AMG Door Pins - Help!
I recently received my AMG door lock pins. I started to install them and when I screw them on, they screw *way* down. So far that if I were to lock the door, I think they would drop inside the door - not flush with the top. If I screw them in so they are flush, they aren't tight on the screw.
Are other people's lock pins not tight??
2017 Dodge Viper GTC, 2014 C63 AMG (gone), 2014 GL450
Now I just need to figure out what to do on the rear - given that you can't unlock the doors except with the pin.
Yes it's a curious design for sure. We did it anyway. You can unlock with the electric buttons in the front obviously. But it's probably a safety risk since the rear occupant can't unlock it themselves.
I recently received my AMG door lock pins. I started to install them and when I screw them on, they screw *way* down. So far that if I were to lock the door, I think they would drop inside the door - not flush with the top. If I screw them in so they are flush, they aren't tight on the screw. Are other people's lock pins not tight??
As for the rear locks, I just left the plastic ones on...out of sight, out of mind.
I find this annoying and a hassle for my passengers. I've learned to hit the open button when driving carpool. I wish it would unlock with a double open like my previous car. I was planning to do the AMG locks until I figured out that the passengers could easily lift the pins.
