Remove GL450 Headlamp Assembly
Walmart charges few bucks "around $15" for labor to install a new one that you provide. Not sure of the level of experience here...
The dealer is another option, it depends on the project itself.
See if this helps:
See if this helps:
You'll need three beers, a crowbar, a quarter stick of dynamite, and a Bible. Well, unless you plan on puttin' them back in.
Source: https://mbworld.org/forums/gl-class-...eadlights.html
I'm planning on replacing them since they started tinting, and have humidity/water inside, so this is my next summer project.
2007 GL450
Here's the basics:
1. Remove the front grille. Note this may not be necessary, but I was doing it because mine needed replacement.
2. From top, remove the torx screw connecting the bumper cover to the plastic underneath it.
3. Remove three pop-pins and one 10mm nut from fender liner. Bend fender liner down.
4. Remove two 10mm bolts inside fender liner, one mounting fender and bumper cover to vehicle body, and one mounting headlight assembly to body.
5. Remove one torx screw tying bumper cover to fender.
6. The bumper cover is now attached to the fender by a long (approx. 8") clip. This clip surrounds inner lips on both the fender and bumper cover, clamping them together. This clip has a pin in it that restricts the bumper cover to sliding out only in the forward direction. This pin is in the fore end of the clip; if you rotate the aft end of the clip toward the car, it will lift clear of the inner lips. The whole clip can then be moved in the aft direction, free of the lips on the bumper cover and fender.
7. I think there are also two 10mm bolts on the underside of the bumper cover, attaching it to the underbody. We had removed the bottom cover as well.
8. The side of the bumper cover can now be rotated forward; it does not need to be very far forward to provide clearance for the headlight assembly.
9. Remove two 10mm bolts at the top of the headlight assembly. While coaxing it out, pull the bumper cover forward to give it room to leave.
10. Possibly support the bumper cover; we found it didn't seem to mind holding itself up.
The only tricky part about reassembly was getting the fender and bumper cover aligned together to slide the clip on. It's a tight fit, which is why I came up with the idea of aligning the two and then maneuvering the clip into place, pin first and then rotating the rest of the clip onto the two lips together.
Feel free to hit me up with any questions.
ML500 2006
I know it's been a few years you did this but I am in a middle of a struggle to reassemble fender to bumper clip and I cant figure out where the rubber shim goes? Between fender lip and clip? OR between fender and bumper lip ? OR others. Thank you
2007 GL450
You could take off the fender liner on the opposite side to check.
I have gotten rid of those plastic pop rivets. Just assemble without them. If the absence bothers you, get some stainless (if in snow country) screws and clip nuts.
MLwrencher (09-19-2022)
See if this helps: https://www.youtube.com/watch?v=vAfalcN_4pQ
