GLE Class (W166) Produced 2015-2019
Sponsored By:
Sponsored By:
Check Engine Light?
Old 02-05-2017, 04:13 PM
Kwando's Avatar
GLE350d
Check Engine Light?
Our 2016 GLE350d has had its second check engine light come on. The first CEL came on in mid-January while driving and after taking it straight to the dealer, scan indicated it was a faulty O2 sensor so it was changed. I'll probably have to schedule another appointment to get it checked out. Car currently has approximately 2x,xxx kilometres.
Has anyone had a CEL come on? What was the problem?
Old 02-05-2017, 04:47 PM
Diabel's Avatar
GLE 350d 2016
I had a "check engine" light come on last week.
It does not come on anymore. However, my rpms seem to go up and which is annoying. I am sure it is a 02 sensor!! Same old, same old.....o2 sensor problems I had with the ML!
I will be seeing the dealer next week
Old 03-05-2017, 02:37 PM
Crispin's Avatar
2016 GLE350 4matic
FWIW, I bought a Ancel AD-310 OBDII scanner on Amazon and it works with my GLE just fine. Was able to read AND ERASE a P0455 fault code after the wife left the gas cap loose.
No more Check Engine Light. $35. Everyone should have one.
Actually, there is absolutely ZERO reason why this isn't built into the computer of these $60,000 automobiles... Oh yeah, that's right, they want you going to the dealer...
Old 03-08-2017, 07:55 PM
Kwando's Avatar
GLE350d
Forgot to update this thread but the CEL mysteriously went away after a few days. The joys of owning a MB product!
Old 03-10-2017, 07:03 AM
GLE43_Sube's Avatar
AMG GLE43 Coupe
The CEL also comes on with the fuel cap isn't tight, so it's not just major problems. I had this happen in my last car and I remembered reading that in the manual. Tightened the cap and it instantly went off and never came back on.
Old 03-10-2017, 09:01 AM
Tbone8771's Avatar
2017 GLE 350 4matic
The fuel cap not being tight and having the driver be notified with a CEL has always made me chuckle. There has to be a better way to notify the driver that the fuel cap isnt tightened all the way without adding panic to the driver.
Old 03-10-2017, 10:39 AM
GLE43_Sube's Avatar
AMG GLE43 Coupe
Agreed. Why don't they just have a dedicated warning alert, either a light or audible alert. Wait, that would make too much sense.
Old 03-12-2017, 02:54 PM
Rainers's Avatar
You guys do not understand, the CEL light went on because of the computer saying that there is a emissions leak in the closed system. The computer does not know the direct cause. Therefore the CEL turned on. If there was a gas cap light because it is not on then you would see two IDIOT lights.
Old 03-12-2017, 05:54 PM
dave2001auto's Avatar
84 300d 2009 e320 bluetec
The cars have a display screen that could be used to display the codes.
Old 03-14-2017, 04:16 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
This, when some vehicles offer an IP that could double as a small theater display, they should at least print the trouble codes on the display and not require a propitiatory scan tool.
It is usually amusing to see people ask why a CEL came on though. On modern cars there are hundreds of faults that could turn it on. By the same token, if the faulting condition goes away, it will turn back off.
Quick Reply: Check Engine Light?
