SL55/63/65/R230 AMG: SL55 Tire pressure monitors
you buy the ones for your car, they will be the right ones. Try ebay or any other MB parts store. After you have the car ready, you reset the TPMS on the screen , all the pressures will go _ and drive it 5 miles, they will all come on
1 Post
2005 SL55 amg, 2009 Lincoln MXZ, 2012 Dodge 2500 Limited
My 2005 SL55 doesn't have a visible TPM option? Is that an option that can be turned on with Star? Also a MB mechanic mentioned that the monitoring option on the sl55 only tells you that a tire is low, but not which tire. Can someone elaborate on this?
it will tell you which one is low and it will also give you a read out of what every PSI is in each tire at any time. When you initiate them you need to make sure they are pressured to the exact correct pressure, b/c this is where the system will then baseline pressure changes from. You then have to drive around 10-15 minutes without stopping. I have an extra brand new set of pressure sensors. PM me if interested. I was going to get a 2nd set of wheels, but I'm now not going to.
2003 SL55 AMG, 1989 348 Challenge, 1987 Testarossa, 1992 F40, 1989 Mondial t cab, 2001 X5 4.4 Sport
If they are dead, they need to be replaced. You can either go to the dealer and pay $300-$400/sensor, or Discount tire did mine for less than $100 per.
I would rather have everything working as it should, than just say F it.
I'm contemplating doing this. How have the sensors been working? Any issues? What was the total cost from Discount Tire including mounting and balancing?
Anyone know if the TPMS can be added to a non TPMS car?
I think my car has just about every option but the TPMS. To make matters worse, the 65 has no spare. I would be very interested in adding a system.
I have an extra set of brand new sensors that I bought when I thought I was going to buy a 2nd set of wheels that I'd sell cheap if anyone is wanting a set.
