E350 ECO mode air conditioning
Today during a red light stop, the ECO mode activated and shut down the engine. The air conditioning is still on but the air wasn't "cold enough". It is code again after the engine turned on. It happened twice today. Is that normal? Is this a sign of the aux battery is dying?
2013 E350 4Matic
Engine needs to run in order for the AC Compressor to operate and provide circulation in the AC system. After the engine is shut down the AC Coil will remain cold for 30seconds or so, it has no circulation due to engine being off, while warm air from the cabin is still forced through it.
This is how I observed the system works too. The air wasn't as cold. I lower the temperature but not making difference. Once the engine is up, it is icy cold again.
Sounds like not a system issue. Just need to disable ECO if it's not cold enough.
Received 2,161 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
I shut eco off on hot days ...
2023 EQB 350 & 2014 GL350
That said, Mid City Engineering has an ECO Kill device for the W212.
http://www.midcityengineering.com/oe...-mercedes-benz
wtzouris (05-21-2022)
Starter motor won't be any more likely to fail with ECO on or off, they have been tested and developed to do a huge number of starts over what any of us will put it through in its lifetime.
This is normal, same thing happens on the 2016 models, i usually turn off ECO because it generally never comes on when i would like it too, like in a drive thru scenario. Plus, there is a slight delay when you take off from a red light while in ECO mode, which i do not enjoy at all. I will sacrifice the few drops of diesel i save and just turn it off.
