Sponsored by: DashLynx
Replace the dome light bulbs for W221
Old 02-13-2012, 06:34 PM
tonykharper's Avatar
2007 S 65
I've searched but have been unable to find this information. I did find this pic on EBAY but I can't believe you have to remove all this to get at the bulbs.
http://www.ebay.com/itm/OEM-MERCEDES...sories&vxp=mtr
Please help!!
Old 02-14-2012, 09:37 AM
2007 S 65
Please help!!
135 views and no body knows how to replace the dome lights.
I still have no light, but at least I don't feel as bad. I thought I was the only one that could not figure how how to get those buggers out.
If you know how it's done please share.
Tony
Old 02-14-2012, 02:48 PM
cool_lagoon's Avatar
(1960) 300d, S550 AMG S500 S600 560SEL
it's not hard, just use a plastic wedge and jam it on the perimeter of the ceiling lighting assy. one side at a time, pull and pop it out then unplug the socket within the rest is just a stroll in the park. Good luck and enjoy your new LED lights.
Old 02-14-2012, 04:25 PM
2007 S 65
Cool lagoon thanks for taking the time to respond. But on my W221 S65 it is a little different.
After much searching, and a lot of looking, I found two screws in the overhead sunglasses compartment. They aren't really screws, just plastic fasteners. Turn them a quarter turn to the left and the rear of the entire unit will drop down and allow access to the light bulbs.
Be careful there are a lot of connections on that unit. The light fixtures unscrew from their holes with a turn to the left.
Hope this saves someone else some time and frustration.
Tony
Old 02-14-2012, 04:33 PM
All W221 have the same ceiling front dome light, the two plastic tabs are for fastening and securing the assy from squicking and yes they are located inside the sun glass console.
post picture after the change and let's see how the LED perform as against the original warm white bulbs.
Old 02-16-2012, 04:21 AM
desired_speeds's Avatar
2007 SL55 AMG
I've replaced one of the rear interior light bulbs under the grab handle on a friends car and holy **** it was a PITA.
Old 02-16-2012, 09:43 AM
2007 S 65
Please explain how you went about doing it. It took me two days to figure out how to do the front dome lights.
Hopefully you can save me some time and energy.
Tony
Old 02-16-2012, 11:12 AM
phatisfy's Avatar
S-class
Tony
how did you remove the front dome lights?
Old 02-16-2012, 01:04 PM
2007 S 65
See post 4 above.
Old 02-16-2012, 01:40 PM
what color did you choose? pictures? i plan to use white on the rear and front reading light and leave the dome with warm white color led bulb
Old 02-16-2012, 05:49 PM
2007 S 65
I'm going to start with all white LEDs but may change the domes back if they are too bright. But I still haven't figured out how to get the rear dome or the side headliner lights out. I'm afraid to pry too hard.
Is there a special place to put the pressure?
The glove box and foot well lights looks much better with the brighter (white) leds.
No pics yet, but maybe when I'm done.
Tony
Old 02-16-2012, 07:12 PM
Tony, use a plastic wedge to pry through the long side of the back ceiling light as to avoid scratching the light assy.
Old 10-12-2012, 02:40 PM
sanjaysingh's Avatar
2007 S550 & 2005 S500 (both FULLY loaded incl. AMG sport package)
Tony
Did you get any pictures?? If you did it, would be super thankful if you could post them.. Thank you so much in anticipation..
Old 10-17-2012, 06:27 AM
S5Hundal's Avatar
S550
Sorry but where did you actually purchase the LEDs?
Old 05-02-2018, 03:12 AM
shotikogabo's Avatar
w221 S550
If someone wants to know how to replace W221 rear dome light bulbs check this video on youtube
Quick Reply: Replace the dome light bulbs for W221
