SL55/63/65/R230 AMG: SL55 Convertible Top/Roll bar issue
Old 02-11-2016, 02:28 AM
sl55_maniac's Avatar
SL55 AMG
Unhappy SL55 Convertible Top/Roll bar issue
I've been having issues with my convertible top/roll bar for the past while now. When I hit the switch to drop the top, the windows make the sound as if the top was to activate, however, nothing happens. The roll bar is stuck in the down position (I have tried to manually reset this but it does not work) and I can hear the motor as I press the lower or raise button for it. At first I thought it was my pump which I sent to Top Hydraulics and Klaus confirmed the pump was functioning properly. The flaps in the trunk are properly intact and my cargo cover is also fully closed. Has anyone experienced this issue and if so what did you to do resolve it?
Old 02-11-2016, 08:38 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Well that sure is a complicated system,about 20 subsystems to open and close the roof,therefore I would not even suggest a guess,except that if I owned a car like that I wouldn't be here, I would be at the dealer where he will use is DAS Xentry diagnostic system to locate the faults in thirty minutes($180)
Is this a case where the repair choice depends upon cutting up the wifes credit card for a week or repair the car---I'd go for the scissors.
Old 02-11-2016, 03:21 PM
dRockSL55's Avatar
MBs: SL55, GLK350
Any messages in the dash during (attempted) top operation?
What about the red led on the top switch (if you have an 03-06), what is it doing?
Agree with the above on star das / xentry diagnosis
Old 02-11-2016, 03:29 PM
SL55 AMG
The message on the dash I was getting was "close trunk lid" when the trunk was fully closed so I went out and bought a trunk actuator as I attempted to epoxy glue mine but that did not solve the job. The new trunk actuator now finally closes the trunk tight on its own. I thought this would have something to do with the top as well but apparently it does not. As for the red light on top of the switch, I have not paid attention to that. I will have a look at it once I attempt it again.
Old 02-14-2016, 05:41 PM
SL55 AMG
When I activate the top switch to lower the roof, the light is solid red. Again, windows open up a little but nothing happens with the roof.
Old 02-14-2016, 10:00 PM
m-svt-amg's Avatar
2003 SL55
Sounds like a bad sensor more than anything according to the dash message. I would check the sensor responsible for that message first.
Old 02-17-2016, 02:45 PM
SL55 AMG
That dash message has gone away ever since I replaced the Trunk Actuator (soft close for trunk).
Old 02-18-2016, 01:28 AM
Nor Cal SL55's Avatar
2007 SL55
Had the same issue with my SL55 trunk. The latch mechanism was split open at the diaphragm.
Old 06-28-2016, 11:47 AM
SL55 AMG
Figured out the issue today. All along it was a result of a bad limit switch on the rollbar. $80. Much better than the stealership quoting me over 10k for a new pump and control module (which still wouldn't have fixed the problem).
Old 06-28-2016, 12:20 PM
Tomcat SL's Avatar
2004 SL55 AMG
Fantastic...how did you discover/diagnose?
Old 06-28-2016, 12:34 PM
SL55 AMG
It was not easy at all. To be honest, it took over 3 months of diagnosing. I was first getting errors on DAS which pointed to the direction of the trunk. After removing the control module (N52) and reconnecting, I finally got a S83/10 limit switch error. Replaced the switch and found out that the stealership kept my pressure valve open on the pump so this didn't help (only took for diagnosing a few months earlier prior to looking into it myself). After doing some additional research, I went over to the pump and closed the valve and voila! Roll bar and roof work just like new!
HopefullyE63 (08-28-2019)
Old 06-28-2016, 01:40 PM
PoCoAMG's Avatar
2018 E63S AMG
Glad this got fixed!
