My C55 dyno results - stock filters vs. K&N's
Rating: Thread Rating: 4 votes, 5.00 average.
Old 01-29-2008, 02:55 AM
JToups386's Avatar
2005 C55 AMG
I know there are several options for air filters on any of our cars. Personally I've always used K&N on everything I've owned since 1991, with great results.
This past weekend I had my C55 dyno tested and was most displeased to open up the air boxes and find clogged FRAM filters in there.
1st pull through the FRAMs yielded 298.85 rwhp and 309.96 rwtq.
2nd pull after removing the panel filters and simply putting a K&N universal cone filter over the MAF sensor to prevent any debris from entering the engine, yielded 309.59 rwhp and 323.56 rwtq. I'm pleased with these numbers!
These are SAE corrected numbers. The un-corrected numbers were higher.
We also tested another C55 with stock replacement K&N panel filters and the car increased 8 rwhp over the stock filters.
This is definitely worth the $100 spent for two K&N's, and knowing I won't have to buy other air filters for the car ever again.
Just FYI...
Old 01-29-2008, 05:50 AM
MBworld Guru
FrankW's Avatar
white and whiter
I think this will put the filter doubter to rest.
Old 01-29-2008, 06:21 AM
MRAMG1's Avatar
S600, GL450, Audi A5 Cab
Just FYI...
THNAKS for the great work JToups386
I have been preaching K/N's for almost 2 decades now, THEY are REALLY tuff to beat for the money per their return on HP.
See yeah
PS: There have been K/N's in EVERY car I have EVER owned.
Old 01-29-2008, 07:32 AM
bumpnzx3's Avatar
W203 C230SS
First off, I am a supporter of them.
However, the one flaw to this test, that I see, and I am sure the doubters will too- is the fact you said the stock filter was clogged in your car. Also, nothing was ever said about the condition of the stock filters in the other car you tested also.
Again- just something the naysayers (*sp?) will point out.
Old 01-29-2008, 09:11 AM
slowrey's Avatar
2006 Mercedes C55 AMG
Yup that's my question is what would the dyno say with fresh MB filters.
Old 01-29-2008, 10:33 AM
rory breaker's Avatar
Yes
Agreed, would love to see that.
So you put a cone filter over the maf, and leave the panels empty? I have yet to inspect my engine compartment (and it feels great, coming from always working on my cars) so I have no idea about the layout.
Old 01-29-2008, 10:49 AM
slowrey's Avatar
Heck when I changed my airfilters from the dirty stock filters at 23K to brand new MB MANN filters I felt a definite improvement.
Old 01-29-2008, 01:17 PM
JToups386's Avatar
2005 C55 AMG
Well, this testing was done on two C55's. The 8 rwhp gain was picked up on my friend's C55 who had stock MB filters in it, and then replaced them w/ the K&N OE style panels and immediately re-tested to see the gain. We dyno'd mine later in the week. So, his was a more accurate sample than mine I suppose, but I expect the same results. Once my K&N's arrive I'll strap 'er back down and test it again with my own car.
The cone filter test was just to see how restrictive the stockers were. Per the throttle body design and placement of the MAF sensor on the C55 it would be difficult to use a single permanent cone style filter on it. You would not be able to use the engine top cover if you did. Also it would defeat the fresh/cold air inlets from the front of the car which would likely cause a HP loss under normal driving conditions.
My filters were somewhat clogged, however my biggest concern was the fact they were FRAM, which is one of the lesser filtering mediums on the market. They may be the most popular due to their marketing campaigns, but they are not the best in micron-level filtering, whether it be oil or air filters. As for a stock paper replacement I would always use WIX or a Purolator PureONE version, however there is a great advantage to using a K&N that can be washed in the kitchen sink anytime it gets dirty. K&N also makes a good oil filter element for our cars which I'm going to use as well.
At the end of the day, there are many dyno proven tests to show considerable performance gains when using a K&N (or the likes) in place of a stock paper element. My Z28 was no different in that it picked up 17 rwhp by using a MTI air lid and K&N panel filter.
The advantage I currently have is that my friend owns a shop w/ a dyno, and also drives a C55 for now, so we're both gauging the results of any changes we make, and can do so on a regular basis. For example, he learned this week that by replacing his AMG wheels w/ heavier 19" look-alikes, the car lost 14 rwhp. That's valuable information!
Stay tuned for more results...
J
Old 01-29-2008, 10:56 PM
MarcusF's Avatar
2002 CLK430
One thing you may wish to consider - a run with no airbox, and a second run with the airbox and no filters. This will tell you the restriction imposed by the stock box, and what's possible with filters. That way, when an ad appears that says "'x' hp from our box" or some unreal number from filters, you'll know whether they are within the realm of possibilities or just saying whatever it takes to make the sale.
Old 01-30-2008, 07:41 AM
Yes
Yep, if you have free access to a dyno, it would be AWESOME if you could take clean stock MB filters (maybe even new and just resell them on the board), K&N's or Greens, and no airbox, dyno them back to back to back.
Not sure what we can do in terms of compensation, but you would receive the love and adoration of thousands of curious benz owners for years to come!
Old 01-30-2008, 10:40 AM
fivepointfivev8's Avatar
C55
Originally Posted by rory breaker
...it would be AWESOME if you could take clean stock MB filters (maybe even new and just resell them on the board), K&N's or Greens, and no airbox, dyno them back to back to back...
+1 +1 Did you notice any change in the engine sound?
