SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: New owner of 1988 560SL
Old 08-24-2016, 11:09 PM
Ornelas66's Avatar
2015 GL 550, 1988 560SL
Dear Members:
I just purchased a 1988 Mercedes Benz 560SL. My concern is that the "heat shield-ie form like material" on the top of the inside of my hood is falling off. Right now, I am just laying the material on top of the engine.
My question is, where can I buy a new heat shield, and how do you take off the old, and put in the new.
Any and all advise is appreciated.
Old 08-25-2016, 12:24 AM
ItalianJoe1's Avatar
2003 CL 600
I assume it's the same as the later model SL I did, but the foam mat is just glued on to the hood. Scrape all the old one off and clean the hood, then use a spray adhesive to coat the new pad and press it on the hood.
The pad can be found anywhere online with a little searching. It's essentially just a large piece of foam on those older cars. Doesn't really do much anyway. Mostly there for noise.
Ornelas66 (08-26-2016)
Quick Reply: SL/R107: New owner of 1988 560SL
