No sound from MCS
Old 03-09-2015, 02:01 PM
kuleke's Avatar
2007 S550 (Prev) 2001 ML320
No sound from MCS
Hi
I finally got the security code to my MCS (2001 ML320) and tried to use it briefly. A couple of issues came up:
- No sound at all, on tape or radio (tried scanning as recommended by MB, still nothing). I tried turning the power knob in both directions but there was no visual (on the screen) or sound effect. It works for turning the system on and off.
-When I select 'CD', it tells me 'No CD Player installed' but there is a CD changer in the back which works as far as unloading and loading discs. Also, are there some easy solutions for things like AUX/Bluetooth?
-This isn't overly important but how much trouble would be involved in getting something out of the NAV and Phone features? ( Both currently saying 'No navigation system installed' and 'No telephone installed' respectively)
Any help would be appreciated thanks.
Old 03-10-2015, 04:38 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You say that you are not getting any visual (blank screen) but didn't you get a visual on the screen to enter the security code?
Check fuses 10 and 21.
Old 03-10-2015, 05:09 AM
kuleke's Avatar
I mean there is no visual response to turning the volume knob. The screen works fine otherwise. Where are these fuses located?
Old 03-10-2015, 08:22 AM
In the underhood fuse/relay box.
Old 03-10-2015, 12:08 PM
kuleke's Avatar
I think I'm gonna need a little more help :/ Is there a guide somewhere (with pictures) I can follow to find/remove/modify things? I'm comfortable with taking stuff apart (and putting them back together!) so I just need some instructions. This is so I don't have to ask you every little question. Thanks
Old 03-14-2015, 07:25 AM
What is it that you need to remove?
Old 07-05-2015, 10:53 AM
kuleke's Avatar
Sorry I completely forgot to say something here. I got a replacement MCS unit and the sound worked. Then I tried the original one and the sound also worked. So I think I must have fixed whatever wiring issue was present during the re-installation. I've been using it without any issues since. Thank you for offering to help though
Quick Reply: No sound from MCS
