Window Problem
Window Problem
My 2014 E350 has a problem with the front passenger window where if I try to put it up with either the passenger button or the one on the driver's side door, it will not go up by pulling the switch all the way (automatic) and once I hold it up to put the window up, it closes, but then opens itself an inch or so. I called the dealer and they said to hold it down for 5 seconds once it is open and hold it up for 5 seconds once it is closed. That did not fix it. Any ideas?
Thanks.
Thanks.
Received 4,446 Likes
'71 Pinto
Might I suggest searching Bulletins thread https://mbworld.org/forums/e-class-w...212-sedan.html - LI72.40-P-058061 door control unit software update and/or replacement, check your email.
Thanks.
'71 Pinto
Only DIY is to attempt a reset as dealer suggested, see attachment.
