HOLD function- who uses it?
#51
w212 E350 Bluetec Estate 2013 facelift with Brabus D6s; W211 2004 E500 salon(stock)
#52
I use it all the time. Just ordered a new car that doesn't have the feature and I'
m already missing it! The BMW hold feature mentioned in post #6 sounds ideal and should be a standard feature on all cars.
#53
I have a friend that had a hip replacement (due to prior car accident) and he bought the newer e-class just for the brake hold feature.
I can definitely see the added safety benefit for distracted drivers (foot might slip off the pedal when reaching for something, etc) and also to keep brake lights on at stops.
#54
Received 2,144 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
My understanding is that it is adaptive ( it would have to be as the amount of pressure will vary depending the gradient of the road you are stopped on) I don't know the response time or how many times per second the brake pressure is adjusted though. i
If you are getting rear ended to the point where the vehicle would move forward i'm pretty sure the grip from the tires would go a lot sooner than the pressure of the pads onto the rotor. Unless this has like just enough pressure to keep it from moving forward?.. i doubt they would design the system like that though.
#58
I just used it for 'launch' the other day and it was pretty cool. Maybe I have to use it more so I can get used to it. Just hard to trust it after years of keeping foot on the brake pedal.
#59
It is a useful feature but to activate it, one requires a lot of practises to perfect it. There are times when it simply refuse to come on. A button instead is therefore a useful suggestion.
#60
2010 e550 p2
P.s. maybe it just feels safer this way , and i know it wont roll back lol
