Service B price?
Service B price?
called around a couple of local dealerships for prices.
$450+tax
$620+tax
what's up with the price difference? how much is everyone else paying at their local dealership? seems like such a basic service at a crazy high price.
$450+tax
$620+tax
l3it3r (04-21-2017)
2021 E450, 2020 C43, 2015 C300, 2007 C280
Consider your local independent shop
On Tuesday, I had my C300 at my dealer outside of Boston for the 2-year "B" service at 10,600 miles. The first 2 years of service were part of my purchase price. Likewise, the previous "A" service at one year. I asked the service rep. what the cost of the next "B" service would be (at 4 years and 20,000 miles). She replied that it would be $800+. The intervening "A" service at 3 years would be $300+.
In 2007, I did my first, one-year "A" service on my first Mercedes at another dealership. Services were not part of the purchase price on that Mercedes. (See my Signature below.) As I recall, the total price was $280+. I didn't like the way they made one charge for one filling the windshield washer fluid and a second charge for the fluid, both of them outrageous. The grabber was that I had filled the windshield washer fluid just before bringing the car in! I found that my local independent shop, European Auto Solutions, did services for about 60% of the dealer price. They also support the Mercedes-Benz Club of America, and the manager is the vice-president of my local section. (See my Signature below for my testimonial to the $500 discount I received on the purchase of my second Mercedes!) So I will be returning to European Auto Solutions for future Mercedes services.
i just did the 20,000 miles Service B, they did change the brake flush. my car is not even 1 year old yet, it be 1 year in 2 days on Jan 24, 2017. maybe they changed the brake flush cus i have the prepaid maintenance package.
Brake flush is every 2 years
Change the fluid according the manufacturer specification listed in your owners manual (NOT the DEALERSHIP specification - dealers are out to make PROFIT, they are not in it for your best interest).
The Service B listed for our 2017 C300 Coupe (C205) calls for:
-Oil Change. OEM Oil filter is about $10-$15 on Amazon. 7.4 qts of Mobil 1 0w-40 runs ~$40.
-Dust filter ~$15
-Activated Charcoal dust filter ~$55
-Brake fluid replacement ~$60 in fluid + labor
-Perform a ton of "checks"
So for a Schedule B service, there's about $185 retail cost in parts. The rest of the cost is labor and PROFIT.
The following 5 users liked this post by Hapa88:
anderson_p00per (09-04-2019),
Darrington (01-24-2017),
gfmohn (01-23-2017),
realmccoy407 (07-25-2021),
schvamf (01-23-2017)
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe kid: 2017 GLC SUV
I'm being told the brake fluid flush/replacement is an additional $140 on top of the $599 for a Service B. If the brake fluid flush isn't included, why is a Service B so much more than a Service A ($290 last time)???
PROFIT
eddieo45 (01-24-2017)
While it is true that brake fluid absorbs moisture, it's only a concern if you have a leak in the brake system or if water somehow contaminates the system. Remember that the brake fluid system is completely closed. The hoses and lines are fluid and air tight for the most part (they have to be in order to maintain the pressures for braking). If they weren't sealed, you'd have air in your brake lines, brake fluid leaking everywhere, and potentially a complete loss in braking all together.
-Dust filter ~$15
-Dust filter ~$15
i had done B service 40k by the local shop without flush brake fluid .
costs less than $200
I think you can make an excellent case that a street-driven vehicle will not have enough moisture for a good number of years to have any impact on braking performance, as the fluid doesn't get hot enough to matter in most regular driving conditions. But there probably is some moisture (you can test it if you want) and will lead to some degradation in the fluid, and over time (perhaps quite a bit of time) will also begin to corrode parts in the system.
On a side note, I (unknowingly) put a few thousand miles on a vehicle with a bad caliper seal with a small leak and there was no noticeable decrease in braking performance. So I can attest to the fact that just because the system isn't perfectly closed, depending upon the issue, the brakes may still work quite well. Obviously, if there was a big issue or leak, you would know pretty quickly.
Finally, I should note that for any high performance driving/track days, where the fluid very well may reach temperatures that matter, changing the fluid is critical, because the drop in boiling points with even a little moisture may matter. While you can argue 2 years is overkill for street driving, it is way too late for track driving.
While the system is closed, you can be pretty sure some moisture is getting in. Think about all the seals in the system, multiple seals at each brake caliper, bleeder screws, each brake line joint, in and out of the ABS module, etc. Plus the microscopic pores in the rubber lines, and most easily, the cap on the reservoir, particularly when the mechanic opens it up to try to convince you the color of the fluid is a reason to change it (its not, but you've just added air that contains moisture into the system). I've seen internet "facts" (from reasonable sources, but not backed by studies) that the fluid will contain 1-2% moisture per year.
In any case, I do agree, without the ability to fully test the moisture content that spending $150 to do a brake flush on a track driven vehicle is definitely the type of insurance (and consistency) I would invest in. (Though I'm guilty myself of doing a few HPDEs on slightly older fluids.. luckily I didn't have any issues whatsoever with the ATE DOT4 fluid I was using)
Anyone have the part numbers for the Service A/B parts?
Is the brake fluid job on the W205 like any other car, or is there a specific procedure?
Oil Filter : A 2701800109
Engine Air Filter : A 2740940004
Fine Particle Filter : A 2058350147
Dust Filter : A 1668300218
C400
Oil Filter : A 2761800009
Engine Air Filter : A 2760940504 **2 needed**
The following 3 users liked this post by rustycruiser:
Awesome...saved me a search!
Great info. I've put USA MSRP for the parts below. Obviously, discounts available some places and/or for non-OEM parts.
C300
Oil Filter : A 2701800109 $14.50
Engine Air Filter : A 2740940004 $51
Fine Particle Filter : A 2058350147 $64
Dust Filter : A 1668300218 $22
Total OEM Parts MSRP (USA): $151.50
C400
Oil Filter : A 2761800009 $24
Engine Air Filter : A 2760940504 **2 needed** $39.50 each/ $79
Total OEM Parts MSRP (USA): $189
C400
I purchased both fine particle and dust filters when I did my own Service B but did not put them on as both are too clean to replace. I will save them for the next Service B. I also did not replace the brake fluid as it looks good too. I was amazed at the conditions of the pads, they have at least 80% left at 20K miles. Just my experience.
