Weird Tranny Problem
Just to clarify done a lot of digging before posting.
MANUAL changes to Sport by itself.
Star no codes found
I honestly don't understand this why it happens I can run the car flat out and suddenly find my sleep being Sport Mode. Driving me nuts.
Oil + Filter changed at AMG After this and they said all is OK we need make a deeper test...
Miss my manual
Anyone seen this before I haven't been able find this problem mentioned on any other cars who also has the Manuel mode...
Any information would be highly appreciated
Star no codes found
Miss my manual
2005 E55, 2009 VW GLI
There is a TSB from MB regarding this issue. See the link below for details.
https://mbworld.org/forums/w211-amg/...ay-m-mode.html
-OA
-OA
-OA
-OA
This confirms my suspicion
"The engine oil sensor may be the cause"
I found a error bad engine oil sensor and when clearing the code will of course come back until solved Tranny works.
Sensor in my hand. Oil ordered sweet super super thanks man you saved me a lot if time and money on pointless diagnostics.
Wow I actually found error code p2076 oil temperature not plausible - with Carsoft 7.4 multiplexer lol.
Regular OBDII didn't show any codes nice.
Thanks again...
I just saw it
and all is good when I clear the code but happens again of course so have ordered the new sensor, sucks just had oil / filter change anyway I believe Shardul is right when he replied me on this thread about the sensor code
https://mbworld.org/forums/w211-amg/...ml#post6849222
And then when O-55 replied on this thread
psuball1 had it replaced and acknowledge
so the tranny has been repaired and O-55 was right, bad oil sensor. I would recommend that anyone that has this issue should print this thread out and show your tech, if I would not have given this info to my tech he may not have figured it out.
O-55:
here's what i'm talking about...
Date: June 20, 2008
Order No.: P-B-18.40/39
Supercedes:
Group: 18
SUBJECT:
Model 171.473, Equipped with Engine M113.989
Model 203.065, Equipped with Engine M112.961
Model 203.076, Equipped with Engine M113.988
Model 209.376/476, Equipped with Engine M113.987
Model 211.076/276, Equipped with Engine M113.990
Model 219.376, Equipped with Engine M113.990
Model 230.472, Equipped with Engine M113.995
Model 230.474, Equipped with Engine M113.992
Transmission Mode Changes from M to S
Click the image to open in full size.
If you receive customer reports in the above model vehicles of the transmission mode changing by itself from M to S/C while driving, the engine oil sensor may be the cause. The engine control unit may contain no stored faults codes or the fault codes shown above. To resolve, install engine oil sensor A006 153 59 28.
Here is the sensor (who have thought crappy Carsoft 7.4 could actually see the problem lol, used Carsoft on my old CLK 320 back then )
I just saw it brother, I get p2076 oil temperature not plausible'
O-55:
Date: June 20, 2008
Supercedes:
Group: 18
SUBJECT:
O-55:
Date: June 20, 2008
Supercedes:
Group: 18
SUBJECT:
http://www.mercedesmedic.com/how-to-...mercedes-benz/
Problem Solved thanks
So finally got the new Oil Sensor, oil and the time to swap the sensor out, Damn what a relief super slick..
Since I just had oil change 300 km ago I just drained rear oil plug 30Nm
then out with the sensor in with new one 15Nm
Oil and a good long run until warm and then.. Darn
I missed this, there is nothing like the E 55 in Manual with the S/C kicking in what a difference thanks guys I am super super happy..
You guys Saved me some $$$$$$$$ sweet I needed that lol.
Even I explained this to my AMG garage and told them I know MB know this is a known problem but all they said oh well we need do a deep tranny test $$$$$$$ not again totally wrong to focus there even most obvious one should think but this shows the MB specially the AMG is not that obvious I like that...
Thank you all thank you thank you thank you I got my car back I am so happy 4 months with this crap and tranny not just manual also S and C was not like it used to be it is now Yahoooo...