I guess this another lesson on how quirky these cars can be and in some cases, can be so simple to fix. Every time I talk to the dealer about the car, its "Oh man the pump is big bucks" or "these cars are troublesome and not cheap to fix" well like SL55_maniac has said, $80 and works like new. Love it. Patience seems to be the most cost effective helper with these cars (op says 3 months of diagnosing). Happy it works now and it's another good thread for people with the same problem. Now going to get out and cruise in "Betty" today. 30 degrees here in Vancouver so perfect for a burn in the hot rod. Top down of course
Cheers!
Shaun
Old 10-31-2017, 01:16 PM
Noir230's Avatar
1992 400E, 1997 SL500, 2007 SL55 AMG, 2016 E400
Roof Control Module Removal
Maniac,
I realize this is an old thread, but I'm trying to find info on removing and replacing the roof control module. All of the info I've been able to find seems to indicate that the rear interior side panels, the rear interior center panel, the center cover and the storage compartment must all be removed in order to remove the module. Did you find an easier way to remove the module?
Thanks,
Noir230
Old 11-01-2017, 12:11 PM
SL55 AMG
Originally Posted by Noir230
Maniac,
Thanks,
Noir230
Hi Noir, that was the way I got access to it. It didn't take too long actually.
Noir230 (11-01-2017)
Old 11-01-2017, 01:52 PM
Noir230's Avatar
Thanks, Maniac. I'll tackle it next weekend.
Old 07-28-2019, 09:06 AM
Invested's Avatar
SL600
SL55 maniac, I am getting the same code on my scanner. I was wondering where you sourced the switch from and if you had a part #, or a picture of the switch.
I removed the panel revealing s83/10, however, I'm not sure which part is the 'switch.' Pls advise
Thanks, Brandon
Old 07-29-2019, 12:15 PM
SL55 AMG
The part number was 2308210551. I sourced it from eBay. This part # comes up with a bunch of different parts. Make sure it is only the actual switch which is clear/see thru in appearance.
Old 07-31-2019, 10:40 PM
Invested's Avatar
SL600
Thanks, I cleared the s83/10 code on my scanner, and verified if the 2 switch units worked, which they did, and then put it back on the unit. The roof then starting moving, (so it doesn't look like I'll be needing that part) but I could tell it was slow. Noticed hydraulic fluid leaking near the pump, which ended up being the left roof cylinder. The roof should work after I replace it. Appreciate the help!
Old 01-13-2021, 02:34 PM
de56723's Avatar
R230 sl63 AMG
Hi,
I would be grateful if you could talk me through how you accessed the switch and removed.
Where is it located and how long did it take you ?
Old 01-13-2021, 04:23 PM
Invested's Avatar
SL600
Originally Posted by de56723
Hi,
Accessing is done by pulling the panel off. Locate the big , long speaker/sub under the roll bar, and look at the end of the speaker-- the top part of the panel is close. Bend it downwards and you'll see the switch which is located on a rectangular metal part (forgot what it's called) which moves the roll bar up/down. I think the switch can be unscrewed from the metal rectangular part
​​​​​​My switch wasn't broken-- it just needed reset via scan tool
only took 5-10 min
Old 01-13-2021, 04:31 PM
de56723's Avatar
R230 sl63 AMG
Thanks for the update.
How the heck did you reset it. Every time i clear the codes it just pops straight back up as a fault.
Old 01-13-2021, 04:55 PM
Invested's Avatar
SL600
My roll bar was simply stuck-- I didn't have the popping issue. The fault code should provide a clue as to what the issue is. If it pops back up, I'm guessing you're able to lower it after it pops up, so I'm guessing the manual switch works?
Old 02-16-2022, 07:25 PM
Servant of God's Avatar
SL500
i have same problem . where is that limit switch and how did you come to that conclusion?
Old 02-26-2022, 11:53 AM
Tomcat SL's Avatar
2004 SL55 AMG
Slightly related thread...maybe someone with recent folding top issue remembers:
https://mbworld.org/forums/sl55-amg-...ml#post8520127
Quick Reply: SL55/63/65/R230 AMG: SL55 Convertible Top/Roll bar issue
