Plasti-dipped
Old 09-04-2015, 04:11 AM
P-Rod's Avatar
E55 w210
Very nice looking batmobile
I'm considering running the same suspension as you did with the H&R's, Bilsteins and #1 pads. How does it handle? Does it roll when you hit a curve too fast? Do you feel the road better?
Old 10-15-2015, 08:30 PM
turbo1k's Avatar
2001 E55 1999 E55 2001 ML55 2017 C43
The car handles great with very little body roll. Defiantly worth doing and easy I might add. I did all the rear control arms and bushings so that might make a difference if yours are not done. I might try the Polly bushings in the front LCA.
Old 02-29-2016, 08:19 PM
turbo1k's Avatar
Originally Posted by cm60k
Flat Emblem is more suitable with your great Plasti-dip touch, don't forget to paint the calipers..
ZAYED,,
Did a little winter maintenance. New lower control arms, ball joins, swaybar links, turned the rotors, pads, wheels bearings, seals, and painted the calipers
Old 04-21-2016, 07:45 AM
turbo1k's Avatar
Originally Posted by Frank N Sense
I like it a lot.
But, I'd like the wheels to stay silver.
Report back in an hour after you removed the coating for me.
Tha-anks.
Here you go.
I also added new Nitto Invo all around and cut the H&R springs until I got the stance I wanted.
Old 04-21-2016, 08:00 AM
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Looooooooooks AMAZING..
ZAYED,,
Old 04-23-2016, 11:16 AM
turbo1k's Avatar
ZAYED,,
Thanks for the kind words.
Took her for an alignment this morning now she is ready for daily driving duty.
Old 04-23-2016, 02:22 PM
  #32
wasp01amg's Avatar
2001 E-55 AMG
I'm diggin the color. Stealthy!
Old 04-23-2016, 10:54 PM
  #33
illest's Avatar
4 matic
Looks good.
are you running spacers in the back. my rear wheels are not that close to the fender
Old 04-23-2016, 11:19 PM
  #34
Frank N Sense's Avatar
E55AMG 2000 E55 AMG 1921 Ford T Speedster
Looks spectacular.
It really does.
Nice work...and a superb artsy fartsy style. I mean that in the most flattering way!
Old 04-23-2016, 11:32 PM
  #35
You obviously know what your doing with the dip..I do NOT!
I just bought a Ford T Speedster and its all yellow, even the spoked wheels.
It all looks fantastic but I was thinking of trying the color black on the wheels.
Do you have any idea how difficult it would be to adhere the P.Dip to the spokes?
How about removing it?
Thanks.
I dig your car.
Old 04-24-2016, 09:21 AM
  #36
turbo1k's Avatar
Originally Posted by illest
Looks good.
No spacers. I lowered the car until the tire just about touched the inside part of the fender then I added some negative camber to achieve the look I wanted and it's still within spec. Here are a few close up pics.
Old 04-24-2016, 09:24 AM
  #37
turbo1k's Avatar
Thanks.
I dig your car.
I'm on my phone but when I get home I'll give you a write up on how I did the plasti dip so it can be removed fairly easy.
Steve
Old 04-24-2016, 09:32 PM
  #38
Thank You Steve.
Just do it if you will on your free time.
8^)
Old 04-25-2016, 07:07 PM
  #39
turbo1k's Avatar
Thank You Steve.
8^)
Now that a nice T model you have there. I think some black wheels would compliment the yellow very nicely.
This is how I do my wheels and other small pieces.
Clean, clean, and clean.
Once you have a nice clean surface I would tape anything you don't want painted.
I have only used the plasti-dip name brand paint and I usually buy from Home Depot.
My first coat is very light, more like a dusting. I give a single pass over the entire piece, don't worry if it didn't cover 100%. Your just trying to get a good base.
My second and third coat I apply a little heavier.
Now my forth and final coat I apply pretty heavy.
I believe the above method make it much easier to remove and leaves a better finish. When you apply the first 3 coats try not to go back over spots because you think it needs more. We all do this and it's one reason most rattle cans look bad and have runs. 4 wheels usually take 2-3 cans. Spray 8-10 inches away. Make sure you shake well. I wait 15 min between coats.
Hope this help. Feel free to ask if you have anymore questions.
Steve
Frank N Sense (04-27-2016)
Old 04-26-2016, 11:16 AM
  #40
IanB's Avatar
'99 E55t AMG
I liked it better with the wheels dipped, you should try taping off the lips and respraying the faces, lol!
Old 04-26-2016, 09:32 PM
  #41
Steve
Hey Thanks so much Steve. I do appreciate it. Thanks for the compliment as well. The car is fun as hell!
One Question: What type of cleaner would you recommend for the wheels prior to painting?
Thanks Man.
Old 04-27-2016, 01:56 PM
  #42
snooozie's Avatar
86 190D (Exported to the Nerderlands), 87 300TD (Sold), 82 Ford F150 3spd, 99 E300D (RIP), 02 E55
There you go. Might take it off and dip it in black.
Damnn...that looks good.
Old 04-27-2016, 02:08 PM
  #43
snooozie's Avatar
What kind of poly bushing.....energy suspension? I would like to replace the rubber bushings on the control arms too. Only problem is, getting the correct size
Old 04-27-2016, 03:20 PM
  #44
turbo1k's Avatar
I ended up just putting all new factory control arms in. I wasn't happy with the Polly bushings that are offered for our cars.
Steve
Old 04-27-2016, 06:52 PM
  #45
turbo1k's Avatar
Thanks Man.
I just use dish detergent to clean, let them air dry, and wipe down before I spray them.
Steve
Old 04-27-2016, 07:31 PM
  #46
Steve
Thanks again.
-btw,your vehicle looks way better with the wheels being silver.
It sets off the black body even more and your hiding a beautiful wheel.
But it doesn't matter what I think. It's not my baby.
Old 02-14-2017, 10:26 AM
  #47
HangtimeDMV's Avatar
03 CL600
How did the plasti dip hold up on this car ?
Old 02-15-2017, 07:24 PM
  #48
turbo1k's Avatar
After 2 years it was just as nice as the day it was done. I have since removed the wrap and trying to vinyl wrap the car myself. If you check out my other thread you can see the current state of the car.
Steve
Quick Reply: Plasti-dipped
