Oil change
#52
I use a flex impellor pump. I made a adapter on lathe from a short piece of 3/4 in shafting. Drilled and tapped a hole in it. Cut 2 o ring grooves in it. Works great. The dipstick tube goes down into a small resovoir and after sucking i pulled drain plug and didnt even gdt a cupfull out the drain.
Be sure to remove filter first so it all drains to crankcase.
#54
Here's an oil change video I made, if anyone is looking for a specific GLK video
Mercedes Benz GLK 350 Oil Change - Super Easy DIY - YouTube
