W221 2006 Backup camera stopped working
Hi,
Often its quite useless to write here but may be at least one of you have had such issue and it will be easy to explain
When put into reverse only black window appears for one second and goes back to audio display. The same black screen appears when i put into drive after reverse but this time i use joistick to return to audio mode.
My camera part number is a221 820 03 97 but i tried on 221 820 33 97 taken from 2008 w221. This cameras shell is a little bit different possibly replacement part). It didnt help, the same issue.
Checked wiring by electricians and all wires show signal.
Do you have any suggestions? Modulator? Do i have to replace exact part number?
P.S.
Merc is the most ****ty car i have ever owned. Hate this crap car. Lexus the best!!!
P.S.
CaliBenzDriver (03-07-2021)
Hi,
So Why come here be positive and ask ?
https://mbworld.org/forums/s-class-w...cal-cable.html
Have a look there or use the search function ?
P.S.
P.S.
Good Luck !!!!
Hi boyz.
This time Im more useful tham all of You
Changed replacement camera - nothing, changed unit - nothing. Rechecked the wiring and it was cut. Fixed the same wire. 110$ repair cost
Received 4,417 Likes
'71 Pinto
Camera control module - 141 (5A) @ rear SAM
'71 Pinto
N10/2 located behind left trunk panel.
Panel removal (shown on CL550, same for S550) http://workshop-manuals.com/mercedes...ar/page_14823/
'71 Pinto
As of MY09 located behind the paneling in the center of the trunk, on the partition wall between the passenger compartment and the trunk. When the center armrest is folded down, the rear SAM control module with fuse and
relay module (N10/2) is accessible from inside the interior compartment.
'71 Pinto
Yes
Reverse Camera not working FIX UPDATE W221 S350 Bluetec 2011
If you just a black screen with the reverse camera guidelines coming up once you are in reverse gear you have a broken cable.
most common place of this break is looking in towards the trunk is the left hand quarter panel.
remove the bottom boot liner and rear plastic moulding, then the left hand rear quarter lining panel and you will see a single black solid type of cable approc 3-4mm thick. follow with your land and see if you can see the damage which is normally just behind the left boot hinge. normally this is a clean break if no picture is showing or if power is lost then a few cables within it may be damaged.
the 4mm cable has inside it 4 separate cables so if you want a simple job and not having to buy a new cable and open up the whole car to run it just use connector blocks and around 6" of cable and do the repair.
you will need approx 6" of cable in a few colours so i just striped down normal household flex cable and used that.
plastic 3 amp connector blocks and stripped the original cable and connected it all up and it worked fine.
easy fix and took about 2 hours to find the break and strip the car and put back together but i did this first time with no clue on what i was looking for
so now with these instructions i would say around 30-50mins max time needed but saved myself around £300 by doing a DIY job
car was a S350 Bluetec 2011 W221 model.
The following 2 users liked this post by ammars27:
eldabr (11-18-2017),
W109 W211 6.2L (03-12-2018)
Ndhlovu (10-22-2019)
I have w221 S550 2008 you diagnostic and fixing help was quite helpful. I have the same issue the camera cable was broken I splice with my own wire piece and now it is working perfectly.
W221 s500L (UK Version)
Thank you!
It's just after the hinge of the boot lid but right before its clipped to the body of the car. I can see why its a common problem. So I just re twisted the 4 wires (encased in a black cable) together and sealed them individually with insulation tape and voilà!! It works!. So thank you for posting the tip!
2009 s63 Backup Camera not working. Black screen
Would their be a display if there was A blown fuse?
Thanks.
cable breaks at the point it flexes for the boot lid movement is normal on such well designed Mercedes, bit like rain water rolling off the boot lid and dripping copious amount in the car
NOTE:
very different camera on the later cars - cheaper and better
NOTE:
Mercedes S500 2007 - reverse camera stopped working.
So this Merc S500 is supposed to be probably the most sophisticated car of its time and should have been built to last a lifetime. My car is a 2007 model with a genuine 161.000 Km on the clock. It has been properly serviced and kept in tip-top condition.
I sent the car in to a Mercedes mechanic to see if he could fix the rear view camera. I was quoted ZAR31.000-00, equivalent of US$2.067! I was told that it could be much more than that when they had stripped the car! I found that amount of money ludicrous and I took the car back. For that amount of money I could live without a reverse camera.
Yesterday was a public holiday and I set aside time to strip and find out what may be causing the problem. It should be noted that I do not have a computer programme for the car so I would only be able to check connections, etc. However I do have a sophisticated multimeter and therefore would be able - in the old-fashioned way like when we had proper technicians and mechanics and not just 'fitters' - to check the continuity of the wires.
Removing all the covers was a fair bit of tedious work and then we started checking the connections. We did not have to go far when, lo and behold, we found that the single wire from the camera that was attached to the curved boot hinge was broken, just under where the boot lid meets the car body. I tried to find out what could have caused this cut but could not see anything obvious.
The fix was very easy. We stripped both ends of the wire and connected the ends together.
When I put the car in reverse the camera worked 100%.
I am very surprised that the normally fastidious Engineers from Mercedes Benz could have allowed such a stupid and easily remedied problem to occur in such a luxury motor car.
I subsequently went on the internet and found that this problem with the reverse camera seems widespread. A lot of people have replaced cameras and computer boxes only to find that the camera still did not work!
I am even more surprised that I cannot find a Mercedes Benz bulletin advising owners of these older cars about this problem.
the days when a Mercedes was styled like a taxi and built like a tank ended in 1990, today they are less reliable than a 1978 Lada that's been through 10 harsh Russian winters... with the current stylist, they tend to look worse these days as well !
since 1980 the only thing that matters in life is marketing... your life its far better now !, 1/3rd the pay, no future and the planets dead... but remember the marketeers tell you its better
as for the first post swapping the aluminium camera for the better half priced plastic one …. the 4 wires need to be re pinned.... then it works just fine. The E class camera is the same physical part, but another $100 cheaper however the removable mounts is different
