Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W210 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-16-2011, 07:56 PM   #1
Drives: 2000 E55
vincentie
x pipe only?
i am interested in doing an x pipe also ,but not sure if i should just do a resonator delete only or add in the secondary cat? (what is better?(definetly dont want to throw any lights!!) i am ready to do it soon i,so i also need a place to purchase it if any one knows. At some point i want to throw in that ams stage 2 kit tooo!!! but will have to wait a while ,because i need front rotors and want to get sport bilstein struts,right now i am riding on H&R sport springs with stock shocks and can't stand how the car feels!!!
To remove this ad, register today or login if you already are registered!
vincentie is offline   Reply With Quote
Old 03-17-2011, 12:42 AM   #2
SPONSOR
Drives: AMG
Do the high flow 2nd cats at same time you do X-pipe.
High flow 2nd cats can be purchased directly from Performance-curve for only $59.99 now ...
http://cgi.ebay.com/ebaymotors/2-5-M...Q5fAccessories
Also, there high flow stainless steel X-pipes are now an astonishing $29.99 !!!
http://cgi.ebay.com/ebaymotors/2-5-C...Q5fAccessories
If you buy a couple of mandrel bends from them as well you can combine all the shipping and save even more money. These prices have come down so much from back in the day when I first performance this modification years ago. You can get all the parts you need now for under $180 where as it used to cost $250-300 back then.
Once you do the high flow 2nd cats & X-pipe, your car will be much better prepared to accept the AMS Stage 2 kit and will perform much better.
Hope that helps.
AMS
__________________
<<< AMS Performance Website (Click Here) >>>
Please View Website for Important Announcement ...
AMS Performance is offline   Reply With Quote
Old 03-17-2011, 01:12 PM   #3
Drives: 02 E55
Hope that helps.
AMS
If you do this setup will it pass the CA smog?
mtnhouse is offline   Reply With Quote
Old 03-17-2011, 02:43 PM   #4
desired_speeds's Avatar
Drives: 02 E55 & 04 E55
Send a message via AIM to desired_speeds
Quote:
The x pipe yes, but not with the high flow cats. they won't even ship it to CA. I'm still trying to get my hands on a pair.
We should meet up and check out each others cars one of these days after you get your H&Rs dialed in.
desired_speeds is offline   Reply With Quote
Old 03-17-2011, 05:32 PM   #5
Drives: 02 E55
Yes for sure! Its almost dialed in, the front dropped a little bit but i still need to replace the pads in the front to make it level. Actually bennz55 also from the bay is planning to have w210 e55 get together somewhere in the bay.
Old 03-17-2011, 05:59 PM   #6
Drives: 2006 CLS500 - Iridium Silver w/ AMG Sportline
Ship them to an out of state buddy and have them forwarded?
boschk is offline   Reply With Quote
Old 03-17-2011, 10:47 PM   #7
sounds good, keep me updated if theres a meet or something.
Old 03-17-2011, 11:13 PM   #8
Drives: E55, W140, R129
Smog test and noise aside, would straight pipes be a better option (performance wise) than high flow cats?
Same question for the x pipe's really.
Thanks!
JU570 is offline   Reply With Quote
Old 03-17-2011, 11:49 PM   #9
Thanks!
yes for the cats, no for the x pipe
Old 03-19-2011, 08:45 PM   #10
MBFLO's Avatar
Drives: 01e55blk/blk
Hope that helps.
AMS
How much would a shop usually charge to install all mentioned items .. Worried not to get a hackjob. should these b installed at a performence shop or can be welded at any local MIDAS or muffler shop . Want todo this but dont trust any place locally to touch my ride especially start hackin my exhuast .
__________________
MBFLO is offline   Reply With Quote
Old 03-19-2011, 10:40 PM   #11
Quote:
don't take it to midas. simply don't. bring it to a muffler shop that is mod friendly or a performance shop.
