Stock Crank pulley wobble!
2007 sl65 amg
I know it is a common issue with our cars. I have noticed the wobble after I have installed a smaller S/C pulley. I have a 3 pc ASP idler pulley set on my car. However I don't have belt wrap kit and have not replaced a tensioner yet.
I still have a stock size S/C belt on it. Only my crank pulley has a wobble, but I am not sure because I have some engine vibr. since I put in new engine mounts. Optical illusion maybe!? I hope so. What should be an order of things to do,check, replace first? If I have to replace Crank pulley, which one to buy?
Used OEM? New OEM? Aftermarket? I would like to keep it stock size
Need some Info guys! Thanks
Will post a video in the morning!
2003 porsche 996 turbo
there is likely an elastomer between the sections of the factory pulley that is failing or coming out. it happened on my silk when i had it. replaced the factory pulley with new unit all was well. look to see if you have elastomer separation. should be easy to see
2007 sl65 amg
I can't upload the video. It will not let me
I think it may not work uploading it from my phone
Happened to me.....my stock crank pulley separated into 2 parts one day.....clean separation, the original oem rubber damping material eventually gave up (car had 129k). Installed new oem pulley ($500 online) and all seems well so far....
@125k now.... guess I have to put that 185mm pulley I have on sooner than I thought. I have about 2mm separation that is new. I can tell from the evident difference in oxidation between the SC/Acc drive pulley. It this is on my list but now I guess is #1 along with adding some additional "mod friendly" additional equipment Comprehensive Insurance coverage through USAA.
I can see them blaming my LTH for the failure.
Guess she is getting parked again. My Accord will be happy though lol
Installed with tq + 90 degrees proper like?
What did it take out when it fell off PumpedTSI?
Believe it or not......nothing.....I got lucky. Opened the hood and the outer piece was laying in the bottom of the bay on top of the tray......belt came off, motor still ran......no damage. I drove it to the shop, in fact, it was at the shop I discovered it......
Yep similar with my oem HB - I also got lucky with my 84mm SC pulley when it failed I was able to replace before catastrophe.
