Few Modification Q's
Hey guys,
I just picked up a new 2016 G63 Black on optional Black interior. I plan on doing the typical power mods for this drivetrain. But had a few question regarding a small lift and offload tires. I have searched but never found a answer for this combination. Im hoping someone can chime in and shed some light. I will also copy this to the AMG G section.
I plan on lifting it with spacers like most have suggested. I see G-wagen accessories has the 30mm poly spacers. I know there was another sponsor here that carried spacers which he offered a slightly bigger lift. On top of lifting it either 30mm or 50mm via spacers. I will be adding 30mm hub bolted wheel spacers most likely from H&R. So with that in mind what tire sizing do you guys feel I can go with on the stock wheels?
Also if anyone has pictures of what Im trying to achieve, please post up. Would love to see them. Also a off the wall question that most might not know, long shot. Does anyone know if someone makes a long gun locking rack for the rear cargo area, with weapon systems standing vertical? Would rather buy it then fabbing up a one. Thanks in advance guys!
-Willis
-Willis
Hey Willis,
Geewagoon just modified his truck with some 20 inches rims, 50mm lift and A/T tires.
Check out this link:
https://mbworld.org/forums/g-class-w...oad-tires.html
I dont know if your calipers with let you downsize your rims for a smaller size with bigger tires like the THOR products G-Wagen:
I walked this path recently but not with a G63.
With 30mm Spacers and the lift you are describing you can easily fit 305/70/18 tires.
Your challenge will be finding off road tires in 20 inch size. You can do Nitto Terra Grapplers but that is all I have seen in 20s. A lot more options at 18 inches, which is why I went 18, and if you actually plan to wheel it 18 is much more practical for off roading.
KC
KC
I have the 30mm hub centric spacers from H&R that I never even took out of the box if you're interested. I thought I would need them for my 33's, but everything ended up fitting just fine with stock suspension. I'm in SoCal and could ship them out whenever.
KC
KC
Thanks KC! Ive found a good amount of off road tires in 20s. That is the standard for lifted heavy duty trucks. I had 22" wheels wrapped in 40s on my last to Super Duties. :-) I think I can pull off 35s with suspension and wheels spacers. Even crossed my mind to start putting a real lift on it. But then it would never end. Didn't buy this truck (G63) to go crazy on.
Thanks bro! Shoot me a pm on how much you want for them. Im in Vegas so not too far to ship. haha.
