COMAND dead - Anti theft activated message
Old 11-09-2012, 10:05 PM
ddruker's Avatar
2011 GL 350, P1 Package, HID headlamps, Blind spot assist, Parktronic, Wood steering wheel
Earlier this week my head unit started reporting "Anti-theft protection activated, please switch the ignition on and restart the system" When you start the truck COMAND comes on briefly, very quickly connects to the cell phone, and then the above message comes on the screen.
This happens every time I start the truck. Turn COMAND on and off doesn't help, turning the ignition on and off doesn't help - I even tried triggering the alarm on purpose and then resetting it. Here is a video of it happening.
Any ideas?
One more data point - my electronic ignition system (EIS) module went bad about six weeks ago and was replaced by the dealer under warranty. Could this be related?
Old 12-06-2012, 07:31 AM
Carmaster's Avatar
Daewoo Nubira
http://www.youtube.com/watch?v=bDxBe...&feature=g-upl
Any ideas?
Hi m8! Ofcoz it is related. Dealer, changed your EIS (electronic ignition switch) seems mistaken, with part number of this. Or they MUST "marry" EIS and COMMAND again. Best regards!
Old 12-21-2012, 12:03 AM
ddruker's Avatar
Problem turned out to be that they failed to properly marry the new EIS and the COMAND unit...
Old 12-21-2012, 02:03 PM
Carmaster's Avatar
Daewoo Nubira
Known trouble of the dealership workstations. )) Thanks for answer.
Old 10-07-2016, 10:51 AM
bevin0708's Avatar
2010 ML 350 4Matic
Command Anti Theft after EIS replacement
Same issue here, I have an appointment next week and the dealer says this is in no way related to the EIS replacement that he did two weeks ago. He has to look at the car, and charge me 200$ for it before he can say anything.
This is the only dealer for the next 50 miles.
They are completely Incompetent. And always trying to charge me for unnecessary service.
Old 10-07-2016, 02:31 PM
alx
alx's Avatar
yup. command needs to be synced with new eis.
Old 09-20-2017, 12:28 PM
marcio.ota's Avatar
W176
Hi, do you solved this problem? I'm with the same message (changed the radio)
Old 09-22-2017, 08:23 AM
alx
alx's Avatar
now, assuming you read the thread- how do you think he solved that problem?
Old 05-01-2021, 12:51 AM
ryandeen12's Avatar
ml350
I got the same message Anti theft protection activated
Any ideas?
did you find any solution for this problem. I need some help too
Old 05-01-2021, 12:54 AM
ryandeen12's Avatar
ml350
Same problem I change my radio
did you find any help, I try everything and notting works
Quick Reply: COMAND dead - Anti theft activated message
