Aftermarket HID problem solved!
Old 03-16-2016, 05:34 PM
nvsocr7's Avatar
GLE 350 4MATIC
Originally Posted by skw
Install your kit yet? No dremel needed. Happy to report no issues over the past few weeks. Still haven't had time to try the e39 adaptor yet. Only have 1 night pic but headlights are on on both cars. GLE on the right, BMW on the left.
I haven't had a chance yet! waiting for the weather to get warmer and for a day off from work. From what I can tell though, it's a significant upgrade although not perfect. I may have some other questions in terms of wiring though, I'll try to post a picture of what I have so far since I too got the morimoto.
Old 04-26-2016, 02:39 PM
jolugo's Avatar
'17 GLC43
Are your kits still working? Other people start reporting issues after a few months.
Old 04-26-2016, 02:48 PM
skw
skw's Avatar
2019 GLS450
Just over 2 months so far and all is still good here.
nvsocr7 (05-05-2016)
Old 04-26-2016, 03:15 PM
Badassml350's Avatar
13 ml 350 palladium silver, 14 grand cherokee overland hemi
I'm the OP and not one problem... Bright look awesome and noerrors.
Old 05-18-2016, 01:04 PM
alextclam's Avatar
2016 GLE350 4MATIC
Elbow grease and fiddling indeed but they're in. Gotta wait till night fall for some pics. Thanks for your help! As an FYI, I had to remove the orange brackets from the ballasts to get them to fit into the headlight housing.
So, the ballast (minus brackets) plus all wiring were able to fit inside the headlight housing with the housing cover on, without any problems?
BTW, I just ordered the same kit! (Morimoto H7 35W - 4500K)
Old 05-18-2016, 08:57 PM
skw
skw's Avatar
2019 GLS450
Correct. You can feel with your hand there's some space under the bulb that the ballast can slide into. The rest of the wiring and the resistor you can finagle in there also. The cover then goes on easily.
alextclam (05-18-2016)
Old 05-21-2016, 09:30 PM
  #32
alextclam's Avatar
2016 GLE350 4MATIC
I installed them today and have an issue with the drivers side. It doesn't turn on if I leave it on 'auto'. If I'm lucky, when manually turning the headlight switch from 'auto' to 'on' immediately after engine start, it will flicker 5-6 times off/on rapidly and then stay on with no issues. Checked all wiring to make sure nothing was loose. Started to rain so I didn't have a chance to swap components with the passenger side and see if the problem follows. I'm assuming it's most likely a bad component since you have no issues on your GLE.
Did some quick searches on the issue I have, the causes vary from weak electrical and/or daytime running lights. Was wondering if you have DRL and vehicle locator lights enabled.
Old 05-21-2016, 10:57 PM
  #33
skw
skw's Avatar
2019 GLS450
Yes, both enabled here.
Old 05-21-2016, 11:34 PM
  #34
alextclam's Avatar
2016 GLE350 4MATIC
Thanks. On my way home earlier, started up the car with the headlights already in the 'on' position and the driver's side came on while the passenger's side flickered a few times and stayed on. I'm beginning to think it isn't faulty components anymore but has to do with the electrical not putting enough power to the ballasts.
Other than that, they are nice and bright. A huge improvement over the factory lights. Kind of bummed about having this issue though. Going to see what the folks over at TRS recommend in my case.
Old 06-02-2016, 01:20 PM
  #35
jolugo's Avatar
'17 GLC43
I finally did mine. I ordered the ballast but didn't realize it was only for one, so I had to order a second one and wait. I had a bit of a problem with the bulbs and the aftermarket clips you guys recommend, but after about an hour fiddling with one side, it only took me 10 min to do the other side. No issues so far, the lights blink a couple of times when they fire up, but its no big issue. Thanks guys for all your guidance.
Old 06-02-2016, 02:22 PM
  #36
SPONSOR/MBworld Guru
AZN Optics's Avatar
Might want to try the Morimoto capacitors to help with the power load blinking
Old 06-09-2016, 12:46 AM
  #37
daloz's Avatar
2014 ML350
Did you guys replace the high beams as well or is this only for the low beams?
Old 06-09-2016, 11:28 AM
  #38
jolugo's Avatar
'17 GLC43
I only did the low beams, It takes couple of seconds for the bulb to warm up so I figured it makes no sense when flashing people and probably puts more stress having to go on and off all the time.
