SL/R230: SL500 ABC Conversion to Coil-Overs With "Light Fix" Module
Thank you all for the information and the opinions. It is good to know all available options.
Just to follow up with the Strutmasters update. I called and was told by the lady on the phone that they currently no longer offer the kit. She think they may be trying to redesign the kit but she is not sure. If they are to offer it at all again, which she is not sure either, it will be at least 2 to 3 months out. She also said that Strutmasters was the only company that conversion kit.
Has anyone tried to retrofit the Mercedes oem sl65 black series coilovers ? Wouldn't they work and be even better than the strut masters conversion ?
Anyone know how much they cost and the part numbers ? Perhaps they cost too much from mb
Each strut costs about the same as a basic ABC strut.
By the way I also discovered the windshield washer reservoir was leaking with a small crack, when I tried to fill it up with the fluid. With some work, I was able to slide it out (with the hoses still connected) after the front passenger wheel cover was removed, and glued/repaired the crack.
Mercedes SL 500 2003
Hi Good Morning i have mercedes SL 500 , i have a problem with the car. in front of the dugboard shes writing abc i already make her a test and the result was that the front left senior is not working. they tell me to to change the part all of it . the problem is that the car is not go up and down. can u tell me where i can find the park please because here in malta cant find thanks
MBworld Guru
Welcome to the forum! Please take a moment to visit the User Control Panel and update your profile to include your car model and year, and your location (at least country). This information will then appear below your name and avatar on the left side panel next to each post you make. This will greatly help others to give you better information. If you are using the mobile version of the site, you will need to switch to the "full" version to get to the User Control Panel.
Now, what error codes do you have?
#32
I got r230 conversion struts from CEIKA
I got the conversion struts from CEIKA, You can adjust the height, no swaybars needed. Drove 140 mph speed, no problems.
paste (05-05-2023)
#33
ABC TANDEM OUMP
A mechanic friend of mine helped me install the strutmasters coil-over conversion kit on my 2003 sl500 (I mostly just assisted). It took us about a day. It works great! I truly feel like I have a new vehicle again and I don't worry about paying $3800 (per repair!) on a regular basis for an abc system that should be much more reliable than it is for the cost. My vehicle stays just as level on turns as it did with the abc system. There were a few "creaking" sounds from the coils at first, but there are less and less each day as they settle more. So far there are only a few drawbacks. 1) The install takes longer and is not as easy as the strutmasters videos make them out to be. 2) My car sits slightly higher than I'm used to seeing it (worth it b.t.w.). And 3) I have yet to figure out how to wire that light fix module correctly, as the wires in the manual do not match up with those under my dash. I don't have an endless amount of funds, so, all in all, I am satisfied with the conversion since it makes for 1 less bill on a vehicle that is a joy to own, but is very expensive to maintain. Still searching for the proper wiring for that light fix though. Any help with that would be greatly appreciated.
#34
im looking to do the same my main question is about the existing pump.. do you leave it as is and just cap the old lines at the struts and do you pull the fuse for the abc pump so it just runs low pressure???btw there are several u tubes on the light fix module which explain install...
You can loop back the ABC pump output hose so that it feeds right back into the reservoir, or you can replace the tandem ABC/power steering pump with a power steering only pump.
You cannot just cap the lines.
#35
here is how to on a CL W215 Just follow the Idea no fuses nothing just loop
you can remove everything if you want, even the abc cooling radiator. good part with that is that if you have a V12 you can easy switch to the full size intercooler radiator
https://mbworld.org/forums/cl-class-...ping-pump.html
#36
Any electronic geniuses in the forum??
Gents, I am pretty sure that in this forum there are individuals capable of figuring out what value of resistors are necessary to 'simulate" typical ABC inputs. That is basically what Strutmasters did, they measured the Ohms values on the Strut itself and placed a bridge on the connector..! Then build a box for sale! I have done the same with some old electronic sensors, but have no good info on these hydraulic struts! If anyone have done experimentation on this, please let me know! The shocks and suspension arm sensors are just plain rheostats!
Thanks!
Thanks!
llcoolbenz (01-06-2022)
#37
SPONSOR
WWW.BENZNINJA.COM
Thanks!
Thanks!
#38
Thanks!
Thanks!
#39
CDK, if the tree pin cables are traced to the module, it will be a lot easier to put a standard rheostat and adjust to the required values. I wonder where can a "electrical diagram" of the system could be located to determine the polarity! So, identifying the points 1,2 and 3 in the struts and the values, this will be a piece of cake at a cost under $5.00.
#41
I haven't seen or used a 'light fix' module, but my guess is that it is a CAN filter programmed to filter out ABC error CAN messages. Resistors might work for some sensors, but the ABC module looks at current draws at all solenoids, it reports errors if levels don't change as commanded, etc. If you don't have DAS, buy the box and don't worry about it. If you have DAS or easy access to DAS, code out ABC.
#42
Inquiry
