been made or work done?
I'm asking because I'm about to pull the trigger on a 2010 E550 with over 50k miles, i.e. out of warranty. The car has been serviced by MB. I will go through the car looking for the issues in the list but wondered how best to proceed if there's a problem.
BTW the missing tab on the rear fender sounds expensive, didn't see any other threads related to it, maybe it'll take more time to become evident.
thanks,
Peter
Old 02-18-2013, 09:54 PM
  #110
OnlyGerman's Avatar
Too many german broads
thanks,
Peter
I also have the bumper issue, not sure if its just a tab or whole replacement.
Old 02-18-2013, 10:21 PM
  #111
mleskovar's Avatar
'17 Jaguar XF
...can someone educate me as to how the local MB dealer uses the information in these bulletins?.....
I believe when you take your car in for either normal or warranty maintenance the system/computer lets them know if a TSB is applicable from the build date or VIN.
.. Is there a record of what checks have been made or work done?...
Yes. My experience is MB is conscientious about applying technical updates.
Old 02-19-2013, 11:07 AM
  #112
'71 Pinto
DTB & LI bulletins are covered under warranty (initial factory, CPO, extended, etc.) pulled by tech normally only upon customer complaint. If they document a specific range (i.e.: VIN, serial #, etc.) and out of warranty request goodwill repair based on production defect from MB rep covering dealership via service manager.
Recalls & Service Campaigns are covered out of warranty - no time or mileage limitations.
Request Vehicle Master Inquiry (VMI) from dealer this is a history of all warranty, maintenance, at cost repairs, etc. performed by MB for your VIN.
Old 03-01-2013, 02:10 PM
  #113
'71 Pinto
Recall 2013020002 FEB13 – X204, 204, 207, 212, 216, 221 model years 2011-2012 due to issues during molding process of supplier operating pressure & high operating temperatures may result in fuel leakage. Dealer will replace fuel filter. Approximately 5,773 vehicles affected – owners of affected vehicles will receive a letter, or you can have dealer check VMI to see if vehicle is involved.
LI27.60-P-055362 FEB13 - 212, 221 with 722.9 transmission / OM642LS (diesel) engine - deceleration upshift from 4th to 5th gear may be uncomfortable under certain driving conditions, dealer will update software & reset adaptation.
LI42.10-P-0555595 FEB13 – 212.091 E550 4matic, 218.373 CLS550 & 218.391 CLS550 4matic grunting noise from front axle area during medium / hard braking (similar to allowing vehicle to creep slowly from a stationary position with brakes partially applied), replace front brake pads.
LI82.85-P-055695 FEB13 – 207, 212, 218, 166, 172, 176, 204, 246, 463 COMAND does not start, cannot be operated, display remains dark. Problem disappears after lengthy idle period or after interrupting the power supply. Update COMAND control unit software. The software will be available with Xentry 03/2013 and Telematics DVD 03/13 (A 166 827 11 59).
LI07.08-P-055310 MAR13 - 276 engine all models, 278 in model 166 shuts off immediately after starting. Symptom is common on restarts after short trips and/or short engine off periods (10-60 minutes) – no relevant fault codes. Software update is now available https://mbworld.org/forums/5492959-post105.html
Old 04-02-2013, 02:57 PM
  #114
'71 Pinto
Indication:
Old 04-02-2013, 03:12 PM
  #115
hyperion667's Avatar
Received 3,400 Likes on 2,845 Posts
2012 CLS63
Indication:
I do have some of that going on, on my drivers seat.......but I don't think I want the dealer pulling my seat apart
Old 04-02-2013, 03:14 PM
  #116
'71 Pinto
LI91.10-P-055704 MAR13 – Model 207 & 204.3 front seat trim protrudes - caused by mounting clip loosening under load, increase clip forces.
LI82.62-P-055715 MAR13 – Model 207.3 poor audio quality from all sources after amplifier software update, flash again.
LI72.00-P-055756 MAR13 – Model 212 & 218 door seal on front & rear door loose, replace doorframe seal.
Old 04-02-2013, 08:48 PM
  #117
Live Oak's Avatar
E550
Indication:
Thanks much, Konig!
