How 2 tell if W220 is ABC
2005 Mercedes Benz S500 4Matic
Hey guys I have a 05 W220 4matic on 20 inch staggered wheels and I am looking for lowering links however I need to know if my car has ABC (Active Body Control) or not. I have NO IDEA how to tell and there are no posts adressing how to tell if your W220 has ABC or not. Thanx
BTW, if you have 4matic you should not be using stagger wheel configuration, for the AWD to properly work requires all the rims/ tires be exactly the same.
Really?? Im running a 20x8.5 with a 245/35 in the front and 20x10 with 275/30 on the back with an 1/8 spacer. Whats the worst that can happen to my 4Matic system?? The wheels are the same diameter as the stock wheels. What kind of issue can it cause?
I had researched this at one point because of odd tread wear I was experiencing with my 4matic system. Unfortunately I can't find the information I read at the time, but if I recall properly it was stated staggered wheels could damage the system (differential and transfer case) and it referenced both diameter and width. I do know newer 4matics can use staggered, but I thought it was because of changes made to the system over time. Sorry, may not be useful as I can't find the original source I had referenced at the time, but a bit of "for what it's worth". Staggered wheels were not an option on the 4matic at that time.
James
James
4 Matic cars must have the same diameter tires otherwise you will damage the 4 wheel drive system . You can run different widths but diameter must be the same or very very close
Yeah my diameter is the same as my stock wheels. No issues there I did my research haha. Anyways thanx for all the help. I will be getting lowering links soon and will post pics up!
The center diff is open, aka NO posi, so it would just spin a little faster to one set of axles.
I ran differnet diamters on my Audi for a short period of time with no ill effects, aka center diff on Quattros is open as well. You can purchase a posi as an option is Audis.
Just sayin