Old 03-20-2011, 08:51 AM   #12
Drives: 2000 E55
vincentie
thank you for your help, i am going to do what ams requested and hopefully have your stage 2 kit bought somewhere in the near future!!!!!
Old 03-20-2011, 01:10 PM   #13
SPONSOR
Drives: AMG
Sounds good, the high flow cat & x-pipe mod really compliments the stage 2 kit very well. All together they will be classified as stage 3+.
Hope that helps
AMS
Old 03-23-2011, 11:51 PM   #14
Drives: 2001 E55
Anyone know what size X pipes to get fro a 2001 E55?
mrbeverlyhills is offline   Reply With Quote
Old 03-24-2011, 01:23 AM   #15
Quote:
2.5 in diameter
Old 03-31-2011, 08:29 PM   #16
Drives: 2001 E55
Hi all and thank you for the help. I have done a search on X Pipe but so many hits- I guess if your signature has X Pipe in as a mod it comes up even when not on topic.
So my question is: I have the correct 2.5 inch diameter X Pipe in a box, can this be installed instead of the resonator and with no other hardware? I do not have the mandrel pipes I have seen noted in posts, can a performance muffler shop just cut out the resonator and weld this in place all by itself, that's it?
Many thanks.
Old 03-31-2011, 09:32 PM   #17
cudaized's Avatar
Drives: 2002 E55 AMG Obsidian Black with Charcoal
AMS
Which mandrel bends? Two 90s?
cudaized is offline   Reply With Quote
Old 03-31-2011, 09:55 PM   #18
SPONSOR
Drives: AMG
two 2.25" 45 degrees for the w210 e55 application.
__________________
Old 04-02-2011, 03:52 PM   #19
Drives: 2008 C350
Will a secondary cat delete or replacement with a high flow pass inspection in the other 49 states?
glovemoney is offline   Reply With Quote
Old 04-05-2011, 11:45 PM   #20
snooozie's Avatar
Drives: 86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
Hi, I am new to this forum but have read the omeyhomey official x-pipe site. There are a few nice pictures of them done up by the guys in that forum. I am curious, would it have a better flow if you mate the 2.5" x-pipe with the 2.5" 45 degree mandrel pipes with the OEM 2.36" pipes?
snooozie is offline   Reply With Quote
Old 04-06-2011, 12:06 AM   #21
SPONSOR
Drives: AMG
Quote:
The high flow 2nd cats are 49 state legal yes, Delete cats are illegal in all 50 states period (hence why we never recommend to do that). Plus, there's no real reason to, the car sounds better with high flow 2nd cats and you only sacrifice about 1-2HP tops.
Keep it legal and get the cats, you won't regret it.
__________________
Old 04-06-2011, 12:07 AM   #22
SPONSOR
Drives: AMG
Quote:
No, no benefit, just get the 2.25" mandrel bends with 2.5" x-pipe.
hope that helps.
__________________
Old 04-10-2011, 12:18 PM   #23
snooozie's Avatar
Hi, does anybody knows of a muffler shop in CT, besides midas and monroe who would know what an x-pipe is when I give them all the hardware for them to weld together? Or you think the neighbourhood midas would do the job? Thanks
Old 04-10-2011, 02:37 PM   #24
dont take it to midas
Old 04-10-2011, 02:41 PM   #25
jtbeche's Avatar
Drives: 02 E55; 99 CLK430 (Sold)
I don't live in all that big of a town and just some local tire place that also does regular maintenance has a pretty good exhaust guy that'll do just about anything I ask him to. Shouldn't be too hard to find a place like that. I wouldn't bring it to a national exhaust chain.
__________________
Rome did not create a great empire by having meetings, they did it by killing all those who opposed them.
jtbeche is offline   Reply With Quote
Tags
cost, curve, cut, detroit, e420, midas, or, performance, pipe, pipes, ship, straight, w210, welded, xpipe, yahoo
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