Old 04-02-2013, 08:58 PM
  #118
Live Oak's Avatar
E550
I dunno. Maybe the issue suggests other potential failure of the heater or seat cover???? And who wants an electrical failure going on between your legs!? Not exactly the kind of lump you want there.
(Note that I resisted any comment about the dealer "pulling your seat apart" when you bought the car.)
Old 04-26-2013, 01:07 PM
  #119
OnlyGerman's Avatar
Dealer replaced rear bumper due to this issue on my 2010.
Thanks.
LI88.20-P-052891 - 212 rear bumper sticks out in area of rear lamp. Bumper experiences thermal expansion mounting rails (fender area) cannot sufficiently hold the bumper in place. If bumper is not equipped with additional latch, it should be replaced. Note since JAN11 bumpers are equipped with additional retaining tab.
Old 04-27-2013, 01:02 PM
  #120
mbuster25's Avatar
2010 E350 Luxury 4Matic
Thanks.
Would any one have a picture of what this looks like?
Old 04-28-2013, 02:13 AM
  #121
BM2BZ's Avatar
w212 E550
not sure if post #49's pic good enough .
Old 05-01-2013, 03:07 PM
  #122
El Cid's Avatar
Here we go again with issues related to COMAND!
Old 05-01-2013, 03:09 PM
  #123
2012 CLS63
oh no! Elcid is jacking konig's deal!
Old 05-02-2013, 08:50 AM
  #124
El Cid's Avatar
Cool Huh?
Not sure what the above means (Koning's deal?), but for clarification. My comment is reference to how often COMAND issues seem to come up and how complicated the "fixes" are. Even then the results seem to vary a lot as to success.
Old 05-02-2013, 04:03 PM
  #125
'71 Pinto
LI6805-P-055754 APR13 - Owner cannot program mirror from handheld transmitter Genie & Wayne Dalton door opener NOV 2010 or later (use Intellicode 2 encryption), transmitter is backwards compatible to mirror by changing to Intellicode1 - see 055754 attachment.
LI01.40-P-056159 APR13 – 172, 204, 207, 212 with engine 271.8 EVO oil loss in area of rear crankcase – transmission bell housing, check threads of transmission mounting, holes of cylinder head bolts 9 & 10, and replace sealing ring on engine temperature regulator.
LI77.21-P-051114 APR13 – 207.3 roller blind of panoramic roof is blocked, broken, fabric torn. Replace roller blind, check guide rails replace if necessary. Possible causes, antenna cable was incorrectly routed and/or sealant bead on frame at center rear protrudes too far causing blind to chafe.
LI91.18-P-049463 APR13 – 204, 207, 212 multicontour seat cushion becomes detached fastener clips will be installed reattaching cover exactly - see 049463 attachment.
LI72.00-P-055920 MAY13 – 212 up to VIN A663422 outside handle does not return to default position, replace bearing bracket.
LI88.50-P-053768 https://mbworld.org/forums/5265348-post86.html incorrect installation or misalignment (protrudes at sides) MAY13 revision, roof spoiler added.
Becker MAP PILOT (BMP) code 509 or preinstallation 508:
http://www.mbusa.com/mercedes/access...rtNo:BQ6829777
LI82.61-P-055955 APR13 – BMP navigation function boots only to Becker logo; display freezes; startup time takes a long time; displays responds with delay, update software to version 12/12.00 (1669027304), firmware to R22.3.1205 or higher, and “free of charge” navigation software to 2.0.50 or higher.
LI82.61-P-055979 APR13 – BMP navigation volume reduction is inoperative. Function operates in relation to volume setting. Check as follows: set music volume loud, during navigation announcement reduce volume, activate audio volume reduction setting and check. If a difference is heard in audio volume reduction during check, system if OK.
LI82.61-P-056044 APR13 – BMP house numbers not found when addresses are entered via Audio/COMAND controller, update software to 12/48.00 (1669021105), firmware to R26.3.0130 or higher, and “free of charge” navigation software to 2.5.26 or higher.
LI82.61-P-055954 APR13 – BMP “No navigation module connected” appears in display, update software to 12/21.00 and firmware to R22.3.1205 or higher. In addition, check tightening torque of threaded connection between bracket and glove box, and low voltage differential signal (LVDS) line @ radio.
File Type: pdf
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
Quick Reply: Bulletins 207 coupe & 212 sedan