Im just going to replace the stock bulbs with some silverstar ultra or something like that.
Old 06-13-2016, 05:40 PM
  #39
nvsocr7's Avatar
GLE 350 4MATIC
Do you need 2 capacitors or just one? Which side do you plug it into? Where?
Also, I just attempted to install. I had to bend the aftermarket retainer clip sides down a bit. Also, i have the 5500k and 4500k and the bases are different. my 5500k are the same as you guys are talking about but i cant get the retainer clip to sit flush on the bottom. Any ideas?
Old 06-14-2016, 12:15 PM
  #40
alextclam's Avatar
2016 GLE350 4MATIC
I believe he is referring to the Morimoto Standalone CANBUS harness which essentially has capacitors and resistors inside the module. If you ordered that with the Morimoto kit then you should be good.
This is how I installed the bulbs with the aftermarket retainer clips. I didn't have to bend or modify anything.
nvsocr7 (06-14-2016)
Old 06-14-2016, 06:07 PM
  #41
nvsocr7's Avatar
GLE 350 4MATIC
Two things: I have the same clips and bulb base however my clip does not sit flush in any way with the base of the bulb. It seems like with the clips, they are rounded in so it will not go over. This is what I end up with when I try to do what you did.
http://imgur.com/a/ynuQK
second thing: do you prevent the shadow from the wire? Does the wire orientation matter?
Old 06-19-2016, 11:28 AM
  #42
alextclam's Avatar
2016 GLE350 4MATIC
Wire orientation does matter, you want to try and keep the return wire of the HID bulb on the bottom when locked into place.
Watch this video and you'll understand what I'm talking about:
The way I installed it was by inserting the bulb into the socket without the clips. Then position the clips over the bulb and rotating the clips to lock in place. Since one end of the clip has an opening, it makes it easier to bend. With that said, use a little elbow grease and I'm sure you will get it to lock into place.
Old 07-08-2016, 07:16 PM
  #43
dvakata's Avatar
ML350d w166
guys, how do you replace the bulb? do I need to take off whole front light? anyone has manual how to do it?
Old 07-08-2016, 07:23 PM
  #44
skw
skw's Avatar
2019 GLS450
Removal is not necessary, can be accessed through the wheel well.
Old 07-08-2016, 09:27 PM
  #45
dvakata's Avatar
ML350d w166
I have read whole trade about how to fit in the bulb but not success yet. I'm using original retainer as I wasn't aware I need to order aftermarket to fit in morimoto bulb, even I specifically mentioned I'm looking for w166 HID kit...
So, what's my best options - to dremel original retainer or wait and order aftermarket? I understand even aftermarket need to be adjusted to fit
Old 07-09-2016, 08:43 AM
  #46
skw
skw's Avatar
2019 GLS450
No, no Dremel needed. I have the Morimoto kit as well. Used the factory clip on one side and an aftermarket clip on the other side. Both fit just fine. Haven't had time yet to change one or the other.
Old 07-09-2016, 01:11 PM
  #47
dvakata's Avatar
ML350d w166
manage to install it! yey!
now, when the lights are on it blinked 4 times and then off
When I connected it direct to 12V it works fine.
Any suggestions?
here's my components
Old 07-13-2016, 09:18 PM
  #48
Eddoh01's Avatar
GLE350
Any suggestions?
I just installed my morimoto kit also and having the same problem as you. It will turn on and off a few times and then stay off. There is an extra section of wiring from the canbus going towards the headlight, did you remove that portion also? I'll call TRS tomorrow and see what can be done.
Old 07-14-2016, 02:31 PM
  #49
skw
skw's Avatar
2019 GLS450
You guys have me at a loss. I bought the exact same kit, components only go together one way. I choose the 4500K bulbs but I don't think that should make a difference. Have not had any blinking nor any other issues.
Old 07-16-2016, 05:38 PM
  #50
Eddoh01's Avatar
GLE350
Doh! Problem solved! I was testing it without turning on the engine, just the ignition in the on position. Once I started the car, no problems. SKW, how is the cutoff on your car? My cutoff is horrible, it seems the passenger side angles up at the far right with a strong beam of light. It's also very cramped in the headlight housing after I stuffed everything in, hope things don't get overheated in there.
Quick Reply: Aftermarket HID problem solved!
