77mm vs 84mm pulley, is it worth it?
I currently have a stock pulley but I'm looking at going to a 77mm clutched pulley. Here's where the tricky part comes in. The pulley itself costs $100 more to get the 77mm, then you also have to spend another $400 on a heat exchanger. So, total cost of doing to a 77 vs an 84 is literally double. I know the heat exchanger does offer benefits regardless, but is it really worth double the money for what is gained? It's not a dyno car, or a track car, or a drag car (though I do want to do WannaGoFast sometime).
read this
http://www.mbclub.co.uk/forums/amg-l...dyno-test.html
You will pick up a lot of low end torque and with the way the cars already have issues with traction the power increase would be better off up top. The smaller pulley creates more boost, but the supercharger decreases efficiency the faster you spin it, which leads to more heat.
I should clarify a little more on what I'm after. I see the dyno numbers, that isn't my interest. I know what the graphs mean, and that shows why I should do one to start with. Where my interest lies is, one option is $400, the other option is $1,000. Is the butt dyno gain worth it for over double the price? I'm talking about true subjective driving. Is the fun factor worth the extra money?
I don't believe there is a real $400 option"...
77mm not worth it for a whole bunch of reasons.
Agree with the other responder on traction and heat. If you have the "mod bug" but want to be smart here are a few options...
1). 84mm - $400
2). Split cooling
3). Custom Tune - $500
be done with it and enjoy it...
or
1). Split cooling
2) Meth Unjection ($1,000)
3). Everything else stock
Either way (IMHO) you will need to increase your budget.
In stock form the cars had heat/traction issues.
TK
1). 84mm - $400
2). Split cooling
or
1). Split cooling
TK
I'm already tuned and split cooled. I agree heat is an issue, which is why I bring it up because going the 77mm route I have to do a heat exchanger as well. The 84 I can get away with not doing it but wouldn't hurt.
in fairness you should really upgrade the heat exchanger even if you are keeping everything stock and even if you are just doing the 83. The 77 to really work with any efficiency is going to require not only the heat exchanger but probly also a trunk tank. The 77 will work fine for maybe 1 short romp, but other than that it will be slower vs an 83 if you don't have tons of cooling
Ive been contemplating this quite a bit lately. But after reading this thread:
https://mbworld.org/forums/w211-amg/...ed-my-car.html
My conclusions:
- Stock pulley has potential to fail, if not inspected regularly/caught when cracks occur
- aftermarket upper pulley has even higher failure rate
- Aftermarket upper necessitates a scatter shield for protection
- aftermarket upper requires larger pump and an aftermarket heat exchanger
All of the above for a street car never tracked..
not worth it to me.
Will stick with the EC tune and thats it
Just my thoughts.
My conclusions:
not worth it to me.
Just my thoughts.
My conclusions:
not worth it to me.
Just my thoughts.
My conclusions:
not worth it to me.
Just my thoughts.
05 E55, 07 ML500
There is a fine line between too much boost(heat) and pulling timing which will make you slower and not enough boost. You definitely need a larger heat exchanger, split cooling without it won't do that much.. If I were going with a 77 I would at the very least put a truck tank in as well or go with meth. I have a 168 crank and 83 upper which equates to around 186-188 crank. If you add headers it will help with the cooling as well. Cooling is really the most important item on these cars.. My set up is right on. Just enough boost without too much heat.. Good luck.
What Silverstrk is telling you is very accurate. Cooling will make or break you. It is possible the car will run stronger with the stock supercharger pulley due to lower IAT's The higher the outside temps and the longer the pulls the worse it gets. The cooling is barely adequate w/ no mods when outside temps get higher. when outside air temps go up IAT's go up timing is pulled. For anything like a 1/2 mile wanna go fast event you will need a trunk tank with plenty of ice even for an 84 mm. Enjoy it stock once you start the mods it does not stop. I have a used 84mm with under 1200 miles. PM if you want it.
So would you say the best course of action is the 84mm and a heat exchanger (down the line) vs a 77mm and heat exchanger now as a result of the 77mm may not outperform the 84mm after a short period of time of driving?
05 E55, 07 ML500
Daily driver and she is a true sleeper with many road kills to her name. No track. You NEED the larger H/E. Do this immediately, then put the 84 on and see how it feels. Make sure your pump is running strong, if you question it at all put a new bosch 010 on as well. Header Really help with heat as it expels it much more quickly than the stock manifolds, which I might add are a Real restriction on this car. I have MBH and they are works of art. PM Shardul for the pulley and H/E, he even has a buy on headers right now, don't know the quality but it's a Real good price for long tubes. Good luck..
HeissRod (12-08-2016)
Being winter time I can definitely wait on the HE. I got the car February of this year and the IC pump needed replaced which I only knew because I checked how quickly AIT's dropped. It didn't drive any differently after I replaced it. I never saw AIT's above 70 F till the end of March. If I went 77mm I'd do it right away, but I was thinking about maybe doing it anyway around May or June when it starts getting pretty hot. Only once have I found the car to be gutless, when it was a little over 100 degrees and very high humidity. (heat index was like, 115 or 119).
When dealing with any type of modification, I'm accepting potential failure. I also know that if 1,000 cars change something and 1 has a problem as a result, odds are still in my favor. I wouldn't let an isolated incident determine everything.
understood, but based on the contents of that entire thread, it's not isolated. (aftermarket SC pulleys exploding). Im not saying every single one fails, but common sense says that there is a higher chance of aftermarket, smaller SC pulleys failing than stock. And without notable cooling mods, an 84mm may even end up getting you slower performance than pure stock/pure stock with a tune
Already did that.
I did catch onto that after some digging, and I emailed them to find out they will match the price of FTP's, FYI.
