My GL 350 CDI 4matic Blue... too long to start
Old 11-20-2014, 07:14 AM
fdofdez's Avatar
GL 350 CDI blueefficent
Hi guys i want to know if any here can help to know something. i have a 2010 GL 350 CDI blue efficient and when the engine is cold it take to long to start.
it have to be engine problems ? or heaters problems ?
warm regards.
Old 11-21-2014, 01:08 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Define "too long"?
Old 11-21-2014, 01:35 PM
fdofdez's Avatar
Like 10 seconds
Old 11-21-2014, 01:50 PM
N_Jay's Avatar
Where are you?
How cold is it?
Is that cranking time or are you including the time where the glow plugs are on before the crank?
Are you guessing or timing with a watch?
Old 11-21-2014, 02:43 PM
alx
alx's Avatar
warm regards.
if your truck is a 2010 right about now is a good time to have the battery checked as those are consumables on all mb vehicles and especially on the diesels.
Old 11-22-2014, 01:59 PM
fdofdez's Avatar
Caribbean, summer all the time!.
N_JAY The exact time is 6.73 seconds since i turn it to star until the engine is finally on!
ALX i thinking about the battery, will check it on monday.
thanks for answer guys
warm regards
Old 11-22-2014, 03:12 PM
N_Jay's Avatar
Warm weather is hard on batteries. My 2008 got a new battery (previous owner, Texas environment) in 2012.
Old 11-25-2014, 04:24 PM
bha
bha's Avatar
13 GL350, 14 SL550
If you have a 4yr old battery in that heat, you probably need a new one. I recall someone once told me batteries last 3 years in Houston heat (as someone testified to in an earlier post)
If the battery doesn't solve it, look at the glow plug module. They fail and stop working. Most times they set an error code/check engine light, but not always.
Change the battery and see how things are. If that doesn't solve it, then it's the glow controller.
Old 11-25-2014, 09:34 PM
fdofdez's Avatar
Thanks N_Jay and bha, ill go to change the battery this week, i let you know how it goes.
Old 11-26-2014, 01:23 PM
alx
alx's Avatar
Do not just change the battery. Have it load tested first. You might have other problems.
Quick Reply: My GL 350 CDI 4matic Blue... too long to start
