Boostane Octane Boost-Tried and Tested
Former Vendor of MBWorld
We tried the Boostane Octane Booster and have had some really incredible results. Since we are in California and suffer from horrible 91 Octane fuel, we were searching for a decent solution. Unlike most Octane boosters, the Boostane app (available on IOS and Android) helps you determine how much octane booster you need to add to your gas. Download the app for free on your smartphone to try it out.
I would recommend buying a case of octane booster and leaving it in the box in your trunk and add it to your fuel every time you fill up.
We have tested this on the dyno and it makes great power with California fuel.
We sell this by the can and the case. If you are coming to use our dyno I suggest that we throw a can in after all your power runs to see what kind of horsepower and torque you are leaving on the table by not using this stuff. Everyone that has tried it on the dyno has bought a case when they left.
If you have any questions please feel free to ask me.
If you want to purchase some and try it for yourself please feel free to stop by our shop in SoCal.
wikiwiki (07-20-2016)
It's 29.95 a bottle and a case of 6 is $164.95. You do not use a whole bottle usually like you do with other Octane boosters. You can download the Boostane app and use that to identify the amount of octane booster to add to achieve the final octane number you are looking to achieve.
MMT is definitely a part of the formula that Boostane uses but it is done differently then other octane boosters so I will explain it to you. What Boostane does differently than other Octane boosters is that it is formulated in a way that keeps all of the chemicals used so that they don't separate. It keeps the MMT in suspension with the other chemicals and everything other octane booster does not have that type of formula.Your plugs and cats are safe because the proprietary carrier and delivery system is able to avoid these issues by keeping all of the active ingredients, regardless of density, in suspension indefinitely. All other octane boosters have difficulties of keeping all of the active ingredients, including MMT, from falling out of suspension. Once it falls out of suspension their is no way of keeping these ingredients from being drawn through your fuel system in a coagulated form and that is when you will have problems with plus, injectors and filters.
Boostane does not have these issues.
I recommend you download the app and check it out. In California we have horrible fuel so we use it just to get a small increase in octane so we can be on par with the rest of the country. It's really amazing what a difference you will see between 91 octane fuel and 93 octane fuel. When only looking for a small increase in octane you will find that the Boostane lasts for a long time providing a very good value to the customer.
2014 E550, 2015 E63S, 2017 G63 - RIP
OK, downloaded the app and, according to the calculator, to achieve 93 octane on a 14 gallon gas tank one needs 0.5 quart of boostane...
But wait! EXACTLY the same amount is required to achieve 95 octane!
Not only it's expensive for the daily use, but also smells of BS...
I don't wanna sell any bs and I don't want to be the one to show how a car performed on it because people like you won't believe it if the results are very positive so I have an idea.
You are in LA. Why don't you come down and put your car on our dyno and baseline it with 3 passes. Let's then put the Boostane in it and test it again with 3 passes and see if it makes a difference. I will do this for you for free. I am hoping that you have a modified car.
It would be so much better if I did this with someone that has no vested interest in this so you make a great candidate for the test.
zcct04 (07-20-2016)
I googled it and ths GT-R guys seemed to like it more than torco.
Well, I guess we will have to put it to the test.
Let's move to PM from here ;-)
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
I'm not buying it unless I see live dyno results. Which I highly doubt you will or can produce.
30hp increase in a BMW 750 with one can of octane booster is BS. There is not 30hp to be gained with a 750 with 2-4 octane numbers.
At our local 76 in Los Gatos sells 100 octane fuel. I put it in and cannot feel a difference. I am sure my timing is advancing automatically, but if there is no HP to be gained, it's just not there. I may gain at most 5-10HP running straight 100, so I will bet the farm that putting in this can of whatever, won't get more gains then that. In fact it won't.
Unless you have liquid Jesus coming out of these can's, I am not buying it. Literally and figuratively.
People buy ***** pills and diet pills for the same reason. HOPE.
BLKROKT (07-21-2016)
Mazspeed (07-20-2016)
http://www.gtrlife.com/forums/topic/...ctane-booster/
Mazspeed (07-21-2016)
Depends what year 750. If it had the N63tu motor with twin turbos, fuel makes more of a difference. The GT-R stuff I was looking at had someone do some independent dyno testing and they claimed some pretty significant gains. One test added a can to 5 gal and one added a can to 7 gal IIRC. Much different than half a can to 14 gal though. Here is the thread I was reading. Take it with a grain of salt.
Yeah, snake oil.
In high boost applications, yes higher octane is very important. But a can of this cannot boost octane that high even in a 7 gal tank. If you ran 91 in a 7 gal tank with 91 in it, and ran a can of this "Boostane" crap octane booster you might be able to get .5 1.0 increase on the AKI octane scale. So in a 25 gal tank on a BMW 750 of any kind is not going to get you 30hp. I'd bet my dick on that. The results that the link you provided was a fabrication. I don't trust the company providing results unless it's 3rd party verified, which of course it's not. Read the last link I put in here. They test the theory of this in a lab. Nothing beats lab and street testing.
http://mycarneedsthis.com/the-best-o...s-and-reviews/
http://www.superstreetonline.com/how...uel-additives/
The following 2 users liked this post by Mazspeed:
BLKROKT (07-22-2016),
chrisridebike8 (07-21-2016)
Not only that, but the chemicals they put in this stuff is known to foul plugs and kill 02 sensors.
If you get anything, get fuel cleaner. Not Octane booster. $29.99 for this garbage. You might as well light your money on fire. This guy is peddling crap!
If you believe the OP you will believe this.
wikiwiki (07-21-2016)
2012 C63 AMG, 2014 Bugatti Vitesse, 2015 Ferrari Speciale Aperta, 2015 RR Phantom, 2016 Aventador SV
2 Enzyte Commercials - YouTube
Mazspeed (07-22-2016)
Just so you know, Europe uses Research Octane Number (RON), where the US uses the average of Research Octane Number and Motor Octane Number. If the Octane rating in Europe is 95, the same gas would only be around 91 in the US.
