Ordered Pedalbox...
2011 E350 4 Matic
Ordered Pedalbox...
Ordered pedalbox, similar functionality as the sprintbooster but with more options to customize your settings.
Unfortunately the website was not correct and I received the wrong item (assuming it was for E350 pre 2010), the connector we have is the same as the W204's so I placed an order for that one while dealing with the return.
Can't wait to get rid of the lag.
The lag is horrible! You will really enjoy your ride a lot better after you receive the correct version.
2011 E350 4 Matic
I had the 1st Gen of the SB (without the 3 setting option) and was only ok with its performance, I always felt that the car adapted itself after a while.
The pedal box features:
-3rd Generation Technology;
-Increased, precise, throttle response, faster!;
-Eliminates throttle response delays;
-Car responds in approximately half the time at low rpm;
-Acceleration delay in third and fourth gear equal zero;
-Maintains power throughout the entire gear change cycle;
-Easier Overtaking in all gears;
-Plug-n-Play less than 15 minute install;
-Improved fuel consumption in Eco Mode;
-Reliable EMC (Electro Magnetic Compatibility) cover over the housing;
-TÜV approved, German Autobahn Certified;
-Three modes with six levels of customization, 18 levels in all,
each for, on the fly, throttle MAP (Mass Air Pressure) switching;
2011 E350 4 Matic
Compared to the SB pricing this is a good deal $265: http://www.twmperformance.com/pedalb...s-pedalbox.htm however you may want to hold off with ordering as there are some issues that they need to resolve.
The 2011 E350 4 Matic option has been removed from the drop down menu as there was a mistake and I ended up getting the wrong unit and now have to send it back (at my expense).
I looked at the european websites and have determined that devices for the W204 is the same as for the W212 so I ordered that one in the meantime while i deal with the return.
2011 E350 4 Matic
Received my second units and installed it, took me more like an hour to install to make it as clean as possible.
I like the default red setting the best and don't think i will ever need to change it unless the car starts adapting (hope it doesn't). Basically just a slight push of the gas pedal and the car moves. looking forward to my drive to work tomorrow.
2011 E350 4 Matic
LOL, the drive to work was actually terrible. not because of the device, it was the stop and go traffic.
Anyway, for me it is 100% worth the expense, function wise it is the same as the sprintbooster (which has been discussed in great lengths in MBWORLD) but this one is cheaper. $268 including tax and shipping (you have to enter coupon code).
My only concern is that the vehicle may adapt to the device (it did with the 1st gen sprintbooster) and will provide an update later in the month.
2011 E350 4 Matic
it's 'SHIP" and you can find it on the the website (on the right hand side). stupid that they even make you enter the coupon if it is posted on the site. but like my first order I didn't notice the coupon code so I guess from their POV it makes sense.
2011 E350 4 Matic
So i have had the device for a few weeks now and the car had slowly adapted itself to the pedalbox (just like the sprint booster did). so just did the ECU reset and it is back to its original sensitivity.
So that is a slight disappointment but it was something that i anticipated to happen. I still am happy with the purchase.
