SL/R230: Used 2007 SL550 with 27,000 miles
Old 01-29-2015, 06:36 PM
MNMM's Avatar
2011 Jaguar XF, 2007 SL 550
Arrow Used 2007 SL550 with 27,000 miles
Hello,
I'm a new member and thinking of buying a 2007 SL550. I've heard motor mounts and struts can be a problem. What else is problematic with this model/year?
Old 01-30-2015, 11:49 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to R230 forum...
Old 01-30-2015, 12:29 PM
kbob999's Avatar
'08 S550 P3; Golf Carts; MT Bike; Scooters
What to look for...
Read this:
http://www.benzworld.org/forums/r230...l#post11217842
Old 02-01-2015, 10:56 AM
El Gringo's Avatar
2007 SL550
MNMM
I have an 07 SL550. Other than the normal stuff to look for, the ABC system is the one they say will most likely cost. I am not a fan of third party warranties, but they say there are some good ones out there if you do your homework. They say a fluid and filter change for it is the best way to extend its life. I have read that you should check the fluid, if it is clear and greenish (new) then someone has changed it. If it is dark, then the maint hasn't been done and is prob soon to fail on that vintage you are talking about and you should run, (don't walk, run).
I have had no probs with mine. Tell yourself when it goes it will be $5000. Either have the money or the warranty or don't buy in.
Good Luck
Rich
Quick Reply: SL/R230: Used 2007 SL550 with 27,000 miles
