2008 Gl550 A/C kicking on and off?
Old 07-22-2014, 09:53 AM
bnzuovr's Avatar
2004 W211 E55K, GL550
Did a search on here and google and came up with nothing. Was hoping someone could help me pretty straight forward. A/C comes on and blows cold sometimes and sometimes blows warm checked the Freon and it is were it is suppost to be at about 2.70lbs Has anyone had the same issue or know what maybe the problem. I was thinking A/C switch but thought i would check on here first. Any help would be greatly appreciated thanks in advance.
Alp.
Old 07-22-2014, 04:39 PM
alx
alx's Avatar
was the ac serviced recently?
this can happen if you are low or overcharged on/ with refrigerant.
Old 07-23-2014, 09:06 AM
bnzuovr's Avatar
i did service it at my repair shop and according to my robin air a/c machine it showed 2.70lbs which is were it was suppose to be at i replace it with 2.75lbs and its still doing the same thing. Any other suggestions would be appreciated.
Old 07-23-2014, 03:33 PM
alx
alx's Avatar
you have air in the system (did they evacuate before adding refrigerant?) or the "2.7 lbs" in there are not 2.7 lbs
it is really that simple
and why did you have to service it to begin with?
Old 07-25-2014, 12:05 PM
bnzuovr's Avatar
it does not have air in the line from what my a/c machine told me and i evacuated the system and vacuumed the whole system. The reason i did the service was cause i was figuring i had low refrigerant in the system. I can try purging the system how do you recommend i do it?
Old 07-25-2014, 09:48 PM
alx
alx's Avatar
If you are sure you have vacuumed the system properly the 2.7 lbs is not 2.7 lbs. I don't have the number, but make sure you have the proper amount in there.
Have you replaced your cabin filters?
Old 07-29-2014, 02:18 PM
chsu74's Avatar
GL 320, 993TT, BMW 550XI
There is a TSB on our AC system where ground is inconsistent. I had mine fixed last summer and it took 3 trips to the dealer...
Old 07-29-2014, 04:02 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Does anyone have a copy of this TSB?
Old 07-29-2014, 04:38 PM
chsu74's Avatar
It's on here or Benzorg. Either in the GL or ML subforum. Can't remember which
Old 07-29-2014, 04:56 PM
N_Jay's Avatar
Any ide on good search criteria?
About when?
Etc?
Old 04-14-2017, 12:15 AM
kismetcapitan's Avatar
GL550
intermittent ground....good lord. like finding a needle in a haystack
Quick Reply: 2008 Gl550 A/C kicking on and off?
