Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension
- Mercedes-Benz C-Class: Why is Suspension Noisy?
Guide to diagnose trouble and recommended solutions
Cracking noise from suspension when going over speed bumps
Service Bulletin
Could one of you please send me the Service Bulletin. I am having the same problem with the front suspension noise...Please send to pedro.diazii@yahoo.com
Can you please send me the Service Bulletin, having same problem. Please send to pedro.diazii@yahoo.com. Thanks
I get some cracking noise in the back, sounds like coming from the trunk but i checked and removed everything from the trunk and it is still there, it only happens when driving over big bumps on the road.
(1960) 300d, S550 AMG S500 S600 560SEL
as far as ive seen its not a bandage. mb originally would have you replace the sway bar but i think the final fix is to "glue" it so there is no movement. i can defiantly see your concern with this as far as short term but so far it seems to be working. you are right some designs act like a hinge when the sway bar moves. in this application it is not the case mb doesnt want any movement there. if you applied some sort of grease and sanded and cleaned the surfaces it would probably work too. i would recommend the proven method though. the bonding adhesive that is recommended is some pretty nasty stuff probably holds the space shuttle together haha i believe its called DEVCON mb part number a0059890971. hope this helps
Owned an Infiniti M35x, Drives an 08 S550 4matic
Can you please send me the Bulletin, i'm having the same problem as well. Ikeibe28@gmail.com
#32
Mercedes-Benz
Thank you so much in advance
#33
I was having the same problem took it to the dealer today and they told me I needed a sway bar, tie rods, engine mounts and I have an oil leak. I'm glad I took that 2 years extra cpo coverage.
#35
Mercedes S Class S320 CDI (W221)
My S Class (W221, S320CDI, 2006) does also have this suspension noise problem, but worst on cold startups, and always on road bumps. Very irritating when driving a car like this. I get noise both from front and rear suspension. My MB-dealer is not capable of locating the couse of the problem.
From having read this tread, can I conclude with replacing the front suspension sway bar is the fix? What about the rear axle? Is there a similar sway bar to replace?
#36
PS: Would be very grateful for receiving the described service bulletin to asr@mail.com.
#37
2008 S63
Could someone please send me this bullitin. Cb.tosado@gmail.com I have the same problem front driver side squeaking bad. Even when I get in or out of the car now.
#41
Hi,
I am a newbie to the forum, just found this topic as I have exactly the same issue with my car.
Would some of you guys forward me the service bulletin to bmakany@gmail.com?
Thank you in advance.
#42
CL55, S550, 450SL
I'm getting a rattle at low speeds going over the smallest imperfections in the road. I'm thinking its from something to do with the suspension (possibly torsion bar from what i've been reading). Don't really hear it over bigger bumps or at higher speeds. Is this what your problems were like??
#44
#45
Can someone e-mail the bulletin to me at rogersdba@yahoo.com
#46
Received 4,446 Likes
'71 Pinto
#47
would someone please send this bullentin to cmims@neo.rr.com please thx!!!
#48
2008 S63
Can I get this to cb.tosado@gmail.com please. I requested a while back but isn't get a reponse. Thanks.
#49
creaking
#50
'71 Pinto
Would someone kindly send the bulletin my way also mustmike86@hotmail.com