Old 01-30-2008, 11:34 AM
JToups386's Avatar
2005 C55 AMG
There was a little more engine noise per the air boxes being removed when we tested w/ the open element cone filter. However that would be expected on any vehicle. It's a sound similar to an open four barrel carburetor, but more refined. And, it's really not an option to run it that way all the time so it's kind of a moot point. If more sound is the goal, then removal of the resonator would be the easiest resolution.
As for all the other testing that's been recommended, I think there are certainly some good ideas being suggested. However, since this is not my "race car", and I'm only trying to pick up a few small gains here and there, I don't anticipate I'll be doing all of these additional tests.
I believe we have clearly shown that with the K&N panel filter replacements we can gain 8+ rwhp. The number may vary 1 or 2 rwhp in either direction depending on all things being equal, but that's a good gain for a small investment. If you use other similar products, ie Green Filters, etc, you'll probably see about the same gains. However, by what I've seen, the Greens are not as durable in quality so I chose to stick by the brand I've always used in my performance apps.
I just wanted to share my results with everyone since we actually have data to back up the claims. I'll do this for any mod I make in order to help others decide if it's worthwhile for them too.
Old 01-30-2008, 11:41 AM
c32used's Avatar
LET C32 2002
I don't understand
I took fresh OEM MB FILTERS, GREENS AND K&N and took them to the track granted never dynoed all of them individually but it really don't matter cause on the track in the real world the better filters shined via better quarter times...I ran each filters minimum 3 times and gave the best of all their individual runs...it proved that on my C32 they worked better while running...if the OEMs gained better at a dyno on a track is where it will really be tested for overall performance...I say don't even think about trying to run or dyno without air filters anything gets thru you can ruin the engine...people who say to test it that way should consider doing it themselves taking the risk instead. Great number though! I had dynoed when stock with fresh green filters 299 rwhp 290 rwtq and with dirty K&Ns on a warmer day by like 10 degress 286 rwhp...but on the track the fresh K&Ns yeilded better times on first track meet but greens slightly better on 2nd. Jacek ran slightly better time on OEM filters on one of his multiple runs...but I still feel that aftermarket filters are superior but not by huge amount. I can't vouch for a C55 though since its NA but I feel the aftermarket filters will shine in all cars compared to OEM.
P.S. We ran several times first to practice the launches...
Old 04-20-2008, 06:43 PM
Yes
any updates on this? would like to replace my stock filters with either greens or K&N or just clean stockers, I am skeptical as to the benefits of going aftermarket.
Old 04-20-2008, 08:16 PM
Former Vendor of MBWorld
hooleyboy's Avatar
C55,SL55,C63
the best thing about K&N filters are you don't have to buy a filter ever again just keep it clean and oiled correctly. over time they will pay for themselves. For me going to aftermarket lifetime filters was a no-brainer any HP gains are just gravy. K&N has been around for a long long time and to stay in the game that long you have to have a good product. go to your local auto zone or parts store and get some k&n filters (you need to buy two) you wont regret it aftermarket filters are a big upgrade over stock.
Old 04-20-2008, 08:17 PM
1qikctr's Avatar
Merc power
K&N FTW.
Old 04-20-2008, 11:30 PM
c32used's Avatar
LET C32 2002
K or G FTW...
Old 04-22-2008, 12:58 PM
rbaker's Avatar
Z06, M3, Mini Cooper S. Sold: C55
Green Filters <FS>
If anyone needs a pair of Green Filters for their C55, I have some left over from mine. I sold the car so I obviously don't need them anymore. First $60 takes them.
I think I also have a pair of Porterfield R4 race pads for the front axle if anyone tracks their cars. Plenty of pad left, used only 1 event $100.
Old 04-22-2008, 10:55 PM
Quick Silver's Avatar
2019 CLS450 4matic, 2013 CLS550 4matic (totaled), 2005 C55 (traded), & a Ford F150
Originally Posted by 1qikctr
K&N FTW.
FTW?
Old 04-22-2008, 11:01 PM
HLG600's Avatar
R230 SL63 | W220 S55
Originally Posted by Quick Silver
FTW?
For The Win.
Old 04-22-2008, 11:36 PM
hkycoldrct's Avatar
2002 C32 ///AMG
Not the best test since running without the airbox would be pulling hot air in from the engine compartment whereas if your running without filters your pulling cooler air in through the ram air tubes.
Old 04-23-2008, 01:08 AM
MarcusF's Avatar
2002 CLK430
That might be the case if the dyno shop uses a WalMart box fan. With the hood open and a real fan, the engine is ingesting room temperature air, not engine compartment air. The first photo is a picture of a CLK430 that SoCalCLK used to own - note the fan.
Cars that run boost generate so much heat that 20,000+ CFM fans are required. Regardless of the airbox, a dyno shop should have a fan capable of proper airflow. Without it, the car will run hot and the dyno numbers come in low.
Old 04-23-2008, 01:02 PM
hkycoldrct's Avatar
2002 C32 ///AMG
"Run" on the Dyno. I was thinking in terms of a 1/4 mile "run". 10-4.
Old 04-23-2008, 03:10 PM
Newzchspy's Avatar
PLAID
FTW
FTW?
Harley Guys says " F *** the World" ; You see it on their jackets (colors as they say!!)
Glenn
Old 04-23-2008, 03:57 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
wow, that's pretty nice gain!
i've been using K&N ever since my 1st car...
i know i'll gain at least .1hp but never dyno'ed to verify that...
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: My C55 dyno results - stock filters vs. K&N's
