W124 Driver Side Power Window Regulator installation
Old 04-23-2014, 01:14 AM
mercymercedes's Avatar
W124 E220 Masterpiece
About six months ago my driver side window gave up the ghost. Taking the door apart, I discovered that the window regulator had snapped all three of its' spot welds. A new one cost nearly U$200 and came with a white 12mm nylon washer (bush). Unfortunately, I had no idea where this washer went and ended up placing it under the motor's dust cover. Bad idea. It has slowed down the window operation and just last week, stopped working altogether….too much strain on the electric motor, I guess.
Anyway, I'm going to have to take the door apart again to rectify this. So the BIG QUESTION is…where the hell does this nylon washer actually go? Photographs attached show my old regulator and a sample motor photograph borrowed from an ebay sale, showing the motor with this nylon washer in situ. Is this where it should be placed or not? Any advice would be most welcome. The door card and regulator is a nightmare to remove and re-install. Don't really want to do it a 3rd time! Thanks, Delboy.
Attached Thumbnails W124 Driver Side Power Window Regulator installation-regulator-plastic-bit-copy.jpg   W124 Driver Side Power Window Regulator installation-dsci0045-copy.jpg
Old 04-23-2014, 11:42 AM
Plutoe's Avatar
1999 E300TD
Very strange, because the only circular opaque washer that I know of goes behind the hand crank!!
Have you visited a local dealer and asked to look at one of their regulators!!!
Old 04-23-2014, 07:50 PM
The sole importer here is not interested in helping. Would rather sell you a new car and wave the old one off to the scrapyard! Hand crank? 'Aint seen one of those since Noah invited me round for a 'all you can eat' BBQ.
Old 04-26-2014, 02:30 PM
vexed's Avatar
1995 E320 Cab; 2007 E350 Sport
The nylon washer is a bump stop for the regulator arm. Like you I had trouble deciding whether it was for the top or bottom of the arms travel so I put one on each end. A little trick I learned after replacing the regulator more than once is to turn it upside down inside the door so the "top" is facing down. A lot easier to remove.
Old 04-27-2014, 12:41 AM
Thank you Vexed. When I removed the broken arm, this item was detached. A bump stop makes sense, but why only one? Have to get it out of its current location anyway. Much happier to do this with this additional information. Cheers.
Old 04-27-2014, 06:31 AM
ONe more question. Exactly where does the bush go? On either side of the motor?
Old 09-29-2016, 11:06 AM
MB Streetballer's Avatar
Is there an electrical component that stops the motor on the window regulator when the window reaches to the top or bottom? I have a 1990 MB 300E.
Quick Reply: W124 Driver Side Power Window Regulator installation
