Break fluid
Old Apr 24, 2021 | 11:23 PM
Pmanc's Avatar
2012 gl450
Break fluid
Hi I have a GL 450 2012 I’m scheduled to do service b I have almost 85,000 miles It’s been about almost 3 years since I changed The brake fluid should I do it how important is this could anyone give me some advice thanks
Old Apr 25, 2021 | 03:16 AM
sak335's Avatar
2012 GL 350
Open the cap on the fluid and draw a bit out with a pipette or a turkey baster. If it's yellow or brownish, then absolutely replace it. If it's still nice and clear, you're likely OK, but remember that brake fluid is hygroscopic (it attracts water.) The water in the lines and calipers can rust things from the inside out if it gets bad enough.
It's a 30 minute job (OK, an hour if you're a newbie) and costs $10. I don't know why you wouldn't do it.
Old Apr 26, 2021 | 11:57 AM
eric_in_sd's Avatar
2007 GL450
For just a few bucks you can buy a brake fluid moisture sensor.
A lot has to do with how humid your climate is.
Old May 2, 2021 | 09:36 AM
Pmanc's Avatar
2012 gl450
Ok thanks for the info
Old May 2, 2021 | 10:05 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
I would do a complete flush. If your a bit handy, you can do it yourself.
MOTIVE makes a fairly inexpensive kit. I do all my vehicles every 3 years, it keeps my OCD in check. Once you know what to do, the job can be completed on about 45 min.
Check out motive YouTube videos also..
Old May 2, 2021 | 10:51 AM
Pmanc's Avatar
2012 gl450
Ok thanks
