Dome-light fan rattling?
Old 09-22-2010, 12:58 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
Question Dome-light fan rattling?
Hey guys,
I'm not sure if I'm the only one with this problem, but I know there's a fan within the dome lights and from time to time theres this little rattling noise. Most likely just the fan hitting some kind of plastic trim inside the housing...
that "little" sound is KILLING ME
If anybody else has this problem or knows how to actually fix it let me know!
Thanks!
Old 09-22-2010, 02:23 PM
Fraser's Avatar
A Mercedes obviously!
As in up near the rear view mirror?
If it is I had the same issue and apparently it relates to the AC somehow, I want to say it is a fan to keep the sensor cool. The dealer replaced mine whilst it was in for a service.
Old 09-22-2010, 03:57 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
It is an aspirator motor, one of two in the car. See the W220 S-Class Owners Start Here sticky at the top of the forum, look under Air Conditioning and heating, and see "Buzzing noise from dash."
Old 09-22-2010, 03:58 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
yes the one near the rear view mirror!
I remember reading a thread about relating to AC but I thought it was more cleaning the actual climate control unit! I know theres a fan at the climate control unit but the sound is coming from near the dome light thats why I'm so confused!
SKYLAW WHERE ARE YOUUU!!! haha
Old 09-22-2010, 03:59 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
ohh wow, thanks SKYLAW haha you literally posted a minute before me! haha thanks I'm going to go read that right now!
Old 02-03-2011, 03:42 PM
elyjohn's Avatar
S500
I also have this problem and it is most noticed on a cold morning. The dealer kept the car three days and finally determined that the aspirator motor bearing were failing. Part on order. You should replace if you want the "automatic" setting for your heat and A/C to work properly.
Old 02-03-2011, 03:44 PM
elyjohn's Avatar
S500
Same problem on my car. See posting below. Need to replace if you want the automatic mode to work properly
Old 06-25-2011, 02:59 PM
MBinSeattle's Avatar
I read sticky on ac sensor in dome ?? How do you change from 1st reading to next after holding the rest button.
Quick Reply: Dome-light fan rattling?
