What's with gas filler door not latching??
#52
Mercedez Benz gas cap wont close.
This forum is the best, I created an account just so I could thank you guys. My gas latch wouldn't shut properly, I was going to take it to my dealer, but then I went on this forum. The gas cap has a cable attached to it, it moves freely from the 5 o'clock position to the 9 o'clock position. My latch wouldn't shut because it was in the 5 o'clock position, I just slid it over to the 9 o'clock position and it was like magic....CLOSED!!!
Pretty weak design, but now that I know what to look for, its an easy fix. Thanks guys.
#53
'15 E350 4M Sport
#54
#55
Filler Flap - Simple Fix
I have recently been having the same issue with the flap not locking. I read the thread and fixed it in 30 seconds saving me a trip to the garage.
Thanks for the help - saved me time and no doubt money.
#57
First was the WTF? the filler door's not closing? Quick check on the forum, one twist of the cord, works perfectly now.
Begs the original question of WTF? One twist in the cord and the door won't close properly? At least I am now forewarned for the future. I would have felt silly bringing this to the dealer for this issue.
CaliBenzDriver (03-14-2023)
#58
Once I was having trouble closing the fuel boor and Nothing i do could fix it. I was getting frustrated but realized that the car was accidentally locked . One would think that we should be able to close the fuel regardless.
#59
Gas filler door
The cord fix worked like a charm for me. I noticed that my filler door stopped closing properly & thought that something was really wrong until I found this thread!
#61
2013 E550 4Matic
Edit: Pics would help
#62
Like the cap itself, or the door? A "coil" malfunction sounds like maybe the "threads" on the tank are stripped, in which case you might have to bite the bullet and get it replaced. But if it's just a matter of the cap being stripped, you can replace it for like $30.
#63
Received 4,417 Likes
'71 Pinto
Here are the parts for tank flap. Dealer seems to be referring to elector (410 in diagram) if so part is less than $10.
#64
Mercedes fuel cover ajar
Thanks for all the input see above title. I have a 2011 E550 yesterday was the first time the fuel cover flap wont close. Its those little things that bug me i was on my way to the dealership tomorrow morning when i thought to check out the MB forum. The answer is there just havent implemented it yet its still very dark at 6:15am ET i will post after i try the suggestions posted here. Thanks guys & gals.
Frank
Frank
#67
My gas door didn't latch. I took it to the dealer, as I have the extended limited warranty only to find out that it wasn't covered.
I couldn't figure out why it wasn't covered, as my contract clearly says that only normal wear and tear isn't covered - but that is a different story.
The dealer said it would cost $450 to fix. Although they gave me the part number which was only $82. I refused.
Thanks to this forum members, I tried to see if it was the gas cap cord that prevented if from latching and... it was. I demonstrated how I "fixed" it to the service manager, and man, was his face red!
Basically I would have paid $450 for the thing that is not even broken.
Thanks everyone!
Thanks everyone!
#68
Awesome.
Thanks to Live Oak for starting this thread and telemakhos for first posting the correct answer.
This _never_ happened on my C class. When I bought my "new to me" E550, I couldn't get the door to close all the way. Yup, moving the cord "down" solved it for me too
#69
I had this happen about 3 weeks ago, thanks to this thread I got it closed at the time but it happened again.
Dealer replaced the latch mechanism under my MB ELW no questions asked.
#70
I need help with the gas door not closing and sticking out
2014 W212 Wagon. It is hanging out there almost fully open. It is not the cord. It seems where the fuel door connects to the body it's loose. Any idea how to access the door hinge on a wagon? I have it taped shut now And it looks terrible.
thanks for any help. Again it's not the cord position that wraps around the gas cap.
#71
'71 Pinto
#72
I had this problem in 2011 or so on an earlier W212. The information is from my response on 04/07/12, #2 in this thread.
With the door open look at about 7 or 8 o'clock there is a spring loaded piston covered with a rubber boot. It's about 5/8" in diameter with the boot. (#410 on the illustration) Push it in and release it until it sticks out. Close and push the gas filler door in the same area and see if it latches. It happened to me a couple of times when the car was a few months old and hasn't happened since.
You may have to repeat the pushing of the piston a few times before it works freely.
#73
Fixed the gas door issue, thanks Ned
Thanks again Ned!
eB
#74
#75
i have had my car for 8 yrs and out of blue my latch did the same thing,
the actuator was pushing in and out...but still couldnt get it closed..
two buddies of mine are mb techs and said it could be that and to try some silicon spray....still no go
purchased a new actuator and then decided to quickly check here, and read about the cable position
problem fixed...slid the door side down...how crazy, when its slid up it wont close....8 yrs..
thank goodnesspart its only 7 bucks but still gonna be returned
