Another thread Oil leak on diesel OM642
Old 01-04-2017, 08:03 PM
phlfly's Avatar
ML320 BlueTec, 09 E63 AMG, 91' 350 SDL
I have 09' Bluetec and it has oil leak somewhere. It's possible it's leaking from throttle body (????), well anyway an oil is all over on alternator . Please take look.
Is possible turbo leaking and it goes to throttle body?
Any ideas?
Plus what is connector, it's not connected to anywhere????
Attached Thumbnails Another thread Oil leak on diesel OM642-img_1081.jpg   Another thread Oil leak on diesel OM642-img_0338.jpg
Old 01-05-2017, 12:08 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Put the car on a lift and look up!!
Old 01-05-2017, 01:12 PM
phlfly's Avatar
It's my plan tomorrow. I was asking if anyone had same experience with it?
And it maybe identify a connector.
Old 01-05-2017, 06:27 PM
justinwrock's Avatar
Ducati
Check the condition of your valve cover gasket, might be cracking. Dunno about that connector, but it looks like it has a sealed cover on it - might just do nothing.
Also, when was the last time you replaced the fuel filter? It's looking a little funky!
Old 01-05-2017, 08:59 PM
phlfly's Avatar
Did you ever seen them cracked?
I just got a car. It's 90,000 and all recored from Mercedes dealer. I was surprised ti see that too. I have already ordered filter from ID parts.
Old 01-06-2017, 02:43 PM
phlfly's Avatar
I got car on lift. So I traced oil leak as I could see without disassembly whole engine. It's leaking along the EGR pipe, that goes to throttle (? ??). It has oil at external and bottom side of the pipe(lower side that is looking at engine). No oil at tranny bell housing, it looked it was there leaked there but no more.
Any ideas??
I have ordered the fuel filter, so I will be replacing soon, and hopefully i will see than.
Old 01-14-2017, 01:58 PM
phlfly's Avatar
Replace all air filter and fuel filter they were nasty, looked like never have been changed. Well It seems to me PCV valve is blown. And it might why has oil at front, since EGT pipe take ramp air to butterfly valve at front. I will replace all gasket here too.
Old 01-15-2017, 07:19 PM
ml320bt's Avatar
2009 ml320 blue tec
My oil leak was from the seals on the oil cooler located in the "valley" on the top of the engine. Lots of stuff to remove to replace seals and costly if you can't do it.
Old 02-10-2017, 02:13 PM
gaineserau's Avatar
2009 ML320 Bluetec
Any ideas?
I have the same connector--I'm not sure where it goes either. I've always wondered it if was some sort of engine pre-heater connector....
At any rate, my car has had a leak (not nearly as bad as yours) for a while in the same area and I just recently figured out it was the vacuum pump. The pump bolts to the top of the engine right above the area you are depicting. I had changed all the seals in the intake pipe around the throttle body like others here have suggested since there is always residual oil coming through the intake tract from the CCV system, and that still didn't stop it. I just bought a new pump for $180. Installed in :20.
Old 02-21-2017, 04:56 PM
TX E55's Avatar
Mercedes-Benz AMG E63 & ML350 Bluetec
Hey, mine just got done today at my local indy shop. $2,800 to get in there, replace the seals (all of them on stuff they had to remove and break apart to get to the cooler), my baby was out of service for a week.
THANK GOD for the CarMax extended warranty. I am out of pocket $300 and my shop said they were super easy to deal with. Just about paid for the warranty with that one claim.
Good, now my wife can stop driving my E63 BiTurbo Renntech.
Old 02-27-2017, 10:55 AM
TX E55's Avatar
Appreciate any input....
If you read the previous post you know I just had my 2011 ML350 BlueTec repaired for the oil leaks at the cooler. Wife said that it was running loudly and when I drove it, it is no longer the quiet, smooth ML350 we had before the repair work was done. Engine noise, almost like valves or injector(s) making a racket. It has plenty of oil and the shop re-checked all the bits and pieces to make sure a shield or part wasn't loose. They want me to just drive it for a few more days to see if it goes away, their thinking is that it might be air in the injector(s) since all of that was apart.
Any suggestions or thumbs up or down on that line of thinking? This local indy shop is a very well respected place and I've trusted them since they opened - just looking for some comfort while we drive it for a few days.
Thanks!
Old 03-02-2017, 05:43 PM
boblydon's Avatar
e320 ml350 xk jag
We have a oil leak on our 2010 ML350 32000 miles, i stripped down the engine to check the dredded oil seals on the oil cooler, was a waste of time as there was no signs of oil in the valley and the seals were the new purple ones.
I still replaced them and all the other ones as i put it all back together, still have the leak coming from the bell housing.
To double check everything i got a tiny flexible camera from ebay and connected it to the computer, i managed to wangle it down into the valley and could see no oil.
Only thing i can think of now is the rear crankshaft oil seal, anybody had trouble with theres??.
Bob
Old 03-02-2017, 10:09 PM
phlfly's Avatar
Where is oil leak, I meant where are you seeing oil drip rear or front?
Old 03-03-2017, 02:48 AM
boblydon's Avatar
e320 ml350 xk jag
the leak is dripping from the bottom of the bellhousing, so at first i thought it was coming from the drain hole from the valley......no such luck!
bob
Old 03-03-2017, 02:39 PM
dieseldoc's Avatar
2016 GLC300 Dakota Brown on Espresso Brown Leather, 2014 C250 Sport Diamond Silver
? Rear main seal
Old 03-03-2017, 05:11 PM
boblydon's Avatar
e320 ml350 xk jag
Hi
Yes thats what i was thinking, thinks it's time to get the car up on a ramp and remove the gearbox etc to check, any pit falls i should know before i start to remove it......except i bet it's bloody heavy!
Old 11-16-2017, 08:00 AM
nathan_guymer's Avatar
E350 C207
Originally Posted by boblydon
Hi
Hello mate, did you find out what he problem was? Mine has got a leak here too, after having the cooler seals replaced, I’m still finding oil coming out of the bell housing...
Old 11-16-2017, 08:07 AM
E350 C207
Bump? Someone help?
Old 11-16-2017, 09:18 AM
boblydon's Avatar
e320 ml350 xk jag
Have replied via your message, it was the crankshaft oil seal, the new one is a much better design and quality.
Been leak free now for 4 months
Old 11-16-2017, 11:43 AM
E350 C207
Thank you for your reply. I did try and reply but don’t think the message was sent.. well I can’t see it anyway haha. How much oil did yours drip? Was it every day?
Cheers
Old 11-17-2017, 04:55 AM
E350 C207
Old 11-17-2017, 04:56 AM
E350 C207
How often was your car dropping oil?
Cheers
Old 11-17-2017, 05:17 PM
boblydon's Avatar
e320 ml350 xk jag
about a teaspoon full after every time it was driven
Old 11-18-2017, 10:05 AM
flybd5's Avatar
2014 Smart ForTwo Passion Cabrio
That sounds like round engines on old airplanes, or fractions of round engines on old Harleys. They're like cats, always wanting to mark their territory.
Old 12-03-2017, 11:58 AM
E350 C207
Smile UPDATE
Bobblydon,
I finally got my car back after 2 days. It seemed to be the rear main seal as everything is now dry and no more drips. Fingers crossed it is sorted now!
Thanks!
Quick Reply: Another thread Oil leak on diesel OM642
