Safety issue! Check your Front Shock Top Mounts!!
Old 01-04-2017, 02:39 PM
Jan AMG's Avatar
The best or nothing
Exclamation Safety issue! Check your Front Shock Top Mounts!!
Check your Front Shock Top Mounts, there could be a hidden defect and a potentially a serious safety issue when the Top Mount "bowl" separates from the chassis. It is bolted to the chassis only in 3 spots.
Even a low mileage car can suffer from this defect. Check the photos.
CORRECT - Top Mount "Bowl" in place
SAFETY ISSUE
Attached Thumbnails Safety issue! Check your Front Shock Top Mounts!!-img_3474.jpeg   Safety issue! Check your Front Shock Top Mounts!!-img_3475.jpeg   Safety issue! Check your Front Shock Top Mounts!!-img_3473.jpeg   Safety issue! Check your Front Shock Top Mounts!!-img_3472.jpeg   Safety issue! Check your Front Shock Top Mounts!!-img_3476.jpeg
Old 01-04-2017, 05:50 PM
Fabio D's Avatar
210 55
Pretty common in the w210 chassis. I hate to burn the factory paint in this place welding this bowls to the chassis again
Fabio Daniel
Old 01-04-2017, 06:09 PM
Jan AMG's Avatar
The best or nothing
Hi Fabio, what are some other known issues? I wonder why this has not been made sticky if it is so common.
Old 01-05-2017, 10:33 AM
Fabio D's Avatar
210 55
Well. Is a common issue in the w210 but is not potentialy catastrofic. when fell off make some noise and you will see some rust comming from the area but nothing mayor like this. to weld it again, the paint in this area got burned and i hate to repaint this place. A mayor issue with the suspension componnents in the w210 chassis is the front spring perch's (here are to many threads about this situation) they rust and fell of and front suspension colide. This is a pretty pretty bad issue in this cars, is most common in cars used in salty ice roads cause the weather.
Fabio Daniel
Old 01-05-2017, 11:16 AM
Jan AMG's Avatar
The best or nothing
I'm aware of the front spring perch issue. Isn't it more common on a pre-2000 W210?
Well I hope the W210 doesn't have any other surprises.
After replacing almost every major suspension component and checking the whole car thoroughly, I have quite a good confidence in my car
Old 01-05-2017, 04:29 PM
Tall Giraffe's Avatar
2001 E55 OMG
I have the same issue on my car on the same side. The cup is a tiny bit jiggly. The other side is good. I have been spaying it with rust inhibitor till I finally get around to replacing the shocks and springs.
Jan AMG did you re weld yours? I have done almost every piece too and she drives great!!
I have never seen a thread about this topic. Thanks for sharing!
Old 01-05-2017, 05:51 PM
Jan AMG's Avatar
The best or nothing
Hi, yes I rewelded mine. I had also undone the other side, and rewelded it too, just in case.
Before mounting the shocks back back to place, applied the original conservation wax around the cups to prevent rusting.
I'm glad this thread helps!
Old 04-03-2017, 10:26 PM
trinitony's Avatar
E55 C43 993C2S
I checked mine tonight and see some rust. What's exactly is the fix on this? Guess I could spray with some rust inhibitor for now.
Old 04-04-2017, 06:22 PM
Jan AMG's Avatar
The best or nothing
Is it just a surface rust? I think the rust inhibitor should be fine and you are good for couple of years.
Quick Reply: Safety issue! Check your Front Shock Top Mounts!!
