R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Jump start question
Old 01-21-2016, 06:44 PM
Rodinal's Avatar
R350
Jump start question
How do I jump start another car using the R350's idiotic design.
I got the red thing.
Where do I plug the black cable?
Old 01-21-2016, 06:48 PM
AsianR350's Avatar
08 R350, 07 Acura RL, 1989 Honda Shadow VLX600 (10K miles)
There is a negative post (-) next to the radiator coolant reservoir.
Old 01-21-2016, 06:55 PM
Rodinal's Avatar
R350
Where?
Where? This design is retarded
Old 01-21-2016, 07:12 PM
marc hanna's Avatar
2008 R320 CDI, 1987 560SL
You can connect it to any bare metal bolt in the engine bay or to the engine itself. I usually use one of the bolts on the cross member.
That bolt in the bottom left hand corner of your pic should do fine.
My R320 doesn't have a - post either, but my E320 does.
Old 01-21-2016, 07:19 PM
AsianR350's Avatar
My 08 has one. it is on the side of the fender. (Bottom picture). It also shows on the owner manual.
It is a hex head bolt. Trust me because I connected the negative (-) to my LED light there.
Where?
Old 01-21-2016, 07:42 PM
marc hanna's Avatar
Found it on mine. Thanks AsianR350!
Old 01-21-2016, 07:49 PM
AsianR350's Avatar
No problem. That is why we are here to help each other.
Cheers,
Old 01-22-2016, 05:30 AM
josworth's Avatar
2006 R350
And I actually LOVE the design.... except when you have to change the battery...
It is actually designed to stop, as you put it, "retarded" people from shorting out or crossing cables on the battery....
The post as shown is an unnecessary bonus since Marc is totally correct.... for negative you can use any good metal point on the engine... that is actually the preferred method when you have the battery under the hood as well.....
Old 01-22-2016, 05:49 PM
marc hanna's Avatar
Yup. People actual forget that batteries can explode when there is a spark. It's not going to throw you across the yard, but it'll be like someone throwing a cup of battery acid in your face!
MB has always been at the forefront of safety - it's a huge value that most consumers don't appreciate or understand these days.
Old 01-22-2016, 05:57 PM
AsianR350's Avatar
The owner manual of R350 shows the photo how to jump start the battery.
Old 01-22-2016, 06:01 PM
marc hanna's Avatar
hmm . . . I probably should've read it.
Quick Reply: Jump start question
