Brake Squeal @ Low Speed
Old 11-22-2016, 08:26 PM
michaelcrawford's Avatar
2018 C43 AMG
Experiencing high pitched squeal at low speed braking. Doesn't occur when braking at highway speeds. I think it's coming from drivers side. Can't determine if its front or rear. Any thoughts?
Old 11-23-2016, 12:12 PM
ble2716's Avatar
Very very slow
I had the same problem with 2010GLK 3 years ago.
It's very annoying every time I have to stop at red lights.
After I replaced brake rotors and pads (aftermarket) and NO squeaking noises from the brakes for 3 years now.
I've just check my brakes couple days ago and they look like it's time to replace them again.
Old 11-23-2016, 08:34 PM
107123210's Avatar
GLK250 2014
It's nothing to worry about. It's caused by the pads vibrating against the caliper pistons. If you want to get rid of the noise, there are compounds that can be applied to the BACK of the disk pads that will dampen the vibration. There are also shims that can be inserted between piston and back of pad (I could never find the right ones)
Just be careful what you use. There is brake paste that is used to lubricate the pins on which the pads slide . You don't wnat that on back of pads. There are various brand names, but what you wnat is usually called something like Diskquiet.
Found this article - Popular Mechanics, no less! It more or less says the same thing.
By the way, I have one car that squeaks like yours. Doesn't bother me. But on my wife's car I used the Diskquiet stuff and it worked well - no more squealing.
Old 12-28-2016, 01:19 PM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
I had the same darn squeak and enormous amounts of brake dust. OEM brake pads really suck.
I just replaced them with EBC Redstuff ceramic brake pads....its suppose to be 80% less brake dust and feels great. it took me about 2.5 hours to do all 4 corners. So far...so good.
Old 12-29-2016, 04:24 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
I had the same issue and also replaced everything with aftermarket parts.
No squeak now.
The only good news is the MB parts suck; mine went 24K miles, so you don't have to put up with it for long...
Old 12-30-2016, 10:14 AM
107123210's Avatar
GLK250 2014
No squeak now.
The OEM brakes on new cars don't squeal. It likely has more to do with how they are installed.
Even dealers can give you car back with squeaky brakes. My daughter had that happen, but they fixed it in 1/2hr and squealing never came back.
I have had squealing when using aftermarket pads. But only because I did not know how to install properly with proper anti-squeal paste and or shims.
Talking about the slow speed squealing in original post.
Old 01-10-2017, 06:34 PM
rmfnla's Avatar
Mine did, intermittently, almost from day one.
Several trips to the dealer; it would stop for a bit and then come back.
Stopped for good when I did the brake job.
I quit going to a mechanic for saying what you said (do you think my wife and I imagined it?)...
Old 01-24-2017, 07:15 PM
jk952's Avatar
2013 GLK 350 & 2007 SLK 350
I had a squeal issue with the rear brakes, driver (LH) side, on second try found out it was the Side of the parking brake shoes dragging on the step inside of the rear disk/drum, relieving the side of the parking brake shoes a few thou. fixed it. Could be a drum machining or tolerance issue as not much original clearance.
Jk
Quick Reply: Brake Squeal @ Low Speed
