Sign in using an external account
| GL Class (X164) 2007-Present: GL320CDI, GL420CDI, GL450, GL550 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2008 GL450
Service A on GL450
#2 |
Drives: '07 GL320CDI
Your dealer can get you a copy of the maintenance booklet.
You can also find it online here: http://www.mbusa.com/mercedes/servic...enance_manuals
__________________
Kent Christensen Albuquerque '07 GL320CDI |
#3 |
Drives: 2008 GL450
Thanks lkchris...
But the maintenance booklet doesn't talk about "Service A". Any idea where I can get the info on "Service A"? |
#4 |
Drives: 2013 GL350, was 2007 GL450
Here's what my dealer says is involved in a Service A
$239 (Market Average Price: $249-$344) Service A - Minor Service Model Years: 1998 - Current Perform Service A Maintenance Reset Service Counter Check all exterior and interior light bulbs Perform function test of windshield wiper system Check all seat belts for damage and proper function Check condition of front and rear brake pads and rotors Inspect tires for any damage and proper wear pattern Correct tire pressures Check catch and safety latch and hinges on engine hood Check and adjust all under hood fluids (including brake fluid, power steering fluid, coolant and windshield washer fluid) Perform midtronics test of battery to ensure proper battery condition Perform function test of parking brake Check for leakage of major components Check for chafe marks, proper line routing and damaged components Check condition of front axle ball joints and rubber boots Check condition of steering components Check condition of Poly-V Belt Perform synthetic oil and fleece oil filter change Rotate tires No charge items included in service package: Car wash and interior vacuum ($15 value) Airport transfers Free wi-fi Shuttle ride Starbucks coffee
__________________
Jim Barnhart 2013 GL350 Obsidian Black/Black Leather |
#5 |
Just a thought, I don't want to offend you, but Mercedes maintenance schedules are different from most cars. Servicing every 12,000-13,000 miles is a normal maintenance schedule. It's not like most cars where you change the oil every 3,000-5,000 miles. As you know, the car will tell you when it's ready, but under normal conditions you'd see a need for maintenance at that interval.
__________________
#6 |
Drives: 2008 GL450
Thank You! So as I understand, can ignore the maintenance booklet and follow the Service Indicator on the Command. Am I right?
#7 |
If you intend to take your vehicle into a Mercedes dealer for the service I believe that would be fine. You might go in for a Service A and they tell you that your GL also is due for something else but all service is scheduled around these 13,000 mile intervals.
__________________
#8 |
In the maintenance booklet Service A is the one with the least work done, Service B is the one with more dots in the table.
__________________
| Tags |
| 2011, 450, belt, forum, gl, gl450, interval, maintenance, mercedes, poly, replace, reset, schedule, search, service, x164 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
